Mountain Haus Samba Member
Joined: October 28, 2008 Posts: 125 Location: Cascade, ColoRADo
Posted: Thu May 19, 2011 7:42 pm Post subject: |
Got mine done with some '05 Mercedes S500 (so I was told) 16" x 6.5 et36, 7 spokes with 205 55 16 G.Y. Eagles, and no spacers. Very close to the upper control arms in front so I may end up with a small spacer, so far so good...no rubbing yet. Re-drilled holes to fit the 14 mm and went with "Van Cafe" studs @ 72mm and "RAD Direct" 55mm bolts up front.
Last edited by Mountain Haus on Thu May 19, 2011 7:59 pm; edited 2 times in total |
Posted: Thu May 19, 2011 7:54 pm Post subject: |
Okay, I got this now. |
SteveVanB Samba Member
Joined: June 01, 2008 Posts: 1645 Location: This side of Daytona
Posted: Fri May 20, 2011 5:40 am Post subject: |
Quote: |
bigsteveob wrote:
How bout these? 2007 A4 17" Any idea as to what would be needed to fit 'em?
Thanks Chris. If I can talk the guy down, I might go for 'em......They are sweet looking! _________________ 91 CARAT |
Ma'ili Pt Westy Samba Member
Joined: March 19, 2005 Posts: 178 Location: Woodside, California (located in Northern California)
Posted: Wed Jun 08, 2011 3:59 pm Post subject: VW sticker for hubs |
I just picked up a set of 15" euro wheels/tires for my 87 Westy. Anyone know where to I can get a set of "VW" stickers for the hubs? |
Posted: Wed Jun 08, 2011 4:39 pm Post subject: Re: VW sticker for hubs |
Ma'ili Pt Westy wrote: |
ebay? or a sign/ sticker shop? Seems like a sign shop with a vinyl cutter could make up a set real quick. _________________ 91 CARAT |
tipsword Samba Member
Posted: Sun Jun 12, 2011 7:18 pm Post subject: |
I just stumbled onto this thread (what a whopper of a thread) and thought I'd share some too.
The top shot is of my current 90' multivan with the same Ronal 17"s as my 85' had on it. The 85' was on H&R pogo sticks (I wont ever run them again, Weitec is a much nicer ride) & 225/45 tires. Am running 215/55's now and my low back and kidneys are lots happier.
I'd love to go to a Mille Miglia cup wheel if I could find some.
Brian |
gflater Samba Member
Joined: January 12, 2011 Posts: 67 Location: Poway, California
Posted: Fri Jun 17, 2011 10:50 pm Post subject: San Diego Tire and Wheel - got some nice 17x8!! |
I was due for 5 new tires but considering the price and availability of Vanagon 14' rim tires I had started looking for new rims that would take more common tires.
I looked at some used Passat and Mercedes rims, prices starting at $300 for beaten up rims. Add tires, I'd be looking at $700 bucks total without knowing what I'd be getting.
Someone pointed me to San Diego Tire and Wheel www.sdtireandwheel.com
I drove away with:
17x8 ET32 TSW ASAN Gun Metal they have a red line inside which matches the red color of the van and brand new tires on them, for a not much more than trying to mess around with this by myself. These guys really know their job.
These rims fit straight, the only issue we encountered was the grease caps in the front which we solved using a 8mm spacer. If I'd modify the grease caps to take off the lip, they would fit without spacer.
They used longer lugs in the front (come with with the rims) and different nuts on the back, using the original studs in the back.
Even the screw that holds the rear break drum on in the back was not an issue with these rims.
The guys at the shop were very friendly and very helpful, we tried a couple of rims, put tires on them mounted them to see the result and whether they would fit/rub and have all the hardware available.
If you are in the San Diego area and shopping for rims & tires, this is the place I would recommend.
Here are some pictures:
[/img] |
speedtek Samba Member
Joined: August 19, 2010 Posts: 234 Location: Prince Albert, SK
Posted: Sat Jun 18, 2011 4:05 pm Post subject: |
225/50R17's I assume?
