"What did you do with your Thing today"?
Page: Previous  1, 2, 3 ... 39, 40, 41 ... 83, 84, 85  Next
Semper_Dad
Semper_Dad is offline
PostPosted: Thu Jun 16, 2011 12:02 pm    Post subject: Reply with quote
mikeyj007 wrote:
I ordered a custom front license plate and got it in the mail today. I was a bit disappointed to discover that the "chrome" frame is really just cheap plastic universal frame that won't work. Does anyone know where I can order a metal license plate frame? Do they makes ones that don't cover up the outer ring on the plate?
All the euro frames I've seen are plastic. Why doesn't the frame work? I put some strong (neodymium) magnets between the plate and holder. They are lined up to matchup with the high point ridges on the front nose. I can remove the plate easily and stow it on the inside of the trunk hood for security if I want.
You can find the magnets at most craft shops or internet. I think I ended up using about 8 half inch round ones. Hot glued them INSIDE the holder BETWEEN the plate and holder. You can put some additional ones on the backside of the apron to increase hold.
74 VW Thing - Walküre (Now Project)
mikeyj007
mikeyj007 is offline
PostPosted: Thu Jun 16, 2011 1:01 pm    Post subject: Reply with quote
The middle of the frame has a bunch of holes that won't let you use the stock holes without the holder. If you use the holder then the bottom part hangs down below the frame. I could have drilled some holes if it was all one solid piece of plastic.
After much searching I found a site that ships them out of Thailand. I'm not sure how much they cost yet. I like the idea of being able to secure it and also see the outer ring on the plate.
http://stainlessfendertrim.com/Products_Plates.html
Semper_Dad
PostPosted: Thu Jun 16, 2011 2:27 pm    Post subject: Reply with quote
Those are nice. Drop them an e-mail, maybe they can give you a USA contact.
perello
perello is offline
PostPosted: Fri Jun 17, 2011 9:38 am    Post subject: Reply with quote
tack weld the new inner rocker...smoothly Smile
fit test the outer rocker, this is the only repro part I am using (danish rockers), in my opinion the inner is perfect but the outer didnt come out as good....
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
GenaBrewer
GenaBrewer is offline
PostPosted: Sat Jun 18, 2011 11:41 am    Post subject: Woke up early this morning Reply with quote
Checked the valves, re-timed the dizzy and changed the trans oil.
Very supprised by the difference in feel with new oil. Feels smoother, like there's less vibration coming from the back. The old oil didn't even look that bad, I just didn't know how old it was. What came out was Hypoid (nothing else smells like that), what went in was Amsoil Severe Duty 75-90.
Chris
63ziggy
63ziggy is offline
PostPosted: Sat Jun 18, 2011 6:54 pm    Post subject: Reply with quote
with temps around 99+ and heat index 105-108
we took on local show sponsored by local VW dealership at their lot. first time to attend. good show, good turn out
even better, no registration fee with free burgers and dogs for lunch.
couple other Things in attendance as well.
aside from extreme heat, we had a good time
View user's profile Send private message Send e-mail AIM Address Instagram Gallery Classifieds Feedback
joescoolcustoms
joescoolcustoms is offline
PostPosted: Sat Jun 18, 2011 8:58 pm    Post subject: Reply with quote
Finally got ride of the Beetle Pea Shooter exhaust!!!
Bought this used, separated, dual quite pack style exhaust in great shape.
First order of business is to make the exhaust heat riser's work properly to heat the manifold for good carb operation. I have gutted a stock muffler around a year ago and cut off the stock heat riser for just this type of use. The factory set up is designed to have the right side come off the exhaust as close to the head as possible in the highest pressure area, circulate through the manifold heat riser tube and then flow out the left side into the lower pressure muffler. Most headers just have two risers on top of each port, which will not circulate, just pulse one way, then pulse back the other way.
I cut the flange off the tube:
Next was to fit it to the header, plumbing it into the muffler area and welding everything back up.
Cleaned and sanded the header so it would take a high temp paint.
I followed the paint instructions of idling the engine for 10 minutes, cool for 20 minutes, run 20 minutes, cool for 10 minutes than drive. tucked up out of the way nicely compared to the Beetle muffler.
Before:
After:
Then had to cruise it with the top down, windshield layed down. Very quite system to the point I cannot hear it run above 10 MPH. But if you are behind the car, it sounds throaty.
