akgp Samba Member
Joined: December 26, 2009 Posts: 17 Location: Anchorage, AK
Posted: Tue Aug 30, 2011 9:55 am Post subject: Found this under my carpet, is it standard? |
So I pulled my carpet last night to prep for adding sound deadening and on the drivers side I found some sort of pad. Is it a standard thing on 85 Westys? Is it for sound deadening? Just curious if I should remove it or cover it up with the raammat.
srmpf Samba Member
Posted: Tue Aug 30, 2011 10:02 am Post subject: |
I had the same (although grey, not white) and I removed it before adding the sound deadening (Fatmat) and insulation (EZ-Cool). |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15129 Location: Syracuse, NY
Posted: Tue Aug 30, 2011 10:06 am Post subject: |
it's factory sound deadening,
pull it up and replace that inferior tar product with a modern tar product..
or just consider your work done for you by the factory and move on. _________________
Abscate wrote: |
GBA 88West LA Samba Member
Joined: September 04, 2008 Posts: 1279 Location: New Hampshire
Posted: Tue Aug 30, 2011 10:26 am Post subject: |
mine was quite a bear to remove good luck _________________ 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin |
srmpf Samba Member
Posted: Tue Aug 30, 2011 11:17 am Post subject: |
GBA 88West LA wrote: |
mine was quite a bear to remove good luck |
use a heatgun - helps a lot. |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1406 Location: Redmond, WA
Posted: Tue Aug 30, 2011 11:24 am Post subject: |
Mine was cracked to isht.. I had to hit it hard with the heat gun, came off easily when heated. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9775 Location: Mt Lemmon, AZ
Posted: Tue Aug 30, 2011 11:37 am Post subject: |
From the subject line I was expecting a doobie or a baggie. |
pjrae Samba Member
Joined: July 13, 2008 Posts: 155 Location: Joshua Tree
Posted: Tue Aug 30, 2011 11:52 am Post subject: |
Ahwahnee wrote: |
must mean it's still there!
experiment: grab the heat gun and seal the van up and I'll tell you when your getting close....
....cold.... warm.... warmer... warmer..... HOT, LAVA HOT, keep the heat gun RIGHT there _________________ a.lake - 87 Syncro 2.5L - |
akgp Samba Member
Posted: Tue Aug 30, 2011 12:03 pm Post subject: |
Well I'm glad to know it's a standard thing and not something weird the previous owner did to patch a hole or something. So far I've found that the PO like to use clear caulking for a wide range of fixes.
I'll just remove it with the aid of a heatgun and try and get the sound deadening done before winter hits.
I think the doobie is stashed in the hidden storage compartment under the passenger seat, I'll let you know after I take the sawzall to it. |
pjrae Samba Member
Posted: Tue Aug 30, 2011 12:24 pm Post subject: |
akgp wrote: |
I vote oxy-acetylene, minimum. these V-gon's are tough nuts to crack (driven by a bunch of cracked nuts!), just those guys at the border prolly just slap some thermite on both seat pedestals, SOP. _________________ a.lake - 87 Syncro 2.5L - |
vanaru Samba Member
Joined: November 02, 2005 Posts: 169 Location: Sykesville, Maryland
Posted: Tue Aug 30, 2011 6:17 pm Post subject: tar is tar |
[quote="danfromsyr"]it's factory sound deadening,
that's funny. _________________ 1962 sunroof beetle
1982 porsche 911 SC
1991 vanagon WRX powered |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Tue Aug 30, 2011 9:44 pm Post subject: |
modern tar, hahaha |
