The Vintage Kadron History Thread with Questions
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Sun Apr 18, 2010 7:29 pm    Post subject: Reply with quote
hazetguy wrote:
http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC
Yep, still have it stashed away!
Looking for aluminum single port Kadron manifolds.
57baja
57baja is offline
PostPosted: Mon Apr 19, 2010 12:49 am    Post subject: Reply with quote
Stashed away? So your signature shows you're looking for aluminum Kadron intake manifolds. Please chip in! This is the thread to do it in.......
KaddieShack.com - Kadron Carburetor Specialists, VW Parts and Accessories
Have fun with the KS crew on Facebook and keep up to date on the latest builds and happenings
57baja
57baja is offline
PostPosted: Mon Apr 19, 2010 12:59 am    Post subject: Reply with quote
BTW.. that would look real nice next to these...
TomSimon
TomSimon is offline
PostPosted: Mon Apr 19, 2010 9:27 am    Post subject: Reply with quote
57baja wrote:
There are fixes for those issues, if you know what you're doing. For horsepower-per-dollar spent, there is no better set-up...
agreed.
It's very cool that you are collecting and sharing your knowledge of the old Kad kits... I would bet there are a bunch of guys who would tell you it was there first bolt-on performance item for there VW.
It would be cool to see a reprint of an old "low-buck, bolt-on" article where Kads, a 009 dist, a header, and a little tuning made a little 1600dp stocker bug into a completely different animal to drive.
I haven't seen a fix for the linkage problem, which isn't really a per se linkage problem, it's the fact that the kits came with to of the same 'hand' carbs, i am sure to keep the cost down (where both the throttle shaft need to be rotated the same direction to open). As the engine expands with heat, the throttle shafts get further and further apart. The steel linkage arm expands, just not the same amount as the aluminum and iron engine, causing one idle screw off it's seat and opening it. So you have to choose, sync them cold, OR sync them hot.
To overcome this, do tuners convert one carb to the other hand, so that the linkage can be set up to pull left and right, like conventional VW weber and dellorto kits?
2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer
57baja
57baja is offline
PostPosted: Mon Apr 19, 2010 12:27 pm    Post subject: Reply with quote
Tom, I use the Scat linkage on about 85% of the kits I build, maybe even more. While it does not reverse the throttle shaft direction, it is made of aluminum, and for whatever reason, seems to help keep things nice and synch'd. Gene Berg makes (made?) a hex-bar type linkage that pulled from the top (maybe someone could post a photo....HINT HINT) that was pretty cool. Obviously if Berg was involved, it was RIGHT.
Many problems that I've seen people have with the original linkage can be attributed to the balls being loose and/or popping out of their sockets. This is due to not setting them up properly, and/or lack of regular lubrication.
I'll get around to putting up some more info at some point. I know people are out there that have some more cool stuff to add here like hazetguy and glandnut did. Where are the photos guys?
Snort
Snort is offline
PostPosted: Mon Apr 19, 2010 1:12 pm    Post subject: Reply with quote
I'm one of those guys, back in the late 70's. Big bore 1641 drop-in with Kadrons on single port heads, 009 and a Monza exhaust. That motor ran great, had plenty of power, and I never had any problems with syncing the carbs or linkage popping off.
W1K1
W1K1 is offline
PostPosted: Mon Apr 19, 2010 2:31 pm    Post subject: Reply with quote
I hate to say I just threw out an old school linkage/fuel lines that I had sitting around for ages.
I had 2 sets of SP manifolds, one with the tube still in one piece.(my buddy still has it sitting in his garage) I couldn't get it to seal when we tried to install it, so I used the two singles. The reason may be that if you tweaked the tube the manifolds wouldn't line up and seal right.
The tube did add a ton of support for those 2 fat carbs sitting on the 6mm SP studs.
i also had a set of the original shield type air cleaners but one had a spagetti looking tube for the breather line that looked stock.
I might still have my original kadron kit box around somewhere. I recieved a box of parts from someone once and noticed that it was an old school kad kit box so i put it away. Same logo as the red sticker.
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
ALB
ALB is offline
PostPosted: Sun Aug 21, 2011 7:52 am    Post subject: Reply with quote
Realized a little while ago that while the first set of kads I used was in '75 or '76, I'm pretty sure a friend installed a set in his car in '73 or '74. And in Canada it takes a while for everything to make it's way up here...
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Dustin B
Dustin B is offline
PostPosted: Sun Aug 21, 2011 9:46 pm    Post subject: Reply with quote
I was told by a friend of mine that kadron's first were originally used on puma's. Puma came out in 64. I went through the gallery and a few of them had kadron's. im no expert. Just giving you somewhere to look for more history.
Wanted Victoria motors licence plate frame.
62 og paint L469 type 1
61 og paint L31 DD panel type 2
64 heilite viscount tent trailer
71 sears clamshell trailer
I <3 Brazilian busses
Original paint and patina extravaganza http://www.thesamba.com/vw/forum/viewtopic.php?t=187156
conrad1468
conrad1468 is offline
PostPosted: Mon Aug 29, 2011 5:41 am    Post subject: Reply with quote
This thread is great!! I've had Kadrons for the past 10 years or more and love them.
When people ask me what carbs are the best. I say "I like Kadrons. They are easy to set up and are very reliable."... Then they say "I'm going to buy Webers." Why do people ask?... Anyways...
