scottf3334 Samba Member
Joined: May 26, 2006 Posts: 205 Location: Davenport, FL
Posted: Fri Jun 17, 2011 1:50 pm Post subject: need assitance in north eastern MO, mid western IL |
Anyone know a good Vanagon mechanic north of Hannibal? My mother is brokedown in Kahoka and can't find anyone willing to diagnose her van. Please PM with your phone if you have any ideas. _________________ 84 Westy
78 Super vert
87 Westy Zetec
heidi85ho Samba Member
Joined: October 17, 2009 Posts: 298 Location: Williamsburg,Virginia
Posted: Fri Jun 17, 2011 2:11 pm Post subject: |
this guy shows up on the rescue list within 100 miles of hannibal. could be of some help
Tom Henderson
COLUMBIA, MO 65203
Phone: (573) 999-2573
Email: [email protected]
Located 78 Miles from you.
Near: 38.88 N 92.40 W
also here is a link to the Roadhaus Mechanics page for Mo.
http://www.roadhaus.com/shops_advanced_search_results.php |
Posted: Fri Jun 17, 2011 7:45 pm Post subject: |
Well, they made it to Quincy, IL. I have checked Roadhaus mechanics list. They have called a few different ones on the list and have been told they don't work on vanagons or there is no way to fit them in for a least a couple of weeks.
Columbus, MO is about 120 miles from them.
I think it is probably something fairly simple. It is an 87 automatic, with the stock 2.1 engine. The symptoms are:
It will stall when coming to a stop.
It is using way too much gas.
The gauge does not show hot.
Will only go about 60mph
The history is that while in Iowa 2 days ago, my brother (I love him, but he is not a great mechanic) put on a new water pump. He also pumped air through the cooling system until a hose in the drivers side front of the engine compartment blew up.
He then replaced the hose, talked about how much of a pile of $$$$ moms VW is and sent them on their way this morning. They drove about 4hrs before the van started stalling at stops (of course they kept on driving, hoping they could just make it to me in Florida). Until it started slowing down.
I had mom look for the oxygen sensor to be sure it is plugged in (thinking the exploding hose may have taken it out).
Is there anyone with even limited vanagon experience anywhere close? _________________ 84 Westy
78 Super vert
87 Westy Zetec |
trip'n Samba Member
Joined: April 27, 2009 Posts: 78 Location: springfield mo
Posted: Fri Jun 17, 2011 8:19 pm Post subject: |
Are they going through st louis |
Posted: Sat Jun 18, 2011 6:28 am Post subject: |
Here is a link to the Roadhaus search page. You can use it to search anywhere in the country for a mechanic. Just input the zip where you are or input the state where you are and a list will come up. |
morymob Samba Member
Posted: Sat Jun 18, 2011 7:45 am Post subject: |
Before it starts stalling out is it running rich, black smoke from exhaust, if so unplug oxy sensor and see if changes, also a shorted oxy wire- center to outside shield- will cause rich running. Follow the wires from the TPS assy to the plug and test. Whoever checks the van should start in the areas, keep us informed. |
50 Kafer Samba Member
Joined: October 27, 2006 Posts: 243 Location: Leavenworth, Kansas
Posted: Sun Jun 19, 2011 10:11 am Post subject: |
Could someone please post a picture of the location of the oxygen sensor on a 2.1.
I can't find a picture anywhere and the one on my 1.9 is in a different location. I'm trying to direct her to unhook it.
It is little like playing vw charades. _________________ 84 Westy
78 Super vert
87 Westy Zetec |
yggdrasil Samba Member
Joined: March 07, 2010 Posts: 240 Location: New Mexico
Posted: Sun Jun 19, 2011 10:30 am Post subject: Temp2 sensor? |
Sounds like it may be the temp 2 sensor.
Im not 100% sure, research the symptons and you may be able to get away with unplugging it? its a sensor that is close by the thermostat if im not mistaken.
Also, if its not heating up at all? then could be a thermostat problem, water temp sending wires? |
Posted: Sun Jun 19, 2011 8:57 pm Post subject: |
Woo Hoo
I talked my mom thru unhooking the o2 sensor and the van immediately ran better.
Sent her to Walmart to get the oil changed just in case some fuel leaked into the oil. She said she took it up to 65 mph on the hwy and it runs great.
So tomorrow they continue the trip to Florida. Thanks everyone for your advice. Especially morymobb, you were right on the money.
Next time I'm in TN, I'm buying you a beer _________________ 84 Westy
78 Super vert
87 Westy Zetec |
