Single Carb Pic request
Banker
Banker is offline
PostPosted: Thu Jul 21, 2011 9:22 am    Post subject: Single Carb Pic request Reply with quote
Can some post pictures of a single carb on engine with front and both side views? Or even have links. I'm not sure if mine is hooked up correcty with vacum and electric wires. I need a starting point to make idle adjustments.
Thanks
Brian
07 Charger Sublime
03 Goldwing
74 Thing
citroen
citroen is offline
PostPosted: Thu Jul 21, 2011 8:53 pm    Post subject: carb Reply with quote
hope this helps this is just like it came from the factoy except for the fuel pump i changed this thing only has 8800 miles on it orignal
Banker
Banker is offline
PostPosted: Fri Jul 22, 2011 3:18 am    Post subject: Reply with quote
Yes it doe's. It looks like the vacum from the dist goes to the front of the carb. On the drivers side of carb, there is another vacum line, is it plugged, or where does it connect to? Mine just has a open line that is not plugged.
Brian
07 Charger Sublime
03 Goldwing
74 Thing
citroen
citroen is offline
PostPosted: Fri Jul 22, 2011 5:34 am    Post subject: carb Reply with quote
post a picture someone will help there is a bunch of good people on this site
Semper_Dad
Semper_Dad is offline
PostPosted: Fri Jul 22, 2011 5:42 am    Post subject: Reply with quote
As long as you have the correct distributor that is. Should have two vacuum lines coming off your distributor can. One on each side.
The hose connected the side of the carb connects the the port facing away from the distributor (outboard)
The hose connected to the rear of the carb is connected to the port closest to the distributor (inboard)
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
crofty
Judas of the North
crofty is offline
PostPosted: Fri Jul 22, 2011 7:37 am    Post subject: Reply with quote
HamburgerBrad wrote:
portraitmac
portraitmac is offline
PostPosted: Fri Jul 22, 2011 3:25 pm    Post subject: Reply with quote
1974 Thing Carb (I think this is stock, dual vacuum dist)
SilverThing Premium Member
SilverThing is offline
PostPosted: Fri Jul 22, 2011 11:10 pm    Post subject: Reply with quote
The stock 181 carburetor will have 3 vacuum connections:
    one on the driver's side near the idle adjustment screws for vacuum advance (advances timing for part throttle operation - long and short, improves mpg) - this will connect to the rear side (rear being rear of the vehicle) of the distributor vacuum advance (or the side that is not closest to the distributor body),
    another on the rear slightly on the driver's half for vacuum retard (rear being rear of the vehicle - the vacuum retard only operates at idle and is intended to retard the timing to burn the mixture more cleanly for emissions purposes) - this connects to the front of the vacuum canister if the vacuum canister has provisions for it (the side closest to the distributor body - factory used a green hose for this),
    and the final vacuum port is at the rear, base of the carburetor on the passenger side coming up at a 45 degree angle for controlling the EGR valve (EGR valve is the ufo looking thing - only operates at part throttle to mix inert exhaust gases back into the intake to reduce the formation of NOx - acid raining causing pollution) - this does not connect to the distributor.
Other carburetors will have different combinations of vacuum provisions from none (military 181 and bay window buses with suppressed ignition) up to 4 or 5 for certain autostick beetles and ghias with emission controls.
portraitmac: I don't think any stock 181 carb came with dual throttle arms, but just in case: What is the part number on the little metal tag? Stock carbs start with 181. If it 181 part number I would be interested to know what the flange number is (found on the driver side of the carb near the throttle arm at the base of the carburetor).
citroen: I love looking at your engine compartment. I hope mine ends up looking that clean when I get done with my 1600 rebuild and get my a/c in place.
"I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy
Banker
Banker is offline
PostPosted: Sat Jul 23, 2011 4:00 pm    Post subject: Reply with quote
OK here is my carb. I only have one vac on dist and it goes to front of carb. The vac on drivers side of carb is open. I hope to find out the correct vac lines to make it run smooth.
I think it is an Solex 30, Should I replace to a Solex 34?
[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=831128[/img]
[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=831129[/img]
Brian
07 Charger Sublime
03 Goldwing
74 Thing
citroen
citroen is offline
PostPosted: Sat Jul 23, 2011 5:05 pm    Post subject: carb Reply with quote
the single advance hose goes to the left side where you have a open hole you do not need the front 2 on the carb with the single advance
Banker
Banker is offline
PostPosted: Sat Jul 23, 2011 5:12 pm    Post subject: Reply with quote
Thanks, do i just plug the front ones?
Brian
07 Charger Sublime
03 Goldwing
74 Thing
citroen
citroen is offline
PostPosted: Sun Jul 24, 2011 6:56 am    Post subject: carb Reply with quote
yes they are used if you have a dual advance dist
Banker
Banker is offline
PostPosted: Sun Jul 24, 2011 2:04 pm    Post subject: She purrs Reply with quote
Thanks to all, esp to citroen. Once vac was changed, bypass cut-off, and choke fixed, idle adjustment was easy. Now to take on a test drive tomorrow after work. Not enough hours in a day Smile
Brian
07 Charger Sublime
03 Goldwing
74 Thing
citroen
citroen is offline
PostPosted: Mon Jul 25, 2011 5:56 am    Post subject: carb Reply with quote
thanks makes a old man feel good
portraitmac
PostPosted: Wed Feb 22, 2012 9:43 pm    Post subject: Reply with quote
SilverThing - I'm sorry I took so long to see your question. I have since had the carb rebuilt so the metal tag is gone. However, I was able to read it in the original photo...141 129031. There is one more character at the end of the number. I can't tell if it is a 0 (zero) or G. So, not 181, sorry. I can see the other number you asked about, on the flange. On the driver's side, it is VW 326_2 and on the passenger side it is B1 165.
PostPosted: Fri Feb 24, 2012 1:58 pm    Post subject: Reply with quote
Those numbers would make the carburetor a '72 Manual Transmission Karmann Ghia I believe.
memphisthing73
memphisthing73 is offline
PostPosted: Sat Feb 25, 2012 4:33 pm    Post subject: Reply with quote
'72 Beetle
'73 Thing
w2vy
w2vy is offline
PostPosted: Wed Feb 28, 2018 7:43 pm    Post subject: Reply with quote
Do you know what distributor went with it originally?
https://www.thesamba.com/vw/forum/viewtopic.php?p=5695407#5695407
suggested either 113905205AJ or 113905205AN (for 326_1 or 326_3)
Can you offer any insights?
Tom
