ldsvwguy Samba Member
Joined: September 16, 2003 Posts: 1020 Location: Saratoga Springs, UT
Posted: Sun Jun 26, 2011 11:09 am Post subject: Ethanol Fuel Friend or Foe? |
So most of the gas stations of my house have a new (to me) disclaimer on their pumps stating that they serve up to 10% ethanol. How does that effect my VW? I mean I started this hobby putting leaded gas into my engine, then it was unleaded and now Ethanol mix. Should I be running additives? I want to get the best life and performance from my engine. I have a 1776 with Dual Weber 44s.
On that note my wife's car requires Premium gas only. Will this Ethanol thing cause issues with her car as well? |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sun Jun 26, 2011 12:08 pm Post subject: |
Ethanol has been a gas additive for a long time, don't worry about it unless you plan on running E85. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1065 Location: Gilbert,Arizona
Posted: Sun Jun 26, 2011 12:19 pm Post subject: |
I disagree,ethanol corrodes gas tanks and float bowls. It absorbs moisture quicker than brake fluid. And it has a shelf life of only 90 days,that means after 90 days the gas starts going bad. Use STA-BIL Ethanol treatment in your tank. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red) |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sun Jun 26, 2011 12:52 pm Post subject: |
I've had no trouble using it everyday, runs great.
But it's shelf life is only 1/3 of pure gas, it absorbs water and is more likely to gunk up carbs if a car is you let it sit for a month.
So it's bad news for small engines and other things that still use ancient carburetor technology. |
Howard 111 Samba Member
Posted: Sun Jun 26, 2011 2:00 pm Post subject: |
So pretty sucky for older engines. What are the alternatives? Is there an additive that can be run? |
Posted: Sun Jun 26, 2011 2:12 pm Post subject: |
I don't know. I run race gas in my Ghia, but it's turboed and F/I and needs it. But I seldom drive it so the expense doesn't hurt so much.
My PT Cruiser is my daily car, but I've never had trouble with it.....so far.
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
We have been having problems with Ethanol enriched fuels for a while.. They are requiring "multi-fuel" rated hoses and are killing some electric fuel pumps.
The first thing that I saw go south when using Ethanol based fuels was German fuel hose, it won't even last a year in my cars with Ethanol enriched fuels. It will dry rot and crack, especially where the hose slides over fittings/ barbs.
The key has been ethanol balancing Sta-Bil. We drive our cars a lot and have had issues when using the same parts and hoses.
The fuel also tunes differently, typically I see engines wanting .5 size larger main jets than what we used to see when optimizing in the past. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
flatfour Samba Member
Posted: Sun Jun 26, 2011 2:23 pm Post subject: |
Ethanol is horrible. Our SUV loses 30-40 miles per tank on E10 vs. Gasoline. It's another invisible "tax" on people, you think you are buying a gallon of fuel but you aren't, you are buying .8 Gallons..... _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Sun Jun 26, 2011 2:43 pm Post subject: |
Those Bastards....
So where do you guys find Sta-bil? Do I need to order it online? Can i buy it at Wally-World, O'Reilly, or Auto-Zone? |
Posted: Sun Jun 26, 2011 2:45 pm Post subject: |
I found a gas station that sells pure gasoline, so I buy all fuel there. It's a Shell station, FWIW. _________________ It's just advice, do whatever you want with it!
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Sun Jun 26, 2011 2:47 pm Post subject: ethanol |
We've had 10% ethanol for sale for many years in Canada. The 10% blend being sold here does not affect rubber fuel lines, etc, as it was specifically blended to prevent these potential problems...manufacturers have to abide by strict guidelines. Perhaps it's different in the USA.
Been running E10 in my '68 Beetle without issue for several years and it has the added benefit of pulling water from the fuel tank, which is an issue with our weather extremes. Also, 10% ethanol blend is the only 94 octane pump gas we have available in my province, so it's a nice product for my 10.5:1 CR.
