RaxAdam Samba Member
Joined: September 03, 2011 Posts: 101 Location: Montreal
Posted: Fri Sep 23, 2011 2:58 pm Post subject: URGENT Advice needed: safe to drive with coolant issue? |
Howdy -
I'm on the road in North Adams, MA & my '89 Vanagon Camper started smoking & the oil light went on: I appear to have a leak somewhere in the coolant system (topped it off, drove a bit & it was almost empty again).
I have booked an appointment with a nearby mechanic (thank god they could see me!) but they are 6.5mi away. I wanted to know if it was safe for me to drive the van there in short stings (drive until it starts getting warm, let it cool for an hour, "rinse & repeat")?
I can have it towed, but would rather not if not entirely necessary, but don't know enough to make the call myself. Any advice would be appreciated. Details on what happened below.
Thanks in advance!
Rax
The situation: I was driving early this morning & around 15mins into the trip, the oil light turned on & smoke started pouring out the back. Pulled over & the coolant tank was extremely low, but the overflow tank was completely full. I manually drained the overflow tank and put the fluid back in the main coolant tank, but that didn't fill it. Things settled down a bit, enough for me to make it to a store to buy more coolant. Topped off the tank, but the whole thing repeated: 10mins & it was smoking more than ever. When I pulled over this last time, fluid was freely leaking out the back & the main tank was back down to the nearly empty level at which it had been prior to filling. I just hope it's a simple leak & not something more serious. I check the other tubes with the engine running & they didn't go "hard" right away - so I don't think it is a pressure issue.
Any help appreciated enormously!
~ Uncomfortably warm in North Adams _________________ '89 Vanagon (camper w/ 3-way fridge) |
Posted: Fri Sep 23, 2011 4:33 pm Post subject: |
I know it hasn't been long since the post: but any thoughts? _________________ '89 Vanagon (camper w/ 3-way fridge) |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Sat Sep 24, 2011 5:23 am Post subject: |
I have a VW shop in NY about an 45 min from North Adams, MA. I've got lots of Vanagon parts here.
Are you sure it was the oil light on and not the coolant light? When you say it was smoking, do you mean out the tailpipe or smoke off the engine? I have tons of new and used parts here and will be here today until 3 then closed Sun and Mon. 518.766.5654. |
oasis Samba Member
Posted: Sat Sep 24, 2011 11:30 pm Post subject: |
You're not going to like my answer, but it's still my best advice. I wouldn't take a Vanagon to any-old mechanic; I'd take it to someone who knows VW's, and specifically Vanagon's. Furthermore, I would error on the side of caution and have the darn thing towed -- even 45 minutes.
If it were just something simple without a diagnosis needed (like a clutch), then I could see nursing it someplace close, and let them get and install the proper part. This is different, and Vanagon's are different. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
Low67vdubinnocal Samba Member
Posted: Sun Sep 25, 2011 6:33 pm Post subject: |
I think if you ask to have your question moved over to the vanagon section you will get a lot more answers and help.
http://www.thesamba.com/vw/forum/viewforum.php?f=20
Years ago my wife drove our 84 Vanagon leaking and it didnt last long before it was melted. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10250 Location: N. Idaho
Posted: Sun Sep 25, 2011 10:03 pm Post subject: |
The Vanagon coolant system is one of the most make-specific aspects of its unique engine so I would be a little concerned about just any shop being able to competently help you. I'd go farther to a shop with knowledge.
As for your issue - I don't really understand it. Smoke is different from steam from a coolant leak. And an oil light coming on is different from a coolant light. Atop that, you have not mentioned any actual operating problems (like temp gauge getting hot, etc) so you seem to be simply driving around with a coolant leak and doing a good job of monitoring your coolant levels and ensuring your engine does not get low. So I suggest you clarify what's up.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
GBA 88West LA Samba Member
Joined: September 04, 2008 Posts: 1279 Location: New Hampshire
Posted: Mon Sep 26, 2011 6:11 am Post subject: |
dont drive it tow it _________________ 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin |
SteveVanB Samba Member
Joined: June 01, 2008 Posts: 1645 Location: This side of Daytona
Posted: Mon Sep 26, 2011 6:18 am Post subject: |
It sounds like a blown head gasket causing the coolant to push into the overflow res........Better tow that thing........ _________________ 91 CARAT |
SL1 Samba Member
Joined: December 17, 2010 Posts: 251 Location: Nova Scotia, Canada
Posted: Mon Sep 26, 2011 6:21 am Post subject: |
yep, get it towed before you cook your engine, the oil light is disconcerning enough, but your make-up tank getting filled up is also a bad sign, could be anything from a clogged up rad to bad heads/seals. don't take a chance by driving it.
and you also need a VW mech that knows about the waterboxers - anybody else will be taking an uneducated guess _________________ Steve
1985 GL Westy - 'Bullwinkle'
1978 Super Beetle - 'Rocky' |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Mon Sep 26, 2011 6:34 am Post subject: |
I have found out more than once some people will say "oil light" when they mean the flashing led in the temp gauge. I have found more than once some people will say smoke when it is really steam. Hard to say what is going on without futher probing. Could be a simple leaking hose or leaky waterpump.
