unibagel Samba Member
Joined: December 02, 2004 Posts: 528 Location: Bflo, NY
Posted: Tue Apr 05, 2011 7:04 am Post subject: My Westy trailer build thread |
]Not sure if anyone here is interested but I’m building a small trailer for my Westy to store misc. camping equipment on one side and have a mini kitchen on the other. I started the design phase of the project for fun and since I’m a Certified SolidWorks Professional (CSWP) I did the layouts for the design in SolidWorks. I’m going to pickup the wood next week and start the build
Rad SolidWorks image...
Uploaded with ImageShack.us
There is a trailer frame in there , I swear!
T1 by unibagel, on Flickr
Beer Holder!
T2 by unibagel, on Flickr
T3 by unibagel, on Flickr
Old Deck removed (& loose suspension bolts tightened. Yikes!)...
T5 by unibagel, on Flickr
Wheels off, primer going on...
T6 by unibagel, on Flickr
T9 by unibagel, on Flickr
First coat of matte black paint...
T11 - Matte Black by unibagel, on Flickr
T10 - Matte Black by unibagel, on Flickr
Getting ready for some Wurth Silver Wheel Paint...
T7 - Rimz Yo by unibagel, on Flickr
Painted and Clear Coated...
T12 by unibagel, on Flickr
T13 by unibagel, on Flickr
building the frame...
T14 by unibagel, on Flickr
The planz...
T17 by unibagel, on Flickr
Sides going on...
T18 by unibagel, on Flickr
T19 by unibagel, on Flickr
T20 by unibagel, on Flickr
T21 by unibagel, on Flickr
Frame w/super cool westy in the background!
T22 by unibagel, on Flickr
Taking Shape!
T23 by unibagel, on Flickr
T24 by unibagel, on Flickr
Wheels look better in Wurth Silver, eh?
T25 by unibagel, on Flickr
Shelves going in...
T26 by unibagel, on Flickr
T27 by unibagel, on Flickr
Shelves
Staining the kitchen side...
...and the storage side...
T28 by unibagel, on Flickr
T29 by unibagel, on Flickr
T30 by unibagel, on Flickr
Artsy B&W
T31 by unibagel, on Flickr
Time for Poly!
T33 by unibagel, on Flickr
T32 by unibagel, on Flickr
T35 by unibagel, on Flickr
Decided to Stain and Poly the whole inside for easy cleanup later...
T36 by unibagel, on Flickr
1st Layer on Bondo to even out the surfaces...
Bondo I by unibagel, on Flickr
BondoII by unibagel, on Flickr
Bondo IV by unibagel, on Flickr
Better than Bondo!!
Wood Putty by unibagel, on Flickr
Primer and Wood Putty by unibagel, on Flickr
Doors Cut and mounted...
More Primer and Wood Putty by unibagel, on Flickr
Passed the trailer inspection:
Passed the Trailer Inspection by unibagel, on Flickr
Mounted on the trailerframe (using Genuine VW Starter bolts!) LOL.
Mounted by unibagel, on Flickr
Trial Run with Coleman Stove:
Coleman Stove Tria Run by unibagel, on Flickr
Coleman Stove Trial Run II by unibagel, on Flickr
Storage Side by unibagel, on Flickr
Storage side II by unibagel, on Flickr
Storage Side III by unibagel, on Flickr
Killed my saw!
Smokin! by unibagel, on Flickr
The Door Locks...
_IGP4732 by unibagel, on Flickr
_IGP4733 by unibagel, on Flickr
Self Stick gasket
_IGP4731 by unibagel, on Flickr
Grab Latches
_IGP4730 by unibagel, on Flickr
Filled up and camping!
Fully Loaded by unibagel, on Flickr
vwgrl1999 Samba Member
Joined: November 20, 2008 Posts: 153 Location: Central PA
Posted: Tue Apr 05, 2011 7:24 am Post subject: |
How high off of the ground will the right side hatch be when opened? You may want to make sure that it's high enough that you don't have to stand there bent over the whole time you are prepping lunch/dinner/etc. as it could lead to one heck of a backache!
Other than that, it looks great! Very functional, nice design. I will be interested to see your progress. _________________ Current VW's:
1987 Vanagon GL
1999 New Beetle
Past VW's:
1980 Westy
1971 Beetle
1974 Super Beetle |
buildyourown Samba Member
Posted: Tue Apr 05, 2011 7:34 am Post subject: |
I would put in a water tank and 10# propane tank for meal prep. A sink would be handy to. A simple stainless bar sink with a 5gal slip bucket underneath would be cheap and easy.
Check out expedition trailers for ideas. Those guys know how to travel. I'll post a link when I get to work.
