SWbySWesty Samba Member
Joined: July 01, 2010 Posts: 327 Location: Adventureville, CA
Posted: Tue Sep 27, 2011 2:37 pm Post subject: Propane Leak inside |
After having the van sit for a while, I will open the door and get a wiff of propane inside the van.
Where do I start trouble shooting? I turned the main valve off whenever driving or not in use, I figured it was leaking out with less pressure, but wouldn't the line empty and stop delivering gas? Either position gives a smell. _________________ 1986 Westy - Billie Jean
A Westy with a Jeep heart (Pura Vida)
www.theadventurebrigade.blogspot.com - Latest update: Johnson Valley - Nov 22, 2011 |
r39o Samba Polizei
Posted: Tue Sep 27, 2011 2:39 pm Post subject: |
I had the same thing. It WAS the valve.
You need to start with the spray soapy water on connections and the valve, etc, to find bubbles. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2068 Location: Ontario Canada
Posted: Tue Sep 27, 2011 2:39 pm Post subject: leak |
If you are sure it's propane and not a dead critter in the cupboard...turn on the gas and test all fittings with a spray solution of soapy water-no smoking. _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Posted: Tue Sep 27, 2011 2:42 pm Post subject: |
So I should take apart the top of the stove to spray? Sorry for the ignorance. I'm also at work and not looking at it right now. _________________ 1986 Westy - Billie Jean
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Tue Sep 27, 2011 3:06 pm Post subject: |
Should I really worry about outside on tank itself? That would make it smell around the van but not inside of it. At least that's what I'd assume. Sigh...just wish I had TIME! No daylight to use until Thursday. _________________ 1986 Westy - Billie Jean
vela123321 Samba Member
Posted: Tue Sep 27, 2011 4:15 pm Post subject: |
SWbySWesty wrote: |
Should I really worry about outside on tank itself? That would make it smell around the van but not inside of it. At least that's what I'd assume. Sigh...just wish I had TIME! No daylight to use until Thursday. |
There are several fittings around the tank. If any of them are leaking, the smell could easily make it up to the inside of the van. I just had this happen... _________________ ________________________
1987 Westfalia Vanagon 2.1 automatic
2014 VW TDi Jetta Sportwagen (Dieselgate)
2016 BMW 328i
1967 Bug... given to a friend
others not VW... Toyota, Audi, Volvo, Datsun, International Harvester |
mwsnow Samba Member
Joined: November 13, 2007 Posts: 266 Location: Alton, NH
Posted: Tue Sep 27, 2011 4:27 pm Post subject: |
vela123321 wrote: |
There are several fittings around the tank. If any of them are leaking, the smell could easily make it up to the inside of the van. I just had this happen... |
Propane is heavier than air, and falls to the ground instead of rising into the body. I would be suspicious of in internal leak. |
