PB blast in water tank
debbiej
debbiej is online now
PostPosted: Tue Sep 20, 2011 8:50 pm    Post subject: PB blast in water tank Reply with quote
Well a month or so ago I was trying to get the original submersable pump in the water tank to work. I did something pretty dumb, in that I sprayed the little impeller on the bottom of the pump with PB blaster and in a moment of thoughtlessness, I let the pump slip back in the water. I've rinsed the tank numerous times, but still the smell and probably the residue is in the tank. what now? wash with dish detergent or degreaser and rinse for a long time? is there a better cleaner to use? I'd really like to get rid of any traces before I put a new line, pump and faucet.
davideric9
davideric9 is offline
PostPosted: Tue Sep 20, 2011 8:57 pm    Post subject: Reply with quote
Well, just a stab in the dark, but I would not hesitate to try vinegar, as my electric coffee maker suggests running a batch of vinegar instead of water once a month to clean it up, and guess what, no after taste of vinegar.
1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012)
IdahoDoug
IdahoDoug is offline
PostPosted: Tue Sep 20, 2011 9:00 pm    Post subject: Reply with quote
PB Blaster is an oil and it's going to be in the pump's impeller as well. Perhaps water lines or anything else the oily water contacted. You'll want to use a detergent such as Dawn dishwashing liquid and hot water. I'm not familiar with the tank in terms of how easy it would be to then rinse out the soapy water (drains?, etc) but the water would then be carrying dissolved oil and need to be drained after a few minutes of agitation. Then I'd repeat again perhaps a couple times and then rinse several times continuing to use very hot water. That stuff's got a cloying odor - I use it a lot.
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader
debbiej
PostPosted: Tue Sep 20, 2011 9:22 pm    Post subject: Reply with quote
well the pump and the hose is out and gone. I'm going to put in a new pump and hose and faucet, so I want the tank to have no trace before the new stuff goes in. I suppose dawn, scrub with brush and rinse over and over. vinegar should help with smell once the oil is gone, but don't know if it would disolve oil...maybe it would!
DAIZEE
DAIZEE is offline
PostPosted: Tue Sep 20, 2011 9:39 pm    Post subject: Reply with quote
Oil & Vinegar and toss in the greens Laughing Soap and hot water, then several rinses and then vinegar and cow brand soda. Question
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
mariusstrom
mariusstrom is offline
PostPosted: Tue Sep 20, 2011 10:30 pm    Post subject: Reply with quote
I think Dawn is probably one of your best bets here. Given that PB is essentially an oil, why not use what breaks down oils and such from your kitchen pretty well. Probably give a healthy amount of Dawn, a good amount of water, and then seal it all up and go do some donuts in a parking lot that has speedbumps. Smile
Good luck!
Marius Strom Otto: 1988 Vanagon Syncro Westy Camper
[SOLD] Felix: 1967 Deluxe Beetle
?Waldo?
?Waldo? is offline
PostPosted: Tue Sep 20, 2011 10:31 pm    Post subject: Reply with quote
I've gotten it on my hands before and no amount of washing with detergents will remove the smell. Only time. Good luck with it.
DAIZEE
DAIZEE is offline
PostPosted: Wed Sep 21, 2011 4:29 am    Post subject: Reply with quote
for the hands try rubbing them with lemons. That may cut the smell, it works for other things (foods) that leave a smell. Just a thought.
Alaric.H
Alaric.H is offline
PostPosted: Wed Sep 21, 2011 4:36 am    Post subject: Reply with quote
Denatured alcohol cleans oil and flashes off pretty good. pour as much as you need in run it through the pump dump it let it dry then bleach and water then fresh water. I just made this up but it was the first thought on it.
SL1
SL1 is offline
PostPosted: Wed Sep 21, 2011 8:34 am    Post subject: Reply with quote
I have extensive experience with Fresh Water tanks, as a C/O of a Coast Guard Vessel, and potable water is an extremely important issue for a ship.
Your tank is probably a write off, hydrocarbons and petroleum based products can actually fuse into the molecular compounds in your tank -because its plastic. If it was a negligible amount, you can probably get by
You can try to wash it out with a citrus based cleaner, but that may well leave a aromatic smell in the tank, if you attempt to use a detergent, then 'sunlight' is best. there are no gaurrantees. the citrus smell will dissipate over time.
