What Dizzy is this? German ZV/PAU/4 R 2
1964VW
Location: I live where people chew dip,just past the sticks...
1964VW is offline
PostPosted: Fri Nov 12, 2004 5:08 pm    Post subject: What Dizzy is this? German ZV/PAU/4 R 2 Reply with quote
I'm looking for info on this dizzy-Bosch ZV/PAU/4 R 2
What motor did it come from,what year was it made,ECT INFO?....
Funny the cap size is larger than the 009's ect,more like the old scat's mallorys.
Any info will help-Thanks!
Jonks
TWD
TWD is offline
PostPosted: Fri Nov 12, 2004 6:55 pm    Post subject: Reply with quote
From http://www.oldvolkshome.com/ignition.htm#A6164
Beetle 1961-1964 * 40HP
Distributor: VW 113-905-205A, Bosch ZV/PAU 4R2, 4R5 (0231 139 002) > 113-905-205B, 0231 139 006 > 311-905-205, ZV/PAU 4R4, 4R6 (0231 139 005) > 315-905-205B, 0231 137 031
Can Use: VW 111-905-205L or M, Bosch 0231 147 002 or 111-905-205N, 0231 137 005
Condensor: 02 006
Rotor: 04 010
Cap: 03 037
Coil: 00 001 (Blue Coil: 00 016)
Vacuum Can: 07 015 (NLA)
Ignition Wires: 09 001
Spark Plug: W8AC
Timing Set At:: 10deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum Advance Only: 10deg @ 1.3 In. Hg, 15-21deg @ 2.8 In. Hg
1964VW
1964VW is offline
PostPosted: Fri Nov 12, 2004 7:14 pm    Post subject: Reply with quote
Nice,thank you!
Anybody know it's worth?
Jonks
PostPosted: Fri Nov 12, 2004 9:08 pm    Post subject: Reply with quote
My understanding is that the 4R2 was used for a very short time in the 40hp engines but there were problems with it so they began using the 4R5 very quickly.
I would say it's worth about the same as a 4R5, which I see at shows all the time in the $5 or $10 bins.
If it's in mint condition, maybe more.
1964VW
1964VW is offline
PostPosted: Sat Nov 13, 2004 4:37 pm    Post subject: Reply with quote
Well in a way it's sorta rare then,guess I'll hold onto it. Thanks E
Jonks
