quartermilecamel Samba Member
Posted: Fri Aug 05, 2011 11:06 am Post subject: Best way to clean a motor? |
If I had a chevy v8 in my bus I would just cover carb and dizzy and pressure wash the motor. My concern here is dirt/grinding dust getting in behind the crank pulley. My motors really dirty on top and bottom. Is it still safe to pressure wash it or is that a no no? _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Fri Aug 05, 2011 11:10 am Post subject: |
I have power washed mine, but I keep it running... Also I never directly shoot at certain areas, like behind the pulley, at the carb/dist, etc.. That purple crap from local stores works good.. I like a 4 to 1 mix water to purple... Stuff is kinda amazing... A little kerosene will cut thru the real nasty stuff... _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Fri Aug 05, 2011 11:37 am Post subject: |
You could stuff a rag behind the pulley just to keep stuff from running behind there. |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Fri Aug 05, 2011 11:55 am Post subject: |
heavy duty oven cleaner works wonders along with purple power previously mentioned
if you use oven cleaner you have to be careful it will etch aluminum and take off paint _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Posted: Fri Aug 05, 2011 1:05 pm Post subject: |
Emeritusx wrote: |
I have power washed mine, but I keep it running... Also I never directly shoot at certain areas, like behind the pulley, at the carb/dist, etc.. That purple crap from local stores works good.. I like a 4 to 1 mix water to purple... Stuff is kinda amazing... A little kerosene will cut thru the real nasty stuff... |
....you mean the purple driveway cleaner _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
justcruzin Samba Member
Joined: July 31, 2005 Posts: 1493 Location: United States
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Fri Aug 05, 2011 4:49 pm Post subject: |
Mineral spirits in an air pressurized canister...a little on the expensive side but works great and doesn't leave residue that purple stuff does nor does it etch...all my tins are powder coated so that might not work for your situation...not sure if you have show paint or anything other than stock. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
Posted: Fri Aug 05, 2011 5:08 pm Post subject: |
quartermilecamel wrote: |
Emeritusx wrote: |
....you mean the purple driveway cleaner |
I use purple power, but that stuff looks good too.. _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
Posted: Fri Aug 05, 2011 10:44 pm Post subject: |
Yes I do have show paint. 1. you step on over to my bus. 2. you ask me to show you where the paint is. 3. I point out........theres some over there, just past the rust.
Im just wanting to clean up all the shit off of it. Years of build up/metal grinding dust from overhead engine hatch installation. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Clara Samba Member
Posted: Sat Aug 06, 2011 7:28 am Post subject: Re: Best way to clean a motor? |
If I had a chevy v8 in my bus I would just cover carb and dizzy and pressure wash the motor. My concern here is dirt/grinding dust getting in behind the crank pulley. My motors really dirty on top and bottom. Is it still safe to pressure wash it or is that a no no? |
I avoid hitting the paper tubes distributor or carb.
I like to spray simple green on the greasy areas. I find the purple stuff can leave streaks in the paint.
You may choose to wash under the motor first.
I do aim at the area between crank pulley and case.
It is fine to leave it running. If it stalls out, you probably will need to remove the cap and wipe it with a dry clean rag before restarting it. When leaving, check brakes for function they may be wet.
hell, take the seats out and wash the whole bus:
jack points:
cargo floor:
doglegs:
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sat Aug 06, 2011 11:41 am Post subject: |
justcruzin wrote: |
This is how I did mine! ( hubby is in this pic, but I did the first part of the cleaning, he just wanted to do better! LOL)
Yah, it was my bug, but we would do the bus the same way! |
Ok, now I just have to call cheating there _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Sat Aug 06, 2011 3:36 pm Post subject: |
I think Im going to unplug the plug wires and ziplock the dizzy and carbs. Im also guessing by reason of crackage that its not a good idea to spray the heads and cylinders from the bottom.......especially while running. I dont have any simple green. just gonna use the old spray degreaser I guess. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Sat Aug 06, 2011 5:41 pm Post subject: |
I think Im going to unplug the plug wires and ziplock the dizzy and carbs. Im also guessing by reason of crackage that its not a good idea to spray the heads and cylinders from the bottom.......especially while running. I dont have any simple green. just gonna use the old spray degreaser I guess. |
thats why I leave it running... like adding water to a hot car - needs to be running or it will crack... no different then hitting a big puddle will driving...
I've done all my air cooled this way, never cracked one yet... _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
Posted: Mon Aug 08, 2011 1:23 am Post subject: |
Used the simple green and a garden hose. Didnt quite get it so I went to the car wash/still used simple green. Worked much better. Will have to go back for a spotless clean. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
