vgajames Samba Member
Posted: Sat May 07, 2011 7:44 pm Post subject: Empi Thing Exhaust |
Anybody run one of these Empi exhaust? Wondering if it sounds good and would be good on a motor with like 1776 dual carbs.
Or other suggestions for less restrictive thing exhaust.
Will be for a 74 with heater box's...
yellow73kubel Samba Member
Joined: August 17, 2008 Posts: 789 Location: Columbia, SC
Posted: Sat May 07, 2011 8:01 pm Post subject: |
I have the Tri-mil version of that exhaust on my 1600. Overall, it is an excellent system. It is a little on the loud side, but gives a distinctive throaty sound rather than being tinny and obnoxious. Picture a quieter big block with the smoother VW noise added.
It shouldn't choke out your 1776 unless you have a particularly aggressive cam and valve train.
I've never looked at the Empi version of this exhaust, so I can't tell you what to expect quality wise. You may or may not run into fit issues. I will say the Tri-mil goes on perfectly and is quite well built.
And.. Unless you go with ceramic coating, you will need to get rid of the shipping paint. It will sand off very easily. I'd recommend either VHT "Flame Proof" header paint or peanut oil (it actually works very well). |
Posted: Sat May 07, 2011 9:03 pm Post subject: |
| yellow73kubel wrote: |
Are Tri Mil made still available? |
dreadnotmusic Samba Member
Joined: March 04, 2003 Posts: 880 Location: Guam, USA
Posted: Sat May 07, 2011 9:05 pm Post subject: |
I have the Empi version. Sounds really throaty, even on my 1600 single port. The paint is crap though, for real. _________________ 66 Riviera |
Posted: Sat May 07, 2011 9:20 pm Post subject: |
| dreadnotmusic wrote: |
| I have the Empi version. Sounds really throaty, even on my 1600 single port. The paint is crap though, for real. |
So the ceramic version would probably be a go?
Seems like for thing performance exhaust its these are $400 or more
for others on market... |
Posted: Sat May 07, 2011 9:29 pm Post subject: |
| vgajames wrote: |
Personally, I wouldn't waste the money on the ceramic, nor would I trust Empi to do the coating any justice. Just order the black one and strip/paint it before install. Than you know it's gonna last. _________________ 66 Riviera |
dells68 Samba Member
Joined: January 09, 2008 Posts: 217 Location: Virginia
Posted: Sat May 07, 2011 9:33 pm Post subject: |
I bought a used EMPI ceramic version. It fit quite well. I haven't had a chance to start it yet, so I don't know about the sound. The coating is starting to show a few thin spots of the bottom side, but for the price I think it's great - if you're on a budget like me
Dell |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2013 Location: Athens, TN
Posted: Sat May 07, 2011 9:57 pm Post subject: |
I recently purchased the Empi version(on a budget too), and I went for the Ceramic coating. I have reservations on Empis quality of ceramic, but I figure it'll last long enough to make it worth the extra cost($60 additional). I can always get it recoated locally if it begins to wear/fail. I had my Heat boxes ceramic coated locally, in a cast grey tone.
Fit is good on the Empi system, and the ceramic finish seems applied decently. I haven't installed it yet, as the body is in for metal work/paint, but i'll have it in and going in about 2 wks.
Hope this helps! _________________ '74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember |
Lettuce Samba Member
Posted: Sat May 07, 2011 11:38 pm Post subject: |
My next exhaust is going to arrive bare metal, I will season it with peanut oil.
I considered the the empi exhaust, but settled on the CB hideaway. I wasn't thrilled about the poor scavenging with the empi system, but I dont think ti would have been an issue  |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Sun May 08, 2011 1:21 am Post subject: |
| i got the trimil version. yeah, throaty. i got the painted version. paint was gone first day. im gonna sand it and season it with peanut oil also. i like that it is compact and fits the bumper holes. |
Posted: Sun May 08, 2011 6:54 am Post subject: |
| GI Joe wrote: |
Hope this helps! |
Nice looking motor....exhaust looks good on it.  |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80160 Location: Sneaking up behind you
Posted: Sun May 08, 2011 6:58 am Post subject: |
I would suggest mounting the coil the other way. it's it's oil filled the terminals should be at the bottom. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
GI Joe Samba Member
Posted: Sun May 08, 2011 8:47 am Post subject: |
| Glenn wrote: |
I would suggest mounting the coil the other way. it's it's oil filled the terminals should be at the bottom. |
I'd like to know the reasoning for this? What's the purpose of the oil? Just curious!
