post your pics of how u mounted your tachometers
turboedbug
turboedbug is offline
PostPosted: Fri Apr 01, 2011 5:25 pm    Post subject: post your pics of how u mounted your tachometers Reply with quote
how u mounted your tachometers, trying to get ideas of what looks good
Check out my video log of my beetle! suby swapped!
Instagram BoostedPower_ check me out!
Youtube channel!
https://m.youtube.com/channel/UCS4MUNXfeo3ZV9t2v4Wu-6A
Build thread video collection
https://www.thesamba.com/vw/forum/viewtopic.php?t=752062&highlight=
View user's profile Send private message Send e-mail MSN Messenger Classifieds Feedback
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Apr 01, 2011 5:28 pm    Post subject: Reply with quote
To the left of the speedo.
Glenn
Member #1009
#BlueSquare
turboedbug
PostPosted: Fri Apr 01, 2011 5:34 pm    Post subject: Reply with quote
thanks for the pic. maybe I shouldnt of been so vague, I am planning on tossing in a 5 inch tach. the location on the left is definently a no go thats where my oil, temp, and vac/boost is located. any other nice options? how about a bracket for easy install. Thanks again TurboedBug
Youtube channel!
Mr. 010
Glenn is offline
PostPosted: Fri Apr 01, 2011 5:36 pm    Post subject: Reply with quote
Some are mounted under the dash, on a pod off the steering column and in a cup above the radio.
Try searching the gallery.
Glenn
Member #1009
#BlueSquare
turboedbug
PostPosted: Fri Apr 01, 2011 5:38 pm    Post subject: Reply with quote
Thanks again glenn, off to the gallery
Youtube channel!
QRP
QRP is offline
PostPosted: Fri Apr 01, 2011 5:50 pm    Post subject: Reply with quote
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Fri Apr 01, 2011 5:53 pm    Post subject: Reply with quote
to the right of the speedometer:
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Max Welton
Max Welton is offline
PostPosted: Fri Apr 01, 2011 6:04 pm    Post subject: Reply with quote
Cool
Max
1967 Type-3 Fastback
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Fri Apr 01, 2011 8:28 pm    Post subject: Reply with quote
I have MS, but I don't drive around like THAT all the time! Laughing
No sir only gauge I have is the speedo, and that's currently got a stripped cable spline so it's disconnected.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
turboedbug
PostPosted: Fri Apr 01, 2011 9:12 pm    Post subject: Reply with quote
good call I should sell my tach and the other gauges. make a laptop mount and go that route using the software for my ecu
Youtube channel!
dmilla
dmilla is offline
PostPosted: Sat Apr 02, 2011 8:25 am    Post subject: Reply with quote
Experience is recognizing a mistake when you make it again...
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Apr 02, 2011 8:34 am    Post subject: Reply with quote
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
turboedbug
PostPosted: Sat Apr 02, 2011 7:24 pm    Post subject: Reply with quote
@ hotrodvw where did you get that bracket? I think that looks great
Youtube channel!
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Apr 02, 2011 10:54 pm    Post subject: Reply with quote
Fast-Fab!
'67 Sunroof
Eric
lots of money!
Hose & Fittings
jfats808
jfats808 is offline
PostPosted: Sat Apr 02, 2011 11:04 pm    Post subject: Reply with quote
Got mine too Hotrod!
MURZI
MURZI is offline
PostPosted: Sun Apr 03, 2011 3:04 pm    Post subject: Reply with quote
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
Cusser
Cusser is offline
PostPosted: Sun Apr 03, 2011 5:05 pm    Post subject: Reply with quote
Since 1976:
Rome
Rome is offline
PostPosted: Sun Apr 03, 2011 7:39 pm    Post subject: Reply with quote
Posting photos in my response has never worked for me, even following the Samba instructions to the letter. Here are two possibilities from my own Beetles:
[img]https://www.thesamba.com/vw/gallery/pix/189173.jpg[/img]
The tach is from a Porsche 914, which has the same diameter as the Beetle speedo. This method requires cutting out the factory speedo opening, relocating it to the left, and welding in a new speedo pod to the right from another car for the 914 tach.
[img]https://www.thesamba.com/vw/gallery/pix/183195.jpg[/img]
Another 914 tach, this time in a RadioShack "project box" under the dash. Disadvantage is that it's out of your direct line of sight.
fredy a
fredy a is offline
PostPosted: Sun Apr 03, 2011 9:52 pm    Post subject: Reply with quote
my test
sorry for the spelling
W1K1
W1K1 is offline
PostPosted: Mon Apr 04, 2011 6:00 am    Post subject: Reply with quote
3.3/4" mini monster tach
Mine mounts with a plate sandwiched under the mirror
Hers uses a plate that screws in under the the visor mount screws
it works well because it's always in your peripheral, and you can't see it from outside.
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
