Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Posted: Sat Apr 02, 2011 2:11 pm Post subject: Type 34 hinges redone |
i recently figured out how to redo type 34 hinges,
now others have their way,. but this is mine.
i used 2 different brand kits as not everyone can get a certain type, so i wanted variations of the same thing ,but both seem to be the same, HELP (38381) and NEEDA (383822)from my local FLAP,
it seemed to be more important to match the bushing hole,and just redrill the pin hole for a good tight fit.
(the HELP kit one has a third pin but it wasn't used for anything, )
and both work well,...and both have 2 pins and 4 bushings, i just showed both so you know what to look for
the rest is pics,. so feel free to ask me any questions if you have any,..enjoy!
so you got the old pin out....wasn't that a big ball of fun?
WooHoo!
you have to drill the old pin holes slightly for the new pin,
11/32 drill bit,.the new pin is slightly larger then the old one,hence the redrill.
now the second pin is slightly shorter then the bottom hinge but it works very well,.. the long pin i used for the top hinge and had to cut the excess off when done
each kit does 2 hinges, each kit ranges from 11 bucks to 9 bucks depending on your area. _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot.
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Sat Apr 02, 2011 2:25 pm Post subject: |
Way to go Foxx; nothing like putting cheap Chinese Pep Boys crap in your Type 34.
But seriously: Nice work. I did mine with a drill press and a drill press vise, and went through absolute hell finding bushings to fit the OEM hinge pins. I didn't even think of FLAPS, I could have saved a lot of time and bullshit. A hole for oiling is a great idea, too. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
Foxx Uncle Meat
Posted: Sat Apr 02, 2011 2:42 pm Post subject: |
| Tram wrote: |
But seriously: Nice work. I did mine with a drill press and a drill press vise, and went through absolute hell finding bushings to fit the OEM hinge pins. I didn't even think of FLAPS, I could have saved a lot of time and bullshit. A hole for oiling is a great idea, too. |
the Needa? kit ones came from O Reilly's auto parts
the HELP kit came from Advance auto.
pep boys is good for stickers and fuzzy dice, but they have the "HELP" stuff too.
anything is better then the plastic bushings that Germany gave us  _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23535 Location: Kimball, Mi
Posted: Sat Apr 02, 2011 3:55 pm Post subject: |
I used some VW 8mm valve guides to do mine. I had the outside of them turned down slightly, to fit the hinge part, and used some oil light bronze washers to take up the slack. I think I had maybe 20 bucks total in the 4 hinge assemblies. I did re-use the OE hinge pins though. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Foxx Uncle Meat
Posted: Sat Apr 02, 2011 4:12 pm Post subject: |
| Bobnotch wrote: |
| I used some VW 8mm valve guides to do mine. I had the outside of them turned down slightly, to fit the hinge part, and used some oil light bronze washers to take up the slack. I think I had maybe 20 bucks total in the 4 hinge assemblies. I did re-use the OE hinge pins though. |
i know,..yours was a work of art,. but i donno if everyone has access to a lathe, so wanted a "over the counter" solution that anyone could afford and do.
plus it gives you new pins!
WooHoo!
i guess this would work also on t14 hinges too?
OG JHC
59 panel
Posted: Sat Apr 02, 2011 4:24 pm Post subject: |
| Foxx wrote: |
| Bobnotch wrote: |
WooHoo!
I don't have a lathe either, but I have friends in low places.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Foxx Uncle Meat
Posted: Sun Apr 03, 2011 11:47 am Post subject: |
well,.. roughly 10 bucks per side. there used to be someone that redid them, but that was years ago, i figured it was time we all had something we all could do.
the same process is used for the lower hinge as well.
i was blessed with an extra set of hinges so i had the latitude to experiment.
the great part was once i had them apart,..i went to the parts store and started looking at the pin sets,..then asked the lady behind the counter at O-Reilly's if i could open up one as i was trying to adapt something to work,. she was most helpful in making this a success. _________________ Frank
OG JHC
59 panel
Foxx Uncle Meat
Posted: Sun Feb 07, 2016 7:45 pm Post subject: Re: Type 34 hinges redone |
| Quote: |
| Lee Hedges Admin: Totally uncalled-for posts have been removed, as has the poster. How'd he get added (again) to this group? No more of that, thank you. Anyone else acts like that gets the same. This will be a civil, helpful, positive group. |
i got booted by Lee off facebook t34 world after an argument the hinge rebuilder John Copello, now i have a history with the Lee, over some door panels he tried to scam me out of,.i was removed despite John Copello
starting the argument... just go to show, who posts to help,..
most in the t34 world really try to help,..some in the dark corners just wanna roll out the self imposed smug. _________________ Frank
OG JHC
59 panel
Posted: Sun Feb 07, 2016 8:12 pm Post subject: Re: Type 34 hinges redone |
| Foxx wrote: |
| Quote: |
Hey Frank! Long time no see. How's it going? How's the 34?
Are you still rebuilding hinges?  _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
Those who can- do.
Foxx Uncle Meat
Posted: Sun Feb 07, 2016 8:31 pm Post subject: Re: Type 34 hinges redone |
hey Tram,..just redid the ones i had..not doing much on the 34 right now as work has me swamped.but house and cars are paid for, so its a plus. _________________ Frank
OG JHC
59 panel
HenrikL Samba Member
Posted: Mon Feb 08, 2016 2:51 am Post subject: Re: Type 34 hinges redone |
If you want to keep your Type 3 clean, i.e. only metric stuff on it, Porsche 911 uses 8 mm pins and bushes which look very much like those in the pictures in this thread.
The Porsche bushings are also reamed after installed in the hinge for a 100% fit. |
Posted: Mon Feb 08, 2016 3:16 pm Post subject: Re: Type 34 hinges redone |
| Tram wrote: |
| Foxx wrote: |
| Quote: |
Hey Frank! Long time no see. How's it going? How's the 34?  |
Agreed, long time no hear. So, how's going? Welcome back. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Mon Feb 08, 2016 3:38 pm Post subject: Re: Type 34 hinges redone |
| Foxx wrote: |
| Quote: |
most in the t34 world really try to help,..some in the dark corners just wanna roll out the self imposed smug. |
To be honest, I expected myself to have been kicked out of T-34 World years ago (I'm not on facebook either ), back when I was doing my T-34. My biggest problem, was I couldn't get answers when I needed them. But then, I was moving along on my project too quickly, and others on there hadn't gotten that far in their years of ownership. The big thing that bummed me out, was a year or 2 later, people would ask the same questions, and suddenly the answers appeared.
To be honest, I found the good people of the Samba Type 3 Forum much better help, as they wanted to see me progress. Also T-34.com (the T-34 registry) helped quite a bit too, as the archives still had a ton of info in them. But, the biggest help came from being on that forum, and having a conversation with Scott Taylor and Simon Kelley, and finding out that he (Simon) didn't know that the T-34 got several different sets of upper door seals thru the years, and that his were the 66 thru 69 style that he had made. That was the biggest headache I had with the car during assembly, and no one had gotten that far on their early car to find out his upper door seals DON'T work on early cars. It was Scott who helped me figure that one out. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