Regarding your wife's new car which runs on premium, again you should be fine. Our 02' turbo Passat uses E10 premium or mid-grade...nine years on the original motor and fuel lines. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Sun Jun 26, 2011 2:55 pm Post subject: |
Ethanol has 34% less energy per gallon than gasoline.
http://en.wikipedia.org/wiki/Ethanol_fuel#Fuel_economy
It corrodes metal pipelines so can't be mixed and piped via regular petroleum pipelines - so it has to be transported via tankers - either truck or rail. Farmers get subsidies for growing it - politicians that support these subsidies get campaign funds from those farmers.
It is simply another way for farmers and politicians to gouge the American public for money. We pay for this corrupt process and get screwed in the process - all in the name of the environment and less dependence from foreign oil. Yeah right!
Want to be to be free of depending on foreign oil?
DRILL BABY DRILL !!! _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
71_1302 Samba Member
Joined: January 19, 2008 Posts: 133 Location: ~547ft. above sea level.
Posted: Sun Jun 26, 2011 3:07 pm Post subject: |
I'll cast one more negative vote for ethanol fuel blends.
MPG in my Super and 914 dropped an average of 2 to 4 when the powers that be in my area mandated the use of E10. Since the switch was made, I've had to change German braided fuel hoses to modern FI-rated hose , increase the intervals with which I change fuel hoses, add fuel stabilizer with regularity(as stated in other posts), and replace the accelerator pump diaphragms and other consumables in my carbs, among other things. MPG in the modern, fuel injected vehicles of friends and family has dropped an average of 3-5 with the use of E10. In my experience, the use of E10 in my older vehicles costs more in terms of time, money, and MPG. Given the choice, I'd never select E10, E15, etc. over ethanol-free gasoline. My friends, family, and self hate the stuff. _________________ 71' Super Beetle, now departed. |
GDOG57 Samba Member
Posted: Sun Jun 26, 2011 4:09 pm Post subject: |
[email protected] wrote: |
I found a gas station that sells pure gasoline, so I buy all fuel there. It's a Shell station, FWIW. |
Does you no good if you live in a state that has no eth-free gas stations.
Check here for your state:
http://pure-gas.org/index.jsp?stateprov=AZ _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sun Jun 26, 2011 4:16 pm Post subject: |
Ethanol blended fuel (10%) is all that has been available in the Chicago area for the last 15 years. I run it in all my vehicles from vintage VW's to vintage American muscle cars and Hot rods. I have not seen any issues as far as the fuel causing mechanical problems. Yes, the fuel economy drops, but it's all that is available.
They are in the process of attempting to up the Ethanol percentage. I'm sure it will be another one of the laws that are passed without telling the people that it affects. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
modok Samba Member
Posted: Sun Jun 26, 2011 4:25 pm Post subject: |
Just depends on your point of view
It runs just fine in my webers and dells, might even run a hare cooler, so I have no beef with E10.
People who are only driving their vw's a few times a month need to pick up some "stabil", and put some in your lawnmower and small engines too. |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Sun Jun 26, 2011 4:39 pm Post subject: |
I like the stuff myself.
You just have to tune/adjust your engine to run it.
My 12 second naturally asperated street bug gets a legitimate 40 miles per gallon while driving 70 miles per hour on E10 fuel from the pump. And it runs cooler than 100% gasoline too.
I've also pumped a LOT of ethanol through my engine over the last 4 years and have had ZERO problems with it. I've had no wear, corrosion, or anything else that others say it can cause.
Now, if you start running E10 without making any changes to cope with it, then it's your own fault that you are having negative results with it IMHO. If you have old fuel lines, or a neverbeencleanedoutbefore fuel tank, the ethanol will cause you problems. But the root cause is niglect. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
It is much cheaper to pay .10-.15 more for a gallon of real gas the to get he ethanol crap and spend $5 for an additive. Lucky for me the corner gas station carries 100% gas. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