Downtown Saint Albans, WV;
UnKlear Racing TAT 2020
Bad News Racing 2018 NORRA 1000 3rd in class, 120/270 overall
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
perello
perello is offline
PostPosted: Mon Jun 20, 2011 9:35 am    Post subject: Reply with quote
unveiled the mystery of the lower A pillar
which is the culprit of a proper rocker adjustment. Tacked B pillar in place
a NOS rear fender looks good, I have all of them bolted to rockers Very Happy
1974 German Thing
1978 Bug 1200
yellow73kubel
yellow73kubel is offline
PostPosted: Mon Jun 20, 2011 2:25 pm    Post subject: Reply with quote
Looking good Perello! Now slow down, you are putting me to shame. Laughing
I finally have my Grabber AT2's mated to the Cookie Cutters. These things look huge sitting next to my current 185/70/14s. Assuming we don't run into any major missing parts snags, the 944 brake swap should begin Thursday afternoon.
My fun over the last two weekends was the Bilstein installation and wheel prep. Both were interesting experiences, and quite worth the effort.
perello
perello is offline
PostPosted: Tue Jun 21, 2011 9:14 am    Post subject: Reply with quote
thanks! ops..got the impression I work slow Rolling Eyes
left B pillar welded in place
secured rear seat support, seat has been shortened on purpose to leave space at the sides for long objects
1974 German Thing
1978 Bug 1200
GI Joe
GI Joe is offline
PostPosted: Tue Jun 21, 2011 9:20 am    Post subject: Reply with quote
My cushion allows a few inches per end(at the doors) to clear for a rifle. I have the Rifle mount installed on the DS back there! Looking to add another one to the DS floor, along the rocker! Good place for quick access to a scatter gun!! LOL!!
Great work Perello!
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
GenaBrewer
PostPosted: Tue Jun 21, 2011 3:51 pm    Post subject: Reply with quote
I installed a new horizontal seal with the motor in. That sucked. Fingers crossed for cooler runnings.
Chris
perello
perello is offline
PostPosted: Wed Jun 22, 2011 8:28 am    Post subject: Reply with quote
Great work Perello!
Thanks! I wa thinking more in kaiak paddles or fishing rods ...
Finished left rocker.....almost
Finished fitting rear bumper...solid
I found the rear door latch catcher
1974 German Thing
1978 Bug 1200
GenaBrewer
PostPosted: Wed Jun 22, 2011 4:22 pm    Post subject: Seal and covers Reply with quote
To compliment the new seal installed yesterday.
I made some covers for the heater holes in my non-181 tin. They're 26ga. steel from home depot, rattle canned and riveted on. Sure beats the speed tape that I kept replacing.
Chris
Billyd64
Billyd64 is offline
PostPosted: Thu Jun 23, 2011 12:32 pm    Post subject: What I did with my Thing today. Reply with quote
Got e-brake ordered from Mike, was going to do more work but it's raining cats n dawgs here, and its only under a carport. Have to find a flasher for warning lights/turn signals, finish rewiring license plate light, numerous other things I could be doing. Other than that I just looked at it!
blakeck2
blakeck2 is offline
PostPosted: Sat Jun 25, 2011 4:45 pm    Post subject: Reply with quote
Made and installed some custom Rubbertite floor mats Twisted Evil
1986 Vanagon Syncro GL, westy interior, GW 2.4 and all locked up
1973 Thing
View user's profile Send private message AIM Address Facebook Classifieds Feedback
Semper_Dad
PostPosted: Sun Jun 26, 2011 8:19 pm    Post subject: Reply with quote
Returned from Mt Baker Camp-n-Cruise. Drove about 150 miles to the location and back without any problems. In fact the car performed perfectly. Got a lot of "thumbs-up", waves and smiles along the way. Weather could have been better but the company was great. Found out what happens to a VW engine block when introduced to bonfire. Shocked
Some pictures here; http://s55.photobucket.com/albums/g127/andisnw/2011%20Mt%20Baker%20Cruise-in/?albumview=slideshow
sixty9fasty
sixty9fasty is offline
PostPosted: Sun Jun 26, 2011 10:19 pm    Post subject: Reply with quote
Drove it doorless and topless to the California Bug Bash.
My Oval Project
Wanna Touch MY THING?!
perello
perello is offline
PostPosted: Mon Jun 27, 2011 10:05 am    Post subject: Reply with quote
MIG day
deleted mirror supports
and restored front left lower corner
almost no militaria signs on front
started restoring back left corner
following with rear left corner
and finished welding rear apron, doors seems to fit well...all doors are in...thats a milestone Wink
1974 German Thing
1978 Bug 1200
perello
perello is offline
PostPosted: Thu Jun 30, 2011 9:41 am    Post subject: Reply with quote
run out of gas...again Rolling Eyes so it was a POR-15 day
1974 German Thing
1978 Bug 1200
Page 40 of 85