I trust your knowledge, so I'll flip it around, thanks for your tip!
Oh, and Thank you VGAJAMES! It's a few months of working on it, when I could. It's sitting quietly under a sheet in the corner, waiting to be reunited with the rest of Our Thing! _________________ '74 Thing, "Our Thing"....
'71 Beetle RPU
www.NLEOMF.com
wbrown45 Samba Member
Posted: Sun May 08, 2011 10:04 am Post subject: |
I got some paint stripper from Home Depot that literally took the paint off as I brushed it on my TriMil Thing exhaust. I used VHT exhaust paint, which stays on. I really like this system. _________________ OK Thang |
Posted: Sun May 08, 2011 11:19 am Post subject: |
| Glenn wrote: |
Usually if it is oil filled the terminals should be at the top. According to the MSD webpage, the oil filled blaster Blaster 2 :
"Do not mount this coil horizontally or upside down. The oil will not sufficiently cover the windings for cooling purposes and the coil may overheat."
Epoxy filled coils like the stock one and "good" blue coils can be upside down or whichever other way. |
Bohdan Samba Member
Joined: November 21, 2007 Posts: 151 Location: Venice, Florida
Posted: Mon May 09, 2011 5:33 am Post subject: |
| I am too looking at TRi-Mil ceramic coated. Is it possible to polish ceramic coated exhaust systems to a glossy lustre without taking the coating off? |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5225 Location: Richmond, VA
Posted: Mon May 09, 2011 6:21 am Post subject: |
| GI Joe wrote: |
| Glenn wrote: |
Oh, and Thank you VGAJAMES! It's a few months of working on it, when I could. It's sitting quietly under a sheet in the corner, waiting to be reunited with the rest of Our Thing! |
Every AC VW I ever had the coil was mounted with the terminals at the bottom. _________________ Ghia Owner Emeritus |
Posted: Mon May 09, 2011 6:24 am Post subject: Re: Empi Thing Exhaust |
| vgajames wrote: |
I have had a couple of EMPI exhausts and in my opinion their products are garbage. You are looking at a year at best of normal use before the exhaust begins to fail - rust out, split seams, etc.
In the long run a good quality system will be cheaper and you won't have the aggravation of a re-install. There is a reason why the Empi product is much less expensive. _________________ Ghia Owner Emeritus |
Sidecar Sarge Samba Member
Joined: September 27, 2010 Posts: 11 Location: NE Ohio
Posted: Thu May 12, 2011 4:18 pm Post subject: |
A question:
In the posts above, the word "throaty" is used to speak of the Empi's exhaust sound. Throaty-schmoaty. The dammed thing is LOUD and I don't like it. Barring going back to the stock exhaust system, is there anything that can be done to tone the Empi system down? I was wondering about stuffing stock exhaust tips in the two outlets. Thoughts?
Tom _________________ Learn to ride hard, shoot straight, dance well and so live that you can, if necessary, look any man in the eye and tell him to go to hell. US Cavalry Manual, 1923 |
CraigInPA Samba Member
Joined: March 09, 2011 Posts: 217 Location: Norristown, PA
Posted: Fri May 13, 2011 7:25 am Post subject: |
I got the ceramic coated empi exhaust to replace a bug pea-shooter exhaust the prior owner put on the car. Installation was straightforward and everything fit up perfectly on my 73. Only glitch was the once I saw how nice the ceramic looked, I HAD to spring for ceramic J tubes, another $50, instead of leaving the original mild steel J's in there. It looks pretty nice on the car as well. I haven't had it on very long, so I can't speak for longevity.
The Empi exhaust is significantly louder than the pea-shooter bug exhaust. It's not cherry-bomb loud, but it's a louder "rumble". I wouldn't call it "throaty".
When I replace the exhaust on my 74, I will probably look for another option, as I find the noise produced by the exhaust system too loud for my taste. Younger owners coming from hopped up Hondas and Acuras would probably disagree with me, but I'm a crotchy old guy who has enough difficulty hearing that a loud exhaust doesn't help.
Craig |