Mark
SL1 wrote: |
and you also need a VW mech that knows about the waterboxers - anybody else will be taking an uneducated guess |
molson88 Samba Member
Joined: April 28, 2004 Posts: 143 Location: Gabriola Island, BC
Posted: Mon Sep 26, 2011 9:19 am Post subject: |
SteveVanB wrote: |
It sounds like a blown head gasket causing the coolant to push into the overflow res........Better tow that thing........ |
Even a small leak in the head gasket can cause this problem. It happened to us on our first long trip in our Westy, but we were about a thousand kilometers from the nearest VW dealer. We just kept topping up the coolant and kept driving... and bleeding the radiator once a day or so. We ended up putting nearly 10,000 km on the van on that trip before we were able to get it fixed.
The same problem happened again the following summer, so we finally bit the bullet and went with a permanent fix (Subaru EJ22). _________________ Cliff
99 Eurovan Camper (current)
88 Vanagon GL Camper with Subaru EJ22 (gone)
83 Vanagon Camper (best forgotten...)
2012 Audi Q5 3.2L |
SL1 Samba Member
Posted: Mon Sep 26, 2011 9:51 am Post subject: |
so there you go, some say drive it, some say tow it
the advice I got last year was exactly the same - I decided to take the easy way - drive it and top up the system. Only cost me $700 for the towing and 3K to have engine rebuilt. ( 250 mile tow, major top end rebuild)
my choice, my mistake, my fault, there is tons of good advice on this site
you've got to read these posts and decide for yourself - advice is always free, but sometimes the easiest way is not the best
good luck _________________ Steve
Posted: Mon Sep 26, 2011 9:58 am Post subject: |
SL1 wrote: |
good luck |
Just for clarification, I was referring to my experience with a specific symptom (leaking combustion gases pressuring up the cooling system causing a gradual loss of coolant).
The OP hasn't given enough information regarding his situation... such as what is the temperature gauge reading, what is the condition and level of the engine oil? _________________ Cliff
2012 Audi Q5 3.2L |
J Charlton Samba Member
Joined: August 24, 2007 Posts: 1546 Location: The True North Strong and Free
Posted: Mon Sep 26, 2011 10:01 am Post subject: coolant leak |
Unless you KNOW that its a small leak and you can safely proactively fill the system to enable you to drive it a few km, don't drive it. Find the leak and fix it, even a temporary fix or get it towed.
Here is a Montreal contact for you Shop Atelier Mecanique Eric 514 830 8350
[email protected] good guy, very knowledgeable in Montreal _________________ NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024 |
Posted: Wed Nov 02, 2011 12:06 pm Post subject: |
Dear All,
First - THANK YOU all for your responses: I can't tell you how much I appreciate it.
This post is pretty long, so I've titled the paragraphs for quick navigation, splitting it into three parts: i) how things played out; ii) for the benefit of those in a similar situation in the future; iii) present woes.
How things played out
I had to make a decision that day & had, it seems, posted in the wrong forum (still getting oriented): turns out there was a crack in the threading of the coolant system sensor. Unfortunately this took the mechanic ~6h to sort out (after replacing many of the old coolant hoses that did not exactly inspire confidence and removing the tank twice). Fortunately, he was kind enough to only charge me for half of those hours (still price).
And yes: I was mistaken, what I called the "oil light" was the red light in the temperature gauge.
However, it turned out this wasn't the end of my troubles: the resistor at the front of the van that is (somehow) a part of the radiator system had burnt out and I'm not entirely sure what else was giving grief, but the coolant started spilling over again a few days later [nearly resulting in my having a mental breakdown: I slept that night at a "Foodmaster", with a meeting with a Harvard professor hanging over my head first thing that next morning and no clear way of getting there in time - what a night!].
I ended up making it to a mechanic in Natick, MA (Greg's VW): he took one look at the coolant tank and diagnosed the issue. He replaced the tank itself as well as the sensor (again); a few hoses & connectors specific to the VW as well as the resistor at the front of the van*. Things have been working okay since then.
