2-way windshield washer nozzles that fits - edited
Page: Previous  1, 2, 3, 4, 5
j_dirge
j_dirge is offline
PostPosted: Wed May 25, 2011 7:48 pm    Post subject: Reply with quote
K58 wrote:
Thanks Guy's
that's what I thought
Any other items I should address with the dash out?
Have you tried a coat hanger?
The squirter line feeds from the driver side.. Should not be at all difficult to pull it close to top and then grab with some hemostats (sp?)
I don't think it can fall down very far.
I'd work that wire a good amount of time before I'd resort to pulling the dash.
Some light directed from below (glove box open) may help you see a little down inside, too.
-89 GL Westy, still humming along under the power of a used "WBXer of mystery"
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
K58
K58 is offline
PostPosted: Wed May 25, 2011 8:30 pm    Post subject: Reply with quote
j_dirge wrote:
K58 wrote:
Thanks Guy's
thank you X10
I tried for awhile from the outside with a hanger but your idea of the hemostats (correct sp) is excellent
I actually have a pair Smile
JeffRobenolt
JeffRobenolt is offline
PostPosted: Thu May 26, 2011 7:31 am    Post subject: Reply with quote
I just got done putting my van together after painting and the hardest part was fishing out the washer lines. I used a hemo on the passenger side.
With the gauge cluster out I could snake my arm in for the drivers side.
Jeff
**For Sale...Modified Subaru Wiring Harnesses**
www.facebook.com/jeffrobenolt
[quote="jfats808"]Most, some, few is not all. You can always learn something from everyone , even the fool.[/quote]
K58
K58 is offline
PostPosted: Fri May 27, 2011 1:26 pm    Post subject: Reply with quote
I got the new nozzles on but only after unbolting the wiper motor on the passenger side, moving it out of the way enough to have access to the small space just under the windshield. After positioning the hose and using a flashlight I was able to fish it out with the Hemostats. Great suggestion!!
A tip for anyone doing this mod is to get a Hemostat locked onto the washer tube while removing the nozzle. It will make your life a lot easier. Wink
Thanks to everyone's suggestions!
kuleinc
kuleinc is offline
PostPosted: Sat Jul 21, 2012 10:17 pm    Post subject: Reply with quote
did we decide which nozzles are best? The 50 euro ones? The Porsche ones from pelican parts? I can't stand the stupid OE ones...
Check out our Our youtube channel: Https://www.youtube.com/channel/UC-EbskIxNm6SYzsq4ugG81A and our Instagram: https://www.instagram.com/krisysparadise/
http://www.thesamba.com/vw/forum/viewtopic.php?t=496946 1987 VW Vanagon Westfalia with 1.8T
View user's profile Send private message AIM Address Yahoo Messenger Classifieds Feedback
K58
K58 is offline
PostPosted: Sat Jul 21, 2012 10:49 pm    Post subject: Reply with quote
All I can tell you is that the Porsche nozzles I got from Pelican work great. It took a bit of trial and error to get them positioned just right but they have worked flawlessly since. 1000X better than OE!
http://www.pelicanparts.com/cgi-bin/smart/more_inf...1976-85%29
Westy HID Projector Retrofit
kuleinc
kuleinc is offline
PostPosted: Sat Jul 21, 2012 10:50 pm    Post subject: Reply with quote
I'll prolly get those then, I know what you mean about adjusting nozzles, it can be a pain, but is SO worth it when they are right!
insyncro
Banned
insyncro is offline
The triple nozzle units are plug and play.
I have had them for years and love them.
The only limiting factor seems to be price for some.
Since owning my sets I have heated them and the lines.