Looks good on the van |
Posted: Sat Jun 18, 2011 8:13 pm Post subject: |
speedtek wrote: |
Thanks! They are Falken 225/45
Its a stiffer, bumpier ride, but way better handling and stability. |
Posted: Sat Jun 18, 2011 9:31 pm Post subject: |
gflater wrote: |
speedtek wrote: |
Well, at least they're XL's, but a 94 load rating is pushing it.....I ran 95 XL's for a year, but I know they were below borderline as far as load capacity is concerned. The 912's will wear pretty quick on you as well. I think I would have a chat with your tire shop and show them your min specs sticker on the drivers door. If you want to run an all season that will give you proper profile (with those wheels) and load specs..go with a Kumho Ecsta LX 225/50-17. The Kumho's will also last 3 times longer for tread wear....way better UTQG. |
Posted: Sun Jun 19, 2011 7:26 pm Post subject: |
speedtek wrote: |
gflater wrote: |
speedtek wrote: |
Thanks for your concern, I will keep it in mind.
I was thinking, considering the van empty is about 5200 lbs, the load rating on the tires is 1477, that gives me about 700lbs load before I exceed that load rating. This is not a Westfalia or hauler, just my casual, socal long distance/camping vehicle.
Works for me... |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Jun 19, 2011 9:33 pm Post subject: |
gflater wrote: |
speedtek wrote: |
gflater wrote: |
speedtek wrote: |
Works for me... |
That passenger van should be well under 4000 lbs empty. My '84 GL is 3380 lbs and my '86 Westy Weekender is ~3800 lbs. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Mon Jun 20, 2011 8:23 am Post subject: |
gflater wrote: |
Works for me... |
Lol..... ......actually, it never even clicked when I looked at your pics that it isn't a westy.....
94 load rating XL's should be just fine... |
poptop Samba Member
Joined: February 27, 2003 Posts: 607 Location: jersey
Posted: Wed Jun 22, 2011 4:05 pm Post subject: |
Hey guys, I grabbed these MB rims for my auto 2wd westy. 5x112 16 x 8 possible Offset +42mm. not 100%
need the usual help on fittament. here was an old thread and did some research but could use some guru action. I will post pics in a bit but the link has pics and specs i think.mercedes 1634010202 Ed
http://www.thesamba.com/vw/forum/viewtopic.php?t=270428&start=0
_________________ So what I drive the short bus! |
Posted: Thu Jun 23, 2011 3:24 pm Post subject: |
poptop wrote: |
Hi Ed,
You know, as good as those wheels look on a Vanagon, the 8" width just does not play nice on a 2wd. You end up pushing the wheels way too far outboard just to gain the necessary clearance between the tires and the upper control arms. A Syncro has completely different front suspension which is why they can work there, but not on a 2wd.
And just for the record, the offset on those is 62mm, not 42mm. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
poptop Samba Member
Posted: Thu Jun 23, 2011 3:53 pm Post subject: |
Now what? Non refundable! Is there Absolutly no way to use them. If not I cAn try to find narrower ones for the front. Or these sweet rims are up for grabs. Uhgg _________________ So what I drive the short bus! |
Posted: Thu Jun 23, 2011 4:21 pm Post subject: |
Here's the deal! We can build adapters to physically bolt them onto your van (you will need adapters because the difference in offset is too great to make up with traditional spacers). However, the front offset will be way off from ideal and the front wheels will most like be sticking out of the fender openings a bit. The rear track width will be much narrower than the front because we have to tuck the rears in enough to clear the sliding door. In my opinion, all of that conspires against the installation on a 2wd. If you are determined to install them, regardless of the negative effects, we can definitely help you do that, but I wouldn't recommend it.
That style of wheel was available in Europe in a 16x6½ ET47, but they were never imported into the US. If you can find a pair in Europe, yes, you could definitely use those on the front. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
poptop Samba Member
Posted: Thu Jun 23, 2011 5:52 pm Post subject: |
I saw a couple 6.5s on ebay but that creats issues for rotations. They look sweet. I'll see what i can find. In the meantime if anyone needs them for a syncro pm me. _________________ So what I drive the short bus! |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Santana Samba Member
Joined: March 18, 2008 Posts: 146 Location: T-Town, WA
Posted: Thu Jul 07, 2011 3:54 am Post subject: |
This is a sharp looking van! I see you are from Oregon, did u by chance happen to be up in Washington on the Key Peninsula last weekend? Pretty sure I spotted you. _________________ PHOTO GALLERY |
