What is this?
orrenh
orrenh is offline
PostPosted: Wed Aug 10, 2011 4:26 pm    Post subject: What is this? Reply with quote
At the risk of sounding stupid...
What is this on my engine? I have seen it in a couple photos, but not all. I have 67' split window walkthrough. This is the first bus I have owned. I haven't had a Volkswagen for abut 12 years now. Before I had bugs - 63', 65', 67'. I hadn't seen this on any cars I have previously owned. To be clear I am curious about the piece underneathth carb that connects via tubing to the round piece and about the round iece itself, which seams like an overzealous T fitting.
55reasons
Samba Swamp Cooler
55reasons is offline
PostPosted: Wed Aug 10, 2011 4:34 pm    Post subject: Reply with quote
do you see a stamp on it that says "1.21 jiggawatts" ?
mgamike
mgamike is offline
PostPosted: Wed Aug 10, 2011 5:36 pm    Post subject: Reply with quote
Just a guess, it's an EGR valve. I could be wrong, but that's not what I'm writing for. Your fuel filter is in a bad place. Check the archives, you'll find a lot of things about it.
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Aug 10, 2011 5:55 pm    Post subject: Reply with quote
Yup, California retrofit EGR device from the mid-1970s, made by STP and others. Does the engine no good! Remove it and plug the drilled/tapped hole in the heat riser with a plug from the hardware store.
More info:
http://www.thesamba.com/vw/forum/viewtopic.php?t=396364
And remove that car-be-que inducing plastic fuel filter while you are at it.
Low67vdubinnocal
Low67vdubinnocal is offline
PostPosted: Wed Aug 10, 2011 5:56 pm    Post subject: Reply with quote
Not seen one in years. The link from the poster above has perfect pictures and discription.
Last edited by Low67vdubinnocal on Wed Aug 10, 2011 6:54 pm; edited 1 time in total
69 Jim
69 Jim is offline
PostPosted: Wed Aug 10, 2011 6:53 pm    Post subject: Reply with quote
Low67vdubinnocal wrote:
Not seen one in years pretty sure it was called a Kar Kit Nox device. Used to come with a dash sticker. Think it was used on lots of Cal. cars in the mid 60's early 70's. Not just VW.
That's it. Wink
busdaddy
busdaddy is offline
PostPosted: Wed Aug 10, 2011 7:10 pm    Post subject: Reply with quote
So that's what those damn holes in some heat riser tubes are for, heard of it but never actually saw one intact Cool
Слава Україні!
orrenh
orrenh is offline
PostPosted: Thu Aug 11, 2011 5:27 am    Post subject: Reply with quote
Thanks for all the quick responses, I'm pulling it today. Also removing the filter - thanks for the heads up. Has anyone ever plugged one of these themselves? Any idea what kind of plug from the hardware store works best?
Mr. Loaf
Mr. Loaf is offline
PostPosted: Thu Aug 11, 2011 5:30 am    Post subject: Reply with quote
Take the removed piece with you and match the threads on it to the plug. I do not think you will need a tapered pipe type plug nor do I think you will need a long one. In this case, the shorter the better.
Never drive faster than your Angel can fly
$24,100 was too hard to resist.................
wbrown45
wbrown45 is offline
PostPosted: Thu Aug 11, 2011 5:39 am    Post subject: Reply with quote
You should also move that fuel filter to over the transaxle, and use braided German hose. Nobody needs the drama of leaking fuel over a hot engine.
OK Thang
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Aug 11, 2011 7:39 am    Post subject: Reply with quote
Russ Wolfe said the new German braided hose develops pinhole leaks just like OG hose! He had a big roll of it that he wouldn't use anymore or sell. He advised using standard rubber fuel hose with the reinforcing thread in the rubber.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
ToolBox
ToolBox is offline
PostPosted: Thu Aug 11, 2011 8:52 am    Post subject: Reply with quote
The ethenol blends here in the US will eat the braided hose in less than a year. I have used fuel hose from Ford that is rated for E85 and fuel hose from BMW without any issues lately.
wbrown45
wbrown45 is offline
PostPosted: Thu Aug 11, 2011 3:38 pm    Post subject: Reply with quote
That must be a bad batch, I have some that is less than 2 years old and it is fine. The outer cloth acts like a second reinforcement in case of leaks. These days, some of this hose might be made in China!
OK Thang
Patty B.
Patty B. is offline
PostPosted: Thu Aug 11, 2011 4:22 pm    Post subject: Reply with quote
That's a substantial piece of metal and hosing!!! Shocked
mynameismud
mynameismud is offline
PostPosted: Sat Aug 13, 2011 6:29 pm    Post subject: Reply with quote
That's what she said.
Rolling Eyes
Even YOU can prevent FIRES!
Click to view image
The Sage
The Sage is offline
PostPosted: Sat Aug 13, 2011 8:18 pm    Post subject: Reply with quote
Russ and Tram both seem(ed) to advocate 7mm Mercedes Benz fuel line. That's what I have on my VW's now.
Feel My Pain l Sage Ad World
Endicott jb
Bondo King
Endicott jb is offline
PostPosted: Sat Aug 13, 2011 10:55 pm    Post subject: Reply with quote
I love how threads like these go from "what the heck is this" to "what's the best kind of fuel hose" lol.
Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs.