A really treat to drive with in winter weather.
designer
designer is offline
PostPosted: Fri Feb 21, 2014 10:19 pm    Post subject: Reply with quote
[quote=
alistair[/quote]
I need a new dichtung. Very Happy My dichtung leaks. The Fullrohr just isn't as tight going into the Dichtung as it used to be. Shocked It's been stretched out over time. I guess with 27 years of useage it just gets that way. Maybe my Fullrohr has just gotten smaller? Embarassed
Just replaced my pumpe fur Scheibenwisch Und Washanlage and man does that ever make a difference. Is there a way to adjust the Dusentralger mit Spitzduse's? I'm talking the stock Dusentraglers, though.
My new Pumpe shoots the fluid up to my sunroof. in 30degree weather on the highway.
I've thought about changing to a two prong approach, but i'm getting good distance, it's just the accuracy that needs attention. Laughing
designer
designer is offline
PostPosted: Fri Feb 21, 2014 10:21 pm    Post subject: Reply with quote
[quote=
alistair[/quote]
singler3360
singler3360 is offline
PostPosted: Fri Feb 21, 2014 10:36 pm    Post subject: Reply with quote
Designer,
At least you don't have a bent Winkelstuck, right?
syncrodoka
syncrodoka is offline
PostPosted: Fri Feb 21, 2014 11:19 pm    Post subject: Reply with quote
VC often stocks the dichtung but they are out of stock right now http://www.van-cafe.com/home/van/page_511_1374/front-wiper-reservoir-grommet.html
If you need a new one pronto like you are going to have to get it from over the pond.
http://www.vwbusshop.de/251955489
dhaavers
dhaavers is offline
PostPosted: Sat Feb 22, 2014 8:13 am    Post subject: Reply with quote
The leak at the dichtung is the improved "FULL" indicator for the tank.
Stop filling when your shoes get wet... Wink
The washer nozzles themselves are adjustable. There is a small metal ball which
rotates in the nozzle - just use a pushpin or needle to aim it however you like.
86 White Westy Weekender
"The WonderVan"
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Feb 22, 2014 10:15 am    Post subject: Reply with quote
I'm not sure if it's been mentioned in this thread, but I recently noticed that LR Discovery rear wiper squirters are dual outlet and stand off a bit from the body. Might be a decent option if a part number and source can be identified.
Casey--
Volkswagens powered by Volkswagen
'89 Bluestar TDI
'01 Weekender VR6
Oly Bulli
kalispell365
kalispell365 is offline
PostPosted: Sat Feb 22, 2014 2:39 pm    Post subject: Reply with quote
I think sometimes people think spending a ton on a simple item somehow gets them a "superior" product Rolling Eyes
These pelican nozzles are also made by SWF,and look great,work even better!
These are the ones to get,IMHO.
madspaniard
madspaniard is offline
PostPosted: Sat Feb 22, 2014 4:47 pm    Post subject: Reply with quote
I'll bite since I'm the only one that has admitted here to buying the ones from Germany. To set the record straight, the 50€ ones are three-way nozzles. The German two-way nozzles that I bought are 17€. The Pelican are two-way nozzles. At the time, I bought other items not available in NorthAmerica like headlight guards so I didn't specifically pay for shipping of the nozzles. How much are the Pekican with shipping? Not really that big of a difference. I actually like the looks of the German better but that is just my taste. I would expect both to work about the same. No rocket science here.
If you are not purchasing other stuff from the German website then I don't think it makes sense to buy the German ones, go with the Pelican (unless you don't like them)
DeadSetMonkey
DeadSetMonkey is offline
PostPosted: Sat Feb 22, 2014 6:19 pm    Post subject: Reply with quote
I got these:
http://t3technique.com/accessories/dual-nozzle-windshield-squirters/
I almost lost the passenger side line... but gladly i didn't...
they're a bit of a chore to aim, but i finally got them dialed in.
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins
K58
K58 is offline
PostPosted: Sun Feb 23, 2014 8:55 am    Post subject: Reply with quote
Revisiting this post after noticing that my Jeep has a "spray" nozzle that works superior to anything I've seen. What about a spray type nozzle < $50 for a Vanagon? Ideas?
Page 5 of 5
