Cliff@BrownBags Samba Member
Joined: June 14, 2007 Posts: 649 Location: glen burnie maryland
Posted: Fri Sep 30, 2011 5:24 am Post subject: |
at one time i had a bug with a 6 and with a 4. it was night and day. it was a dream to drive the one wtih the 4" _________________ its not about what you say you will do oneday, its what you do today that actualy means something. |
Cody1963 Samba Village Idiot
Joined: December 12, 2009 Posts: 619 Location: Jamestown, California
Posted: Fri Sep 30, 2011 6:54 am Post subject: |
Ya I'm prety set on the 4 inch, I can't wait to make it! _________________ Cody
57 Oval
63 Bug "Slammed"
68 Bug "Shortened" |
puttin slow Samba Member
Joined: March 28, 2007 Posts: 67 Location: garden grove
Posted: Sat Oct 01, 2011 6:29 pm Post subject: |
running a 5.25 beam with drop spindles and 195-50's. only rub the trailing arm on full lock and headlight buckets have been cut and re-welded and i still rub the buckets on a quick turn. no body rub though. narrowed beam sucks turning to the left.....just a warning. |
Posted: Sat Oct 01, 2011 6:34 pm Post subject: |
Why to the left? _________________ Cody
57 Oval
63 Bug "Slammed"
Posted: Sat Oct 01, 2011 6:40 pm Post subject: |
[/img] |
Posted: Sat Oct 01, 2011 6:41 pm Post subject: |
tie rod is super short now as with a narrowed beam setup on the left so the turning radius is about half of what right turning radius is now. can always be corrected with a center load rack and pinion. working on that right now |
mdnick Samba Member
Joined: August 05, 2006 Posts: 136 Location: Maryland
Posted: Mon Oct 03, 2011 5:46 am Post subject: |
like it's been said.. ive been running a 6. i get significant rubbing on the inner fender and the headlight bucket, the cars i've driven with 4" beams are awesome.. if i ever make a new beam it will be a 4 _________________ -nick-
purists seem to think everyone should conform to their standards. i seem to remember a certain historical figure that believed the same thing. yet we called him a lunatic? weird. |
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Mon Oct 03, 2011 12:37 pm Post subject: |
a 4" beam is superior to anything more. I would run a 4 but then I wouldnt be able to use my swaybar. I currently have a 2" with swaybar and discs/Sprintstars and 165/60. I need 2" more narrow to clean it up but for these roads, that will have to stay for now. I would stick to the small Smart car tires as well. I had a couple bad accidents due to 135s sliding in the rain, years ago. Now I use either 155/60 or 165/60 Continentals. Much better tire all around. |
dirtylawnchair Samba Member
Joined: January 26, 2004 Posts: 1234 Location: Bradenton FL
Posted: Mon Oct 03, 2011 12:39 pm Post subject: |
How narrow is all relevant to the offset of your wheels. _________________ Paulie
63 Standard OG paint |
Posted: Mon Oct 03, 2011 1:33 pm Post subject: |
dirtylawnchair wrote: |
How narrow is all relevant to the offset of your wheels. |
Stock smoothies. Drums.... All stock _________________ Cody
57 Oval
63 Bug "Slammed"
Posted: Mon Oct 03, 2011 1:37 pm Post subject: |
Cody1963 wrote: |
Stock smoothies. Drums.... All stock |
2", 3" maybe 4". In my opinion. _________________ Paulie
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Mon Oct 03, 2011 1:38 pm Post subject: |
Very true. A 4" is great with stock wheels. Or anything with a similar offset.
5" is great for anything with a BRM offset. |
Posted: Mon Oct 03, 2011 3:15 pm Post subject: |
something you also need to realize- if you are running stock 4" smoothies and stock drums, something even minimal like a 2" IS noticeable. 4" is major on a stock setup. I would use the Smart tires and not the 135s if you do a 4". You want the extra track for handling and safety. A 145/65 or 155/60 with your wheels would look good and still handle, and you can still have shocks. |
flatNbug Samba Member
Posted: Mon Oct 03, 2011 9:10 pm Post subject: |
i just wanted to add my two cents i worked at a tire shop and i run temps on the front of my bug (think of it this way) lighter in the front and not as fast as the car they came out with. also they under rate the speed on them
as for my set up ive got a 6 inch beam 3 inch drop spindles 3/16ths pied pan head running empi 5 spokes and 135 15 temps. beam adjusters are mid way arms are strait and caster is 10(alittle much but it tracks great)
just somthing to think about if you have bucket rub you can cut 3/4 out of them and weld it back in |
Posted: Mon Oct 03, 2011 9:43 pm Post subject: |
flatNbug wrote: |
I'll probably end up cutting my headlight buckets eventually _________________ Cody
57 Oval
63 Bug "Slammed"
Posted: Tue Oct 04, 2011 7:50 pm Post subject: |
there was a post i was looking at, can't remember where, but a guy had a narrowed drop spindled early bug and ran 1.5 inch longer trailing arms on his beam. actually looked good in the pictures and the wheels were centered again. He also said there was no head light bucket rub issues. I hope someone can help me out and post a link to this. |
Earlybugs Banned
Joined: December 23, 2004 Posts: 246 Location: Salem, OR
Posted: Tue Oct 04, 2011 8:42 pm Post subject: |
puttin slow wrote: |
I have a set of 1" extended trailing arms that Michael Fischer built on my 60 he had a set on his 64 to. My set up now is a 6" beam with drop spindles 145 65s and 6" porsche spares with adapters. I have also ran randars, smoothies, and spindle mounts with temps with no head light bucket rubbing, it does rub a little on the inner fender well at full turn.
I have no problems with this combo i also have mikes drop plates on the back. I put about 400 miles on it a week year round.
Posted: Tue Oct 04, 2011 9:13 pm Post subject: |
Damn! That bug is awesome and low!!!
Earlybugs wrote: |
57 Oval
63 Bug "Slammed"
fuhq64 Samba Member
Posted: Tue Oct 04, 2011 11:44 pm Post subject: |
Earlybugs wrote: |
Wow, that wheel is really centered up. Looks good _________________ 69 Squareback
Still a n00b
www.instagram.com/fuhq64 |
Posted: Wed Oct 05, 2011 5:12 am Post subject: |
My next project I may notch the pan head to pull the wheels back.
Your set up looks great. Where did you get those extended arms? Info please!!! _________________ Paulie
