josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Sat Oct 15, 2011 12:52 pm Post subject: |
jmstu76 wrote: |
Seriously? No one has bought these beauties yet? If they don't shed heat, why would Raby offer them. |
He doesn't offer them in bus engines. _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1227 Location: Edmond Oklahoma
Posted: Sat Oct 15, 2011 4:21 pm Post subject: |
josh wrote: |
jmstu76 wrote: |
He doesn't offer them in bus engines. |
True, but I'm sure anyone could buy the set and experiment. _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
SGKent Samba Member
Posted: Sat Oct 15, 2011 4:33 pm Post subject: |
I've been thinking why not use the dual 8 100's that have a nickle - moly finish? They have more surface area cause you have two pistons effectively on one connecting rod. The cooling area is increased and the inner fins are longer. The heads work the same as the dual plugs fire both sides and the top notches allow both sides to breath easily. With those you might see an additional 20 - 40 HP. What say ye James? Should I use those instead? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Oct 15, 2011 6:09 pm Post subject: |
SGKent wrote: |
I've been thinking why not use the dual 8 100's that have a nickle - moly finish? They have more surface area cause you have two pistons effectively on one connecting rod. The cooling area is increased and the inner fins are longer. The heads work the same as the dual plugs fire both sides and the top notches allow both sides to breath easily. With those you might see an additional 20 - 40 HP. What say ye James? Should I use those instead? |
I apologize if I came off the wrong way. I have no clue what dual 8 100's are.. _________________ James
SGKent Samba Member
Posted: Sat Oct 15, 2011 6:25 pm Post subject: |
jmstu76 wrote: |
SGKent wrote: |
I apologize if I came off the wrong way. I have no clue what dual 8 100's are.. |
neither do I - just seeing you'd take the bait _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
