Which Big Brake kit. Van Cafe or Smallcar.
Ryan Keating
Ryan Keating is offline
PostPosted: Wed May 11, 2011 8:01 pm    Post subject: Which Big Brake kit. Van Cafe or Smallcar. Reply with quote
Looking at big brakes for my svx westy 2wd. Just want to know how they have worked in your van. Or just your opinion on them.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed May 11, 2011 8:07 pm    Post subject: Reply with quote
Aren't those two kits essentially the same?
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
hdenter
hdenter is offline
PostPosted: Wed May 11, 2011 8:11 pm    Post subject: Reply with quote
Take a look at the thread on the Jaguar brakes. It is almost bolt on if you don't mind getting dirty. I would link it, but I am on my phone.
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
Oceanpro907
Oceanpro907 is offline
PostPosted: Wed May 11, 2011 9:26 pm    Post subject: Reply with quote
I choose VC big brake kit. My impression was that they fit more wheels than the small car kit. the Small car kit has dual pistons and the VC has a single.
Williamtaylor33
Williamtaylor33 is offline
PostPosted: Wed May 11, 2011 9:32 pm    Post subject: Reply with quote
I would give van cafe my business
89 Bostig powered syncro westy
Jedi
Jedi is offline
PostPosted: Wed May 11, 2011 9:46 pm    Post subject: Reply with quote
I think Gowesty should be included in the topic too
http://www.gowesty.com/ec_view_details.php?id=23124&category_id=&category_parent_id=
1961 Westfalia SO23 Mango Green/Seagull grey
1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro
ProvoCyclist
ProvoCyclist is offline
PostPosted: Wed May 11, 2011 9:54 pm    Post subject: Reply with quote
Ryan, i'm using the Van-Cafe kit, its all Audi-based, the A4 B5 chassis if i remember right. Ive been really happy with it, i can get parts from my local import parts shoppe. Umm, i dont really know what else to tell ya.
Ninja edit: Oh yeah, its all a kit from Euro Spec Sport, [url]eurospecsport.com[/url], they also have some really nice looking diesel conversion kits too.
Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Savanna Beige Metallic LH1V.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A
syncrodoka
syncrodoka is offline
PostPosted: Wed May 11, 2011 10:39 pm    Post subject: Reply with quote
The problem with the GW kit is that replacement parts have been spotty in the past(like all SA parts).
The smallcar kit is a premade G60 dual piston kit- http://www.syncro.ca/tech/audibrakes.htm I made my own kit and the calipers are huge and hard to fit rims over but replacement parts are easy to come by.
The VC kit is a single piston kit that audi based as well but is supposed to fit more rims.
madspaniard
madspaniard is offline
PostPosted: Wed May 11, 2011 10:48 pm    Post subject: Reply with quote
Van Cafe started selling the South African big brake kit (same offered today by GoWesty, 275mm rotor). After a while, Van Cafe stopped selling the South African kit and now offers the Audi big brake kit (288mm rotor).
Alaric.H
Alaric.H is offline
PostPosted: Thu May 12, 2011 5:22 am    Post subject: Reply with quote
2 pistons are better at stopping than one and SA brakes will not stop a SVX fast enough.
RGS Paul
RGS Paul is offline
PostPosted: Thu May 12, 2011 6:12 am    Post subject: Reply with quote
The rotors on the VC kit are actually a little larger then those on the SC kit, about 10 mm in diameter. I think the pads might be a little larger on the G60's that SC sells though. The VC kit will develop more stopping torque while the SC kit will resist fade a little better. All in all I think they are pretty comparable, parts are available for both and there is a good selection of pad options. You can upgrade the guide pins in the VC calipers to improve pedal feel some more, the design of the G60's is different so this isn't an option (not a big deal).
My Dad put the VC kit on his Westy Syncro and loves them, much better feel according to him. He did have a tiny bit of clearance problems on one corner and had to grind the back of the caliper down slightly, this was minor though. I'm putting together a G60 kit from junkyard parts, they look pretty substantial and I'm looking forward to testing it all out.