I would also make it all metal construction. It's not any harder than building with wood if you are starting from scratch. |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Tue Apr 05, 2011 8:00 am Post subject: |
As far as sanding down the plywood and painting it to match your westy I wouldn't put too much time into sanding it because it will not look all that great in a couple years time unless you have a place to store it indoors. Some heavy duty oil based primer if you can find it and a top coat mixed to match your westy color (both applied with a roller) is the best use of time and money IMO.
buildyourown wrote: |
I've worked with both for some time and metal is IMO significantly more of a pain in the butt to deal with primarily because cutting it is so much more time consuming than cutting wood. _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Tue Apr 05, 2011 8:51 am Post subject: |
I really like the idea and have been thinking of something along this line as the kids get bigger and we run out of room in the Westy.
I agree with JackBombay.. build with wood.. which will be easier to work with once it is assembled. Because, no doubt, there will be things you'll want to modify.
Do a little reading on wooden boat finishes for fairly tough all-weather finishes.. And then have a local marine canvas or awning shop sew up a cover. Shouldn't cost but a couple hundred to fab one out of sunbrella and it will save your finish maintenance at LEAST that amount over time.
Once you get the design dialed in wood, you can always go back and build new from steel and/or aluminum.
There are 1000s of wood trailers traveling the by-ways.
And a few kits of various materials to build "new". _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Pascal Samba Member
Joined: January 13, 2006 Posts: 825 Location: Fredericton, NB, Canada
Posted: Tue Apr 05, 2011 9:09 am Post subject: |
I have the same Harbor Freight trailer kit and I'm planning on using MDO plywood for the exterior. MDO is used for some DOT highway signes in New Brunswick and is more weather resistant that plywood. It also has a smooth finish for painting. _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
Well, my wife says that's a good height for the counter, so that works for me! LOL. I'm sticking with wood for now as the total cost for me is under $200 for everything.
I'll make the box as smooth as possible before the paint. After paint I was thinking of a nice thick clear coat. IDK. Still formulating the plan for that...
Thanks all for the encouragement and suggestions!! You rock.
Chris |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 762 Location: Langley, BC, Canada
Posted: Tue Apr 05, 2011 9:18 am Post subject: |
If you haven't already, you may want to peruse Expedition Portal or ih8mud. There's quite an active off/on road small camping trailer section on both. Lots of things have been tried and documented.
But, of course, don't leave us hanging
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
Posted: Tue Apr 05, 2011 9:30 am Post subject: |
jackbombay wrote: |
I've worked with both for some time and metal is IMO significantly more of a pain in the butt to deal with primarily because cutting it is so much more time consuming than cutting wood. |
I'm much faster in metal, because that's what I do all day.
My point is, if you need to aquire some tools anyways, and you aren't very good at wood, then metal isn't a stretch. Cutting 1/8" alum sheet with a circular saw is just as fast as cutting plywood. Just wear your ear plugs. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6245 Location: Portland OR
Posted: Tue Apr 05, 2011 9:54 am Post subject: |
I would be carefull of compartmentalizing it too much. Making a lot of special compartments seems cool, but limits the flexibility and versitility of the trailer. I think at max I would create two or three compartments. The size of what you want to carry can change easily. It's better to have bigger compartments to hold a variety of items. Your design looks really cool however. I like the fold down shelf. I have a similar size open trailer that I use.
One side note, that size trailer is nearly impossible to back up. I usually have to unhitch it and move it by hand.
_________________ 89 Westy 2.1 Auto |
1621 Samba Member
Posted: Tue Apr 05, 2011 11:25 am Post subject: |
Very cool design, though I tend to think like PDX in this case - allow for some flexibility. Perhaps make the interior compartments removable, and have some other access points besides the two sides. A removale top perhaps?
What is the target weight you are looking for? The wood + trailer + gear can add up pretty quickly. Good luck, watching this one with interest. _________________ '85 Westy |
bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1375 Location: Halifax, N.S.
Posted: Tue Apr 05, 2011 11:41 am Post subject: trailers |
It's scary that so many of you guys have similar ideas. I too wanted to make my little trailer into a kitchen/storage/bike/kayak/carry all unit. I talked it over with my Dad one day extensively. He came up with the solution pretty much right away..."Buy a hardtop camper." hehe.
It's a great idea! Plywood painted with the correct paint will last a very long time. Marine grade plywood even longer. A very fun project indeed. You could even top it with a set of yakima racks! Bonus!
