Idler arm confusion
Vinnems
Vinnems is offline
PostPosted: Mon Aug 08, 2011 9:54 pm    Post subject: Idler arm confusion Reply with quote
I have the Bentley manual for my year and it shows something completely different than what I have pictured. It shows an insert that looks like a T with splines. I have a big bolt as pictured, no splines.
Do I have things arranged correctly for installation? Bolt goes through as shown, cap the end with a washer and nyloc nut, call it a day? How tight should the bolt be in the bracket, because I can't even get it to budge by hand.
Joel
Joel is offline
PostPosted: Tue Aug 09, 2011 4:39 pm    Post subject: Reply with quote
Pretty sure those ones with the pressed steel base like that are late 73/74 only.
Mines got the same, the 71-73 had a cast base instead with the steering lock adjusters on the top.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
vw_hank
vw_hank is offline
PostPosted: Tue Aug 09, 2011 10:35 pm    Post subject: Reply with quote
Thats why I didn't comment when I seen the post last night Wink its nothing like the heavy cast one on my 72.
1302s sunroof..
TimsACVW 1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
Big thanks to my friends Jes67 & Keoki
72on18's
72on18's is offline
PostPosted: Wed Aug 10, 2011 12:07 am    Post subject: Reply with quote
Thats good info to know. I got 2 sent over to me for my RHD conversion and one was cast and one stamped. i used the cast one thinking the stamped one might have been an aftermarket replacement. Does anyone have pics of the 2 different bushings? topline lists 71-72 and 73-74 with a chassis number split between 72 and 73.
Vinnems
Vinnems is offline
PostPosted: Wed Aug 10, 2011 10:12 am    Post subject: Reply with quote
So is everything fine with this set up? I know the bushings are different as Topline shows in their catalogue, and don't want to be using the wrong bushing for my application.
Vinnems
Vinnems is offline
PostPosted: Mon Aug 15, 2011 9:39 pm    Post subject: Reply with quote
Bumping this with another question. What's supposed to move on this set up? The whole bolt and arm, or just the arm? Because my bolt is locked in SOLID and will not move at all, even after sanding it smooth and filing it a bit.. However, the arm still pivots on the smooth part of the bolt head just fine.