For everybody using these tanks, they should be superchlorinated for a minimum period of 4 hrs. the ratio os 1L/M3, or basically 50mg/litre - of unscented bleach. Check the best before date - it actually has one
the superchlorinated solution must then be run through the hose and faucet as well, for a minimum of five minutes
tank must be drained and flushed, at least 4 times with fresh water, then
air dried. You should do this every year to keep safe. Never take chances with potable water - personally, I will never use my 25 yr old plastic tank for potable water. I am planning on having a stainless steel tank fabricated as part of the restore project of my van. You can get some stainless at any place that sells used restaurant equipment and have it welded up.
Good luck
Steve
1985 GL Westy - 'Bullwinkle'
1978 Super Beetle - 'Rocky'
dobryan
dobryan is offline
PostPosted: Wed Sep 21, 2011 8:45 am    Post subject: Reply with quote
If it was me in this situation and I wanted to thoroughly clean the tank I'd try to clean it in place with Dawn, etc but I'd be ready to remove it (but that is somewhat a PITA). With it removed you can thoroughly agitate and repeat many times with various cleaners as necessary. If you can't get it clean then you are halfway done to replacing it.
Sorry for your misfortune.
Dave O
The Western Syncro build
One more islander...
One more islander... is offline
PostPosted: Wed Sep 21, 2011 9:02 am    Post subject: Reply with quote
I've found household ammonia is pretty good at cutting grease. I'd do the dishwashing-liquid wash-out and add a couple of tablespoons of ammonia--then the serial rinsing out as others have suggested.
Kathy
88 Westy
teej
teej is offline
PostPosted: Wed Sep 21, 2011 9:15 am    Post subject: Reply with quote
I'm sure you know this, but whatever you do don't mix bleach and ammonia!
http://wiki.answers.com/Q/What_happens_when_you_combine_bleach_and_ammonia.
1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans
psych-illogical
psych-illogical is offline
PostPosted: Wed Sep 21, 2011 10:21 am    Post subject: Reply with quote
I pretty much think SL1 nailed it with this advice. I personally wouldn't take a chance. I like the idea of getting a stainless steel tank made up. I've thought about this in the past and still haven't done it but it's a good idea. I think I'd go smaller too since I've never, ever even come close to using all the water in the tank on a trip. Water is really heavy too. Most of the time I find it more convenient just to use a separate 5 gallon jug anyway since the faucet is kinda slow and the sink is kinda small.
Thanks to teej for the reminder about chlorine and ammonia too.
83 1/2 Westy waterboxer
'57 Beetle-sold Sad
Coupla '81 BMW motorcycles (R80G/S; R100RS)
'96 BMW R1100GS
PostPosted: Wed Sep 21, 2011 10:48 am    Post subject: Reply with quote
For sure!
Two separate processes: 1) cleaning a tank with soap/ammonia>>several rinses with fresh water; 2) disinfecting the water you carry with bleach.
The intermediate rinses should do it.
Kathy
climberjohn
climberjohn is offline
PostPosted: Wed Sep 21, 2011 1:10 pm    Post subject: Reply with quote
or, to approach this from a different angle . . .
You can do what many Samba folks do, and that's use the on board tank for hand and dish washing only, and carry water in a refillable jug for drinking.
Unless you are dry camping for more than a few days, 5 gallons of potable water should last you for some time.
-CJ
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
debbiej
PostPosted: Wed Sep 21, 2011 8:38 pm    Post subject: Reply with quote
thanks everyone for the good ideas. I'll try citrus degreaser/cleaner and a green scrub pad, rinse a lot then detergent and rinse a lot. then some of the other agents suggested.
it was dumb, I knew it the minute I dropped the pump back in the water. I jerked the pump back up and drained the water. flushed it several times. refilled and went camping. the smell was there, and now I think it is more in those soft plactic water lines than the tank. will change those for sure.
we usually do take drinking water in a container, and did for sure last time. but I love the convenience of a water tank and faucet, even tho little and slow.
markz2004
markz2004 is offline
PostPosted: Wed Sep 21, 2011 8:54 pm    Post subject: Reply with quote
could the inside of the tank be coated?
87 Westy, 250k GW 2.4 - 2.0 Wink, 16" wheels
debbiej
PostPosted: Wed Sep 21, 2011 9:05 pm    Post subject: Reply with quote
it dosen't feel like it, but maybe it has penetrated the material of the tank. is is penetrating oil, after all. bummer Sad
ger320
ger320 is offline
PostPosted: Thu Jun 20, 2013 10:10 am    Post subject: Re: PB blast in water tank Reply with quote
Does anyone know how to remove a fresh water tank in a 1987?
