mxracer Samba Member
Posted: Wed Sep 21, 2011 6:46 am Post subject: Wiper washer alternative... |
I'm not a big fan of the "spare tire" wiper washer system. I know it works I'm just always paranoid of it filling the floorboard with fluid at some point.
So I wanted to convert to an electric pump but wanted to still use the stock wiper arm on the column to control it. Turns out it was pretty easy to do.
What I did was get a momentary switch from Radio Hack (Part # 275-1556), made a bracket to mount the switch in the stock plunger location, used some spring stock I had laying around to mount the bracket and then wire up the pump with a relay using the switch to control the ground to the relay. I also drilled a small dimple in the switch cap to center the "push rod" and give it a positive stop engagement in the cap. I haven't mounted and wired the pump yet but here's some pics of the switch and mount.
EDIT
I finished the install today. Worked out great. I had to shape the mount a little more to slide into the column but that was it.
I used an open relay slot in the fuse block, used a spare spade on #10 on the fuse box, which is for wipers and rear defrost. I ended up with a universal pump from Autozone (part # 9-300) and replaced all the hose, which is 8 ft. I used 5/32 which is a little bigger than the stock stuff. It's a little hard to get it back thru the grommet on the "fire wall" but the stock stuff is all but impossible to get on the 5/32 fittings. i mounted the pump under the washer bottle.
Here's a few more pics of the wiring and pump location.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Wed Sep 21, 2011 7:30 am Post subject: |
Approved Modification #169 _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Wed Sep 21, 2011 10:17 am Post subject: |
I like this! But I fine that I rarely use the washer. And I have a 70 with the separate control knob. I'll need to investigate... |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Wed Sep 21, 2011 10:20 am Post subject: |
I was planning something like this for my early Variant...keep the water away from the dash/electrical bits.
Now I know which part to get from RS...thanks! |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
Posted: Wed Sep 21, 2011 6:01 pm Post subject: |
One question, have you installed the switch into the steering column head? Just asking, because the OE part looks like it has a kick in it, where the switch is straight.
Also, you should have put the pump under the water bottle, that way it's self priming (they melt internally without water/fluid).
I used a micro switch on the edge of my dash (already had a small hole there) to run the pump, and I also used a used GM full size van pump (and mounting bracket) for the pump set up, mounted low in the spare tire well (under the washer tank). This has worked great for 11 years, and I get to have a spare tire full of air when I need it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Sep 21, 2011 6:09 pm Post subject: |
Bobnotch wrote: |
I used a micro switch on the edge of my dash (already had a small hole there) to run the pump, and I also used a used GM full size van pump (and mounting bracket) for the pump set up, mounted low in the spare tire well (under the washer tank). This has worked great for 11 years, and I get to have a spare tire full of air when I need it. |
Yep, the switch is mounted in the column. I had to shape the bracket a little for clearance but once it conformed to the switch assembly it slid right in.
The particular pump I bought recommended installing the pump above the washer bottle. It does take a second to prime each use. Does make sense to mount it under the bottle to keep prime though. |
Posted: Wed Sep 21, 2011 6:46 pm Post subject: |
I just mentioned the pump, because I have one similar to that in my 71 Notch. It's mouted under the bottle too.
I had a pump in my old bug that melted the impeller from running dry (to prime the pump). Since then, I just mount them as low as possible. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Sep 22, 2011 6:50 am Post subject: |
Thanks for the heads up Bob. I went down this morning and moved the pump under the bottle. |
Angelo Amato Samba Member
Joined: January 22, 2005 Posts: 83 Location: Wirral, england
Posted: Sat Sep 24, 2011 3:05 pm Post subject: |
very similar to my mod, works a treat |
Brent Samba Member
Joined: April 28, 2010 Posts: 1613 Location: San Tan Valley, AZ
Posted: Tue Feb 21, 2012 6:57 pm Post subject: |
I've been thinking of how to do this mod using an early switch. I was thinking of drilling out the back side of the rivet and removing the black inlet/outlet section.
But then I'd need to put a small bolt (4mm) through the entire assembly as it holds it all together. Then I could mount the momentary switch using the two holes already there.
I seem to remember seeing a picture of the pump somewhere, maybe it was someone else.
Thought I'd post it up before I go drilling out my switch. Don't want to ruin it. Sorry for the blurry pics, but they get the idea across. Think it will work?
_________________ 69 Fastback Build
Berg5 Build |
supaninja Samba Member
avesondm Samba Member
Joined: July 12, 2010 Posts: 237 Location: west covina, ca
Posted: Tue Feb 21, 2012 8:19 pm Post subject: |
supaninja wrote: |
Here's my early switch
I searched and searched all over on TS and couldn't find more then some references, usually from Bobnotch
Anyways, the washer portion of that switch was crap already so I went about completely disassembling it. Warning, the rivets that hold back on are part of the front structure so be careful when you drill them out.
anyways, all I used was a small momentary switch, small piece of aluminum flat stock, and my favorite...JB Weld
The pump is a cheap garbay special from a jetta, I added a small check valve and it has a nice quick squirt time (i just made term up ) |
Does the "squirt time" and squirt pressure decrease with age? _________________ 71 Squareback FI "TC"
Fat chicks need love too and I have more frunk space than you. |
Posted: Tue Feb 21, 2012 8:24 pm Post subject: |
avesondm wrote: |
supaninja wrote: |
Does the "squirt time" and squirt pressure decrease with age? |
They got some pills that you can add to your wiper fluid to fix that _________________ http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/ |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1590 Location: Seattle, WA
Posted: Tue Feb 21, 2012 8:31 pm Post subject: |
Looks very similar to my Beetle switch - I didn't have to make a bracket for this switch, and ran the wiring through the stock hoses so you had to look close to notice...Also available at RS and it might mean less work.
_________________ (3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's |
Posted: Tue Feb 21, 2012 8:51 pm Post subject: |
supaninja wrote: |
avesondm wrote: |
supaninja wrote: |
They got some pills that you can add to your wiper fluid to fix that |
I've always wondered. Do the pills increase the potency of the washer fluid or increase the voltage of the circuit? Can you only squirt the windshield within four hours of dropping it in the washer bottle? _________________ 71 Squareback FI "TC"
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
Posted: Tue Feb 21, 2012 9:35 pm Post subject: |
I understand you can get pill repops from Mexico and Canada. _________________ 71 Squareback FI "TC"
Posted: Tue Feb 21, 2012 10:31 pm Post subject: |
supaninja wrote: |
Looks slick. I like it.
Well, when you play around with these cars for 20+ years, you kind of learn how to redo some stuff that will keep working (rather than the usual PO hack). You also learn what works, and what doesn't. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
tikitime Samba Member
Joined: December 12, 2006 Posts: 443 Location: New Westminster, BC, Canada
