thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Wed Oct 20, 2010 8:56 pm Post subject: |
I used to think that people who ran out of gas were really stupid, but then it happened to me, coincidently while I was trying to do a thousand things at once. the shock of looking down at the fume meter and wondering how long that needle had been there is memorable..with all of these added systems, I care not to attend to them by not having them. power to those who do-- |
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Fri Oct 21, 2011 4:33 pm Post subject: |
Winterize:2011 Version.
Our first frost is expected in Portland, Oregon on Monday. Westy's have no problem with a little frost, but, Just thought I would suggest it is time to drain and treat the tanks for the winter and button things up. For those of us who have the pleasure of driving them year round, share your winterizing tips and tricks!
Since all my Westy stuff is out of the van, I have it easy but will have to think about it when I put it all back together in the coming month or so.
I always fill up my wiper washer fluids to the low temp/won't freeze type. Always do an oil change to my winter weight oil.
Drain tanks and add some RV antifreeze if you are doing it late. Be safe. I always drain mine after the last camping trip of the season and leave the caps of for a week or so, then, seal up and spray a few sprays of bleach water solution in there.
Check tire pressure and adjust for the season.
Check all seals and drains for proper function. I live under a bunch of trees so I must always check the Luggage area up top.
Knocking on wood, have never had mice problems, but do have dryer sheets all over the place in the cabinets and such. No peppermint oil yet, but, sounds Zesty!
What say you? _________________ Happiness=Portland, Oregon in the rearview mirror! |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Fri Oct 21, 2011 10:46 pm Post subject: |
Thanks for the timely reminder. Not a Westy (wish), but I've still got a weak coolant solution in there as the vehicle's still getting sorted. Got a stainless coolant tower on the way, so will be flushing the system for the 8th time since I got it running when I replace that, then filling with proper mix. We're not due for a freeze yet in the forecast.
Gotta get the boat winterized this week, too - along with painting and reassembling the Syncro. Guess which one has my undivided attention and which one will be a last minute fire drill? Heh.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
BillWYellowstone Samba Member
Joined: July 16, 2011 Posts: 767 Location: Yellowstone NP
Posted: Sat Oct 22, 2011 8:32 am Post subject: |
On DVD we use air to purge lines, then the antifreeze (pink stuff) for traps and waste tanks. Never load the water tank, takes a long time to clear taste, plus takes too many jugs.
For west, I drain tank, run pump, pour a little down drain. Easy. _________________ Live Fulltime in motorhome
Have 86 Westy Camper 2.1 rebuilt
Work in Yellowstone NP year round. |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Sat Oct 22, 2011 10:15 am Post subject: |
Around my house we winterize by turning off the AC and opening the windows. Will probably work for the Vanagon as well. Although I may get wacky and store a sweatshirt behind the seat. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