To make a decision I'd look at the cost of replacements and base it off that. Performance wise I think they are indistinguishable, it is just how much do you want to pay, who do you want to send your money to, and do you think there is an advantage to the 2-piston semi-floating (only way I can describe the G60, it is a floating design though) caliper versus the 1-piston floating caliper.
The absolute best option. Wilwood 4-piston monoblock calipers on Audi rotors. I'll go this route when I have more money to burn and I can afford to have the van waylaid for a few weeks while I design parts.
Lots to consider,
Paul
'87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman
RGS Paul
RGS Paul is offline
PostPosted: Thu May 12, 2011 6:14 am    Post subject: Reply with quote
Oh, one more thought. I wouldn't put the SA kit on for the reasons syncrodoka mentions, you aren't necessarily going to be able to get parts for them in 6 months, 12 months, 4 years… There are lots of Audis out there to support future part manufacture and the Audi's the kits are based on were made in to the mid/late 90's, relatively new stuff. I like the piece of mind of that.
Paul
WestyBob
WestyBob is offline
PostPosted: Thu May 12, 2011 11:41 am    Post subject: Reply with quote
I installed the VanCafe big brake kit on my westy weekender syncro many years ago and they work very well .. very happy.
At the time I compared this with SC's offering but chose VC. The dual SC piston arrangement is attractive but I've had no problems slowing quickly and noticably with the VC jobs.
Ryan Keating
PostPosted: Thu May 12, 2011 8:16 pm    Post subject: Reply with quote
Thanks for all the input. I think the VC big brakes are the winner. I try to buy all my parts from them if I can. They have always taken care if me. Just wanted more opinions. Plus the cookies always make me happy. I think I will order them right now along with some lift springs.
beelzibus
beelzibus is offline
PostPosted: Sat May 14, 2011 1:11 pm    Post subject: Reply with quote
So the big question I have is what are the Audi calipers used in the Vancafe 288mm kit, are the carriers modified in any way, if so how?
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat May 14, 2011 3:01 pm    Post subject: Reply with quote
The caliper carriers used in the 288mm single piston kits are custom made for use in the Vanagon kit. New castings with more metal in the mounting bolt hole areas and bigger holes to match the huge caliper bolts used in Vanagons.
People who do it themselves are drilling out the used Audi carriers at the bolt holes and using spacers to set the caliper offset to match the rotor. The new holes are not on the same centers as the old small holes but overlap them almost.
Mark
r39o
Samba Polizei
r39o is offline
PostPosted: Sat May 14, 2011 5:58 pm    Post subject: Reply with quote
Been using these brakes now on a few vans including SVX ones:
http://www.thesamba.com/vw/forum/viewtopic.php?t=160055
G60 calipers and Mercedes 303mm rotors.
Drum brakes in the back...no need for discs in the back.
Stop just fine. No...GREAT!
Ryan Keating
PostPosted: Sat May 14, 2011 6:02 pm    Post subject: Reply with quote
303mm rotors. Wow you must be doing nose wheelies. My VC brakes are on the way but I may do some reading on that. Must feel great.
r39o
Samba Polizei
r39o is offline
PostPosted: Sat May 14, 2011 7:02 pm    Post subject: Reply with quote
Not a lot of nose dive. In fact, no more than normal, I feel. Of course, with great power comes great restraint too. Panic stops don't lock up.
I have a BMW booster that I may try, because the pedal could work a bit easier (always!)
Team WorldTour
Team WorldTour is offline
PostPosted: Sat May 14, 2011 9:52 pm    Post subject: Reply with quote
I have been driving VWs for many years, and I must say; since I put the VC brakes on Domo, I have confidence in my brakes for once! It stops like I think it should!
FWIW: Go with the VC kit. You will not be sorry!
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
Page 1 of 7
