oval56 Samba Member
Joined: July 21, 2003 Posts: 1309 Location: oktoberfest maintown
Posted: Sat Mar 05, 2011 12:57 pm Post subject: |
if you have them availible, please let it me know... _________________ www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com |
joshbuchan Samba Member
Joined: April 12, 2007 Posts: 712 Location: victoria bc canada
Posted: Sun Mar 06, 2011 5:33 pm Post subject: |
Nice parts!!! if anyone can't wait for these to be ready and needs a pair of original inner skins now....I have some ribbed 54 door I will be cutting up (drivers has a pint outer skin too) let me know
josh |
Matthew Tolbert Samba Member
Posted: Mon Mar 07, 2011 7:00 pm Post subject: |
Josh, PM sent!! _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Sat May 07, 2011 8:26 pm Post subject: |
Next week I'm starting to make door panels for Bad Camberg, so if you have any wishes, it's the time now. My standard outer repair panel is 13 cm height and has Z-form for the joint. But anything else is possible.
Repair set includes inner and outer panels together with hinge support and window regulator brackets. I can spot weld those or if you like to have them separated.
_________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
oval56 Samba Member
Posted: Sun May 08, 2011 2:34 am Post subject: |
pre order needed?
pm me the price for a pair... i'm also in BC _________________ www.oval56.com
www.dbkvw.com |
Wolf1 Samba Member
Posted: Sun May 08, 2011 11:51 pm Post subject: |
Nice work Mika _________________ www.wolfparts.com |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1771 Location: Finland, Jakobstad
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed May 09, 2012 7:15 pm Post subject: |
Hebster52 wrote: |
Just got to say the quality of these parts are stunning! recieved mine this week! |
Me too! VERY nice. Excellent work Mika!
I have the split running boards as well. Those are also of the highest quality you can find. Another must have for an authentic restoration.
Thanks much. |
joel55bug Samba Member
Posted: Sun May 13, 2012 4:40 am Post subject: |
Still doing the running boards? How much and what is the time table on you processing an order of these and getting them shipped to Texas? |
Posted: Sun May 13, 2012 7:15 am Post subject: |
joel55bug wrote: |
They are available in the classifieds. They ship from the US, so as quickly as you can place your order and UPS can deliver I suppose.
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search |
Posted: Sun May 13, 2012 8:20 am Post subject: |
Thanks for the link. Just curious, in the ad it says they're for '49-51 deluxe models. Is there some differences from '51 to '52? Also, I've noticed there is no rubber on the running boards but it states they are for deluxe models. I thought the only differences on the boards was deluxes had the metal trim and standards did not. Am I mistaken, please enlighten me on what I might be missing! Thanks! |
Posted: Sun May 13, 2012 9:21 am Post subject: |
joel55bug wrote: |
You probably need this version? The difference is in the shape of the trim holes (round versus square)
http://www.thesamba.com/vw/classifieds/detail.php?id=1098325
The deluxes do have the rubber mat, but that is not being sold with the boards. It is available elsewhere. |
Posted: Sun May 13, 2012 11:06 am Post subject: |
nlorntson wrote: |
joel55bug wrote: |
So basically because mine is a '52 Standard Model it really doesn't matter cause all I'll need to do is locate the rubber mat? |
Posted: Sun May 13, 2012 12:01 pm Post subject: |
joel55bug wrote: |
If you have a standard then the ad says you need
http://www.thesamba.com/vw/classifieds/detail.php?id=1098320 |
Posted: Sun May 13, 2012 2:22 pm Post subject: |
Ok, thanks again guys for all the help! I'll be working on getting mine in the next couple of weeks! |
PASHN8 Samba Member
Joined: January 30, 2011 Posts: 152 Location: Melbourne, Australia
Posted: Sat Feb 02, 2013 5:13 am Post subject: |
virtanen wrote: |
Hi Mika,
Do you have these available as above inside/outside door repair sections for '54 Oval Beetle, in stock?
Dino. _________________ www.dinography.com.au - Dino!
1957 11-Window Split Bus
1954 3-fold Sunroof Oval Beetle
*** Looking for '56 Porsche T1 356A 1300 engine no. 22373 *** |
Evil Dan Samba Member
Joined: March 09, 2012 Posts: 20 Location: Liverpool UK
Posted: Tue Apr 30, 2013 3:27 am Post subject: |
Do you make them with the correct support bracket for a 54 oval?
Its a different size and possition to the split window ribbed door! |