I say "okay" because the coolant light keeps turning on, but I don't know why: the levels are fine. I initially felt that the temperature gauge was also reading higher than it had before (I thought it had usually been just above the top of the lightbulb - i.e. roughly 2/3 up - and now it was closer to 3/4 of the way to the "max" line). I had the mechanic look over the system again, but he reported that everything seemed to be responding well: heating up until the rad fans kicked in & the cooling off. In the weeks that followed, I found that the temperature gauge normalized at a lower point during highway driving, but would go up to the 3/4 point (and threaten to go higher) when I was in the city (i.e. start & stop).
For the benefit of anyone who has a similar question in the future: I ended up letting the van cool, topping off the coolant and driving, slowly the 6mi/10km to the local mechanic, watching the temp gauge the whole time. This decision was based on my having seen that it was a leak in the vicinity of the coolant tank and having been previously informed that the smoke was, as others pointed out, actually steam and probably okay to drive the short distance. If I had not had that confidence, I'd've had it towed.
Present situation:
I've put a few thousand miles on the van since: both city and highway driving (the majority being highway, of course). The coolant light has persisted in blinking: sometimes turning off if I turn off the engine and start up again; sometimes coming and going - the levels had been fine until recently.
At one point, 2 weeks ago there were a few drops of coolant that spewed from somewhere and caused a bit of steam, but the issue was minor and didn't persist and I was too terrified to face the possibility that I'd have to take it in again, so lived in practical denial (not the best solution, granted: but I had been living out of the van for 2.5 months at that point, on business, no less, so was too worn down to be proactive).
On my trip home [sweet, sweet, sweet, home], some new rumblings started storing up from both the back and front of the van and the temp gauge climbed high for a bit. I eased off the speed a bit every time the noise came up and it slowly died down to an occasional grumble: something like a fan at the front passenger side (though not the "jet engine" noise of the radiator in '2nd gear').
Upon arriving home, I checked the oil and was surprised to find it was way below the min. (shouldn't the oil light turn on for this?!). I also noticed that the expansion tank for the coolant system was bone dry, when it had been topped up not long ago (2 weeks). Finally, the transmission fluid also seemed low (having also been topped up not long ago).
I've added oil, and have the transmission fluid, but [the confession:] I'm a real bookish guy and this is my first vehicle (let alone Vanagon!), and wasn't able to find the place for adding transmission fluid. Lastly, I don't have coolant on me, so have to pick some up before topping off the expansion tank.
I have an appointment with a friendly mechanic next Monday, but it is a 2h drive away - so I guess I'm ending this post by asking the original question again: safe to drive it? How can I sort it out?
Being at home again, I can (& will) respond to the thread quickly.
Thanks to all for their help - it is very much appreciated.
All the best,
Rax
ps. please also consider this a general call for advice on maintenance and care for a VW: i've struggled so far to find material that is accessible to me. I had hoped to find an owners group where I could learn from others in person, but have yet to find such a thing: any & all advice warmly welcome.
* he mentioned that the manufacturer for these ceramic resistors has stopped producing them and that it was merely good luck for me that he happened to have one of the last ones in stock: is it true that these can no longer be sourced? _________________ '89 Vanagon (camper w/ 3-way fridge) |
r39o Samba Polizei
Posted: Wed Nov 02, 2011 12:27 pm Post subject: |
Read the Coolant Temperature Gauge threads from the FAQ...... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
buildyourown Samba Member
Posted: Wed Nov 02, 2011 12:35 pm Post subject: |
You have foudn your place to learn about proper care for these vehicles. There si no dumb question and people here are very knowledgable about vans and vehicles in general. Welcome.
I wouldn't put too much energy into diagnosing a blinking coolant light. The higher temp gauge is concerning and I would investigate that. First guess: Air bubble in coolant system. Search and do a proper bleed and see if that settles things down.
Maybe I'm being niave about the light but mine has been flashing intermittenely for months with no other symptoms or predictability. I go off the gauge and the coolant level. |
elsyr Samba Member
Joined: May 06, 2008 Posts: 270 Location: North Florida
Posted: Wed Nov 02, 2011 12:37 pm Post subject: |
I believe the fan resistors are now available again. I tend to buy stuff from Van Cafe most often (I like the cookies), but Bus Depot and/or Go Westy or others might also have them.
EDIT - just checked Van Cafe and they appear to be out of stock again.
As mentioned, there are lots of ways the coolant level sensor/indicator can go funny, and there's a good thread on it. An air bubble in the coolant system can also, as mentioned, cause all sorts of wierd behavior. Learning to bleed the system properly should be one of the first things you master. If I can manage it - anyone can.
In my case, fixing the blinking was a matter of replacing the sensor (which was bad and obviously so - there was liquid wicking up into the sensor itself), and then working a little on the connector to get a better connection (the female connectors needed to be removed from the connector shell and adjusted for a tighter fit on the male contacts).
Doug _________________ '89 Carat "Brunhilde" |
