Distributor questions
Paulfive5
Paulfive5 is offline
PostPosted: Thu Oct 13, 2011 5:16 pm    Post subject: Distributor questions Reply with quote
Not to open a can of worms or anything, but what distributor should I be shopping for? I have a vacuum advance that came with the engine case from a EFI car, but the vacuum diaphram hits the single carb manifold that I've installed. I'm starting with a 30 PICT carb, but hope to move to a Holly two barrel at some point. I"m currently leaning towards a mechanical advance distrubutor with electronic points. This is on a dune buggy that really won't be too performance oriented.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Oct 13, 2011 5:22 pm    Post subject: Reply with quote
Get a Bosch Mexican vacuum/mechanical distributor from aircooled.net.
And forget the Holly 2 barrel, they don't work well on VW engines.
If you want a purely mechanical, then get a Bosch 019, it's much better than the Chinese 009 knockoffs.
Glenn
Member #1009
#BlueSquare
cmiller95
cmiller95 is offline
PostPosted: Thu Oct 13, 2011 5:46 pm    Post subject: Reply with quote
not to bring up a disagreement but, Very Happy i have a bugspray on my sandrail and it runs way better than the stock 30 pict did.
Swing axle: Eating tires since 1938
My Rail Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=427627
My Baja Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466974
vwracerdave
vwracerdave is offline
PostPosted: Thu Oct 13, 2011 6:13 pm    Post subject: Re: Distributor questions Reply with quote
If this is a street legal fiberglass dunebuggy for street driving then get the SVDA from aircooled.net as mentioned. If this is an off road sand buggy and will never be driven on the street then go to a swap meet and buy a used genuine Bosch German 009.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Thu Oct 13, 2011 6:35 pm    Post subject: Reply with quote
He said holley 2 barrell....bugspray is one barrell
And no....the holley 2 barrell doesn't work well
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
Mr. 010
Glenn is offline
PostPosted: Thu Oct 13, 2011 6:58 pm    Post subject: Reply with quote
Ed Zackerly.
(019 is better than 009) Wink
Glenn
Member #1009
#BlueSquare
DarthWeber
DarthWeber is offline
PostPosted: Thu Oct 13, 2011 7:01 pm    Post subject: Reply with quote
Are you sure there 5Lug? Think
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
Mr. 010
Glenn is offline
PostPosted: Thu Oct 13, 2011 7:04 pm    Post subject: Reply with quote
I stand corrected.
But I was thinking Weber Progressive.
Glenn
Member #1009
#BlueSquare
RockCrusher
RockCrusher is offline
PostPosted: Thu Oct 13, 2011 9:46 pm    Post subject: Reply with quote
I've never looked at a bugspray up close and personal but that one in the picture looks like a 2 barrel.....two main jet access screws in the bowl but a single inlet throat and single bowl vent like a rochester or carter 2 barrel.
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
fivelugshortaxle
PostPosted: Thu Oct 13, 2011 9:50 pm    Post subject: Reply with quote
Single throat...single barrell......am I wrong on this line of thinking? And to the guy who says the bugspray works well....yes, they're awesome....had one on my first bug, a 1972 super when I was 16....
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
RockCrusher
PostPosted: Thu Oct 13, 2011 10:02 pm    Post subject: Reply with quote
It has one CHOKE butterfly but 2 main jets. 2 jets means 2 barrels. They are very old skool design and that's basically what all 2 barrel carbs looked like back in the 60's and 70's
fivelugshortaxle
PostPosted: Thu Oct 13, 2011 10:04 pm    Post subject: Reply with quote
Never knew that!.......learn something on here every ten minutes, I think....thanks for the info....
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
DarthWeber
PostPosted: Thu Oct 13, 2011 11:12 pm    Post subject: Reply with quote
fivelugshortaxle
PostPosted: Thu Oct 13, 2011 11:14 pm    Post subject: Reply with quote
DarthWeber wrote:
..........and there they are...thanks for the close-up, Darth
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
HRVW
HRVW is offline
PostPosted: Fri Oct 14, 2011 9:23 am    Post subject: Reply with quote
Smile When first starting to work on bugs in 68-9 had a 40 HP case with a 83 BB kit and a Holly bug spray #300 on a split intake manifold. Two mixture screws and easy to adjust compared to the Zenith with the screws towards the fan housing. Dual cannon exhaust that gave a mellow sound all inside a New dunebuggy I built from a 60 bug...shortened chassis and all.
We learn...don't we?
sactojesse
sactojesse is offline
PostPosted: Fri Oct 14, 2011 9:37 am    Post subject: Reply with quote
Yup, e.g., Zenith 32 NDIX.
1966 Karmann-Ghia convertible
bsairhead
bsairhead is online now
PostPosted: Fri Oct 14, 2011 5:03 pm    Post subject: Reply with quote
So your diaphragm hits the manifold. Rotate it 90 degrees and re-index your plug wires.
