transmission differential
llovette
llovette is offline
PostPosted: Sun Aug 14, 2011 4:06 am    Post subject: transmission differential Reply with quote
Im putting together a 67 transmission ,axles, and need to know if there is an order in which the 2 spacers go onto the differential. 1 is thick and 1 is thin. Also the thick spacer has a split in it. Is it supposed too? Thanks for the help
BarryL Premium Member
BarryL is offline
PostPosted: Sun Aug 14, 2011 7:11 am    Post subject: Reply with quote
The thin one goes on first and the thick on top of that one. However, they only go there if that is where they were and you didn't change anything regarding the pinion or crown. The exact thickness determines the backlash and must be set-up with special tools and pre-loads. The split is not supposed to be there as far as I know.
llovette
llovette is offline
PostPosted: Sun Aug 14, 2011 7:51 am    Post subject: Reply with quote
Thank you BarryL. No I didn't change a thing. I bought it used, it was diassembled for shipping. If the spacer is cracked, can I get another somwhere? The spacer is 3.1mm thick. Thanks for the help
BarryL is offline
PostPosted: Sun Aug 14, 2011 6:56 pm    Post subject: Reply with quote
A transaxle builder like Rancho should be able to set you up. I'd think there'd be someone nearer to you.
Dougy Dee
Dougy Dee is online now
PostPosted: Mon Aug 15, 2011 6:11 pm    Post subject: Reply with quote
The thick one should have a bevel on the inside. It goes on first with the bevel towards the C/L of the diff. The thin one after that then the brg.
The split is normal.
llovette
llovette is offline
PostPosted: Mon Aug 15, 2011 6:25 pm    Post subject: Reply with quote
thanks DougyDee. I didnt know about the bevel either
BarryL is offline
PostPosted: Mon Aug 15, 2011 7:15 pm    Post subject: Reply with quote
Sheesh. I thought we were talking against the bearing: part 23 and 24 with 24 being the thin one. So it's split, huh. Maybe Everett can delete my posts.
http://oacdp.org/5867part/295.png
llovette
llovette is offline
PostPosted: Mon Aug 15, 2011 7:42 pm    Post subject: Reply with quote
I'm the one that keeps calling the shims spacers!!!
llovette
llovette is offline
PostPosted: Tue Aug 16, 2011 3:29 am    Post subject: Reply with quote
Is there a right and left difference on the axle tubes?
How can I tell the difference? Thanks all for the help
Dougy Dee
PostPosted: Tue Aug 16, 2011 5:15 am    Post subject: Reply with quote
The axle tubes are the same. The RGB ends are L & R sided. The tab for the flex liine to solid line connector face towards the nosecone or front of the vehicle. If no tab the boss for the shock faces forward.
Note: There may be a different thickness of shims on either side of the diff. Often the ring gear side has a heavier combination if shims for preload.
Dougy Dee
PostPosted: Tue Aug 16, 2011 5:18 am    Post subject: Reply with quote
It is 23 & 24. The pic doesn't show the split in the thicker shim.
llovette
llovette is offline
PostPosted: Thu Aug 18, 2011 8:15 am    Post subject: Reply with quote
When reinstalling the axle, Do I use a rubber gasket AND paper shims for the retainer plate? The rubber gasket part # 111-501-139. I cant seem to find this part!!
Dougy Dee
PostPosted: Thu Aug 18, 2011 8:55 am    Post subject: Reply with quote
The two piece retainers use the rubber o-ring. If you see spot welds holding the upper boot ring to the lower flange then you have two piece retainers.
llovette
llovette is offline
PostPosted: Thu Aug 18, 2011 9:51 am    Post subject: Reply with quote
Dougy Dee you're the MAN!! No rubber gasket just paper for adjusting yes?
BarryL is offline
PostPosted: Thu Aug 18, 2011 11:34 am    Post subject: Reply with quote
The cover plates with the o-ring look like a flying saucer and are late '67. For the paper gasket adjustment: put on 3 dry, tighten, try to let the swing arm fall. It should just fall slow under it's own weight but not just drop. Tear out a gasket one at a time till it's right.
llovette
llovette is offline
PostPosted: Tue Aug 23, 2011 3:05 pm    Post subject: Reply with quote
I am setting the axle retainer plate shims and wanted to know , Is it ok to have 3 gaskets on one side and 2 on another? They seem to drop by their own weight. Just trying to make certain, Thanks all
