Vinnems Samba Member
Joined: December 23, 2008 Posts: 1183 Location: Simi Valley, CA
Posted: Mon Aug 08, 2011 9:54 pm Post subject: Idler arm confusion |
I have the Bentley manual for my year and it shows something completely different than what I have pictured. It shows an insert that looks like a T with splines. I have a big bolt as pictured, no splines.
Do I have things arranged correctly for installation? Bolt goes through as shown, cap the end with a washer and nyloc nut, call it a day? How tight should the bolt be in the bracket, because I can't even get it to budge by hand. |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Aug 09, 2011 4:39 pm Post subject: |
Pretty sure those ones with the pressed steel base like that are late 73/74 only.
Mines got the same, the 71-73 had a cast base instead with the steering lock adjusters on the top. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Tue Aug 09, 2011 10:35 pm Post subject: |
Joel wrote: |
Mines got the same, the 71-73 had a cast base instead with the steering lock adjusters on the top. |
Thats why I didn't comment when I seen the post last night its nothing like the heavy cast one on my 72. _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
72on18's Samba Member
Joined: August 14, 2005 Posts: 117 Location: corydon,indiana
Posted: Wed Aug 10, 2011 12:07 am Post subject: |
Joel wrote: |
Thats good info to know. I got 2 sent over to me for my RHD conversion and one was cast and one stamped. i used the cast one thinking the stamped one might have been an aftermarket replacement. Does anyone have pics of the 2 different bushings? topline lists 71-72 and 73-74 with a chassis number split between 72 and 73. |
Posted: Wed Aug 10, 2011 10:12 am Post subject: |
So is everything fine with this set up? I know the bushings are different as Topline shows in their catalogue, and don't want to be using the wrong bushing for my application. |
Posted: Mon Aug 15, 2011 9:39 pm Post subject: |
Bumping this with another question. What's supposed to move on this set up? The whole bolt and arm, or just the arm? Because my bolt is locked in SOLID and will not move at all, even after sanding it smooth and filing it a bit.. However, the arm still pivots on the smooth part of the bolt head just fine. |