Brian. _________________ 86 Vanagon GL Westfalia 2.1
18 Nissan Frontier Pro 4X
19 Honda Civic Hatchback
A little rudeness and disrespect can elevate a meaningless interaction to a battle of wills and add drama to an otherwise dull day. Calvin and Hobbes. |
Posted: Tue Apr 05, 2011 11:52 am Post subject: |
Yeah, I had a thought that I could attach the car top hauler to the trailer if I ever needed MORE room being that the top is flat.
I'll take the advice given on the storage compartments and not permantly affix them. I just didn't want stuff sliding around. Maybe plastic bins would work well to contain stuff.
Someone mentioned a sink and I thought of that but our campsite is already equipped.
Thanks all, I'm so happy that my little project has generated so much interest. I'll keep you posted as things develop. I hope to get the wood next week... |
vwlovr Samba Member
Joined: May 21, 2006 Posts: 1122 Location: on the road
Posted: Tue Apr 05, 2011 12:08 pm Post subject: |
love it, i agree u should add propane to the mix, not sure if your trailer has the A frame at the front but you could mount one there. then you can run a hose to a stove and a lantern or something.
water would be good as well, but maybe that could just be a jug with a tap that sits over the kitchen shelf.
as someone who full times in an RV i'd also agree that you don't need a lot of special compartments. instead i would make shelves that hold plastic bins with lids and in the large compartment i would make like 3-4 shelf supports so you can adjust the height of a shelf inside, that way you don't have to pile everything into on big area.
as for the finish, i'd get some thin bright aluminum treadplate cut to the top and maybe trim with aluminum L bar, or just leave it as the plate and just file the sharp corners. just lay the plate on the wood and apply with construction adhesive, then paint the sides. that would hold up to weather a bit better i think and it would look cool.
also, for the kitchen area definitely get some super thin stainless for your work surface, i did this in my RV in several places and it rocks. 22 gauge is plenty, just go to a metal supply and have them cut it for you, then glue it on with construction adhesive. it would cost like $40 or so, but totally worth it.
the only other thing i'd add if i were building it for me is a bike rack for the top. |
JED THE SPREAD Samba Member
Joined: July 14, 2009 Posts: 626 Location: South London UK
merleandsarah Samba Member
Joined: February 13, 2011 Posts: 10 Location: SEATTLE
Posted: Tue Apr 05, 2011 12:26 pm Post subject: |
Take a look at ADVENTURETRAILERS.COM. They are overbuilt and over priced, but have layouts like like you are doing. They have some really cool ideas. Keep us posted, with photos of course. |
Posted: Tue Apr 05, 2011 12:44 pm Post subject: Re: trailers |
bjrogers86auto wrote: |
Plywood painted with the correct paint will last a very long time. Marine grade plywood even longer. |
I have been using door-skins from Home Depot.. cheap.. water resisitant glues,.. Make sure you get the sheets intended for exterior use.
MUCH less expensive than marine ply.. and as a thin skin ply, it is easy to bend over curves. gives you some design flexibility and opportunity.
Wieghs less than thicker plys, too..
If you're frame is built to support it, the stuff would be a low cost, low wieght option.
Give it a look.
Similar marine grade stuff can be had in various exotic hardwoods, but PRICEY!
Just think.. A nice varnished finish!...
Hahaha.. all the torture of owning and building a fine wooden boat!
Seriously, though. Exterior door skins. _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
Posted: Tue Apr 05, 2011 1:13 pm Post subject: |
Why take up space (and weight) with things that are already on the van? Perminantly mounted propane and water seems redundant. So does a sink, especially in a 3'x4' trailer. The purpose of the trailer is to carry extra things that aren't already in the van. Throw a 5 gal jug in there if you need it for an extended stay. _________________ 89 Westy 2.1 Auto |
Posted: Tue Apr 05, 2011 1:17 pm Post subject: trailers |
Quote: |
Hahaha.. all the torture of owning and building a fine wooden boat! |
No chance of it sinking though!
1621 Samba Member
Posted: Tue Apr 05, 2011 1:29 pm Post subject: |
PDXWesty wrote: |
Why take up space (and weight) with things that are already on the van? Perminantly mounted propane and water seems redundant. So does a sink, especially in a 3'x4' trailer. The purpose of the trailer is to carry extra things that aren't already in the van. Throw a 5 gal jug in there if you need it for an extended stay. |
He's got a weekender, but I do see your point.
I like the flip down shelf a lot, even with a full camper. It's nice to have the extra work space. Bike racks on top is a clever idea as well. You could go crazy and build something with all the gadgets and features of some of those adventuretrailers (very cool BTW), but it sounds like this is supposed to be a much more modest project.
A bigger question is how you intend to keep the elements out. Strong winds from the road mixed with a bit of rain tends to get everything wet unless water tight. _________________ '85 Westy |