Keep the info coming. I like finding old Kadron stuff, too. People think I'm goofy for like Kadrons so much... Glad to hear I'm not the only one.
I'll snap some pictures of my collection, too.
Fresh Air VW Car Club
New Pittsburgh, PA Car Club. 100% free!!!
club website link
http://groups.yahoo.com/neo/groups/FreshAirVWCarClub/info
thesamba link
http://www.thesamba.com/vw/forum/viewtopic.php?t=363031
Official website
http://www.freshaircarclub.com/
Look us up on Facebook, too
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
IMPI
IMPI is offline
PostPosted: Mon Sep 12, 2011 10:36 am    Post subject: Reply with quote
I can confirm that the solex 40 carbs were part of the early Puma production line as an option they had linkage similar to Okrasa 36 horse links Beautiful Aluminium manifolds with Puma kit cast into the manifold tall air cleaners as well as smaller flat ones. The carbs themselves were OEM on the brazilian opel 4.1liter straight six engine. As Kadron made Puma exhausts etc it might have been a mutual type of design. My 1973 Puma had them as OEM equipment coupled with a Resolit Dizzy.
I will see if I can take a few Photos
Armand
IMPI
IMPI is offline
PostPosted: Sun Sep 18, 2011 9:21 am    Post subject: Reply with quote
Here are the promised Photos:
Regards
Armand
earthquake
earthquake is offline
PostPosted: Sun Sep 18, 2011 3:01 pm    Post subject: Reply with quote
IMPI
Did the linkage mount on the bracket that is welded to the shroud? Do you have a picture of it?
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
IMPI
IMPI is offline
PostPosted: Mon Sep 26, 2011 11:34 am    Post subject: Reply with quote
Hi on the original fan housing the bracket was welded directly to the fan housing and it cracked so i made a base of 2mm plate and welded everything together, it is a serious hassle to weld in that spot as the metal is thin and warps easily. I suspect this welding was also the reason all Pumas had repainted fan housings
Armand
youngnstudly
youngnstudly is online now
PostPosted: Wed Oct 19, 2011 5:44 pm    Post subject: Reply with quote
This is a cool thread! I have been dealing with these carbs for 8 or 10 years and I've often wondered how many variations there are of the linkage, manifolds, carbs, air cleaners, and even exhaust systems.
I know a guy that has an engine that is nearly identical to yours! Haha
Regards
Armand
My current 1679cc single port build with Kadrons:
I didn't think this square fuel line block was anything special, but I might polish it and replace the round one at some point.
I like the Scat linkage a lot, but I really like the Kadron steel bellcrank with the fuel line mount on top much better than the Scat center pull setup...So until I can fab up an alumium crossbar for the stock Kadron linkage, I'll be using the steel 2pc. setup that I modified for CB heim joints. I need 2 more (right hand threaded) heim joints to do the z bar connector on the factory linkage though and I'm too cheap (read:Poor) right now to spring for them. The factory 5mm fine pitch ends are so freakin close to a 10-32 pitch standard thread that I was able to thread a 10-32 die over the stock linkage parts without a die handle...I think it's like .006" difference in major diameter between the two (with the kadron threads being larger than the CB joints), plus the metric pitch converts to 34 TPI, which fits a 10-32 pitch gauge just fine. Although not as safe, I also like the (more hidden) single return spring as opposed to the return spring for each carb. I'll be making refinements as I go.
-Andy
The economy is in a state of disaster, we have NO time for common sense!
c21darrel
c21darrel is offline
PostPosted: Fri Oct 21, 2011 3:27 pm    Post subject: Reply with quote
Cool topic! Ran these on my first VW back in 78-79, replaced a Zenith centermount I couldnt tune. The Zenith got 13MPG on a 1750. Bolted on the kad kit, sync'ed best i could and got 24mpg, Its when I finally liked that Ghia. Had them on several sand cars w/ AJSims tricks, always worked well.
ok, What is the correct way to pronounce??...Kad-ron, Ka-drones....??
ferry
ferry is offline
PostPosted: Wed Mar 14, 2012 11:49 am    Post subject: Reply with quote
cool topic Very Happy
just bought an original set kadrons ..incl the single port manifold ,not cut Very Happy
original linkage and all the clamps ..
ill try to post a picture
Former bmx shop wob61,combat veteran iraq
After several aircooled ,now a 1986 t3 syncro westfalia
avus
avus is offline
PostPosted: Thu Mar 15, 2012 11:08 am    Post subject: pre 1965 kadrons Reply with quote
Armand
Hey Armand,
Very cool info. It would be great to have some documentation of the use of Kads pre-1965. That would make them legal under 36hp Challenge guidelines for the DSS category. I've searched online for the Opel Kapitan 4.1L, found pictures and history, but so far no engine detail information.
IMPI
IMPI is offline
PostPosted: Tue Mar 27, 2012 10:28 am    Post subject: Reply with quote
Hi the Air cooled Pumas were only built from 1969 so earlier info would not come via Puma.
The carbs were used on the Brazillian opels which were re named Chevrolet for their production.
Armand
avus
avus is offline
PostPosted: Tue Mar 27, 2012 1:30 pm    Post subject: Reply with quote
Armand
I've found info about the Chevy Opels with the 250 c.i. engine, but nothing about the carburetors used. Hope to find something definitive like a picture or part number. Thanks.
Jerry
Page 2 of 5
