wyomingresident Samba Member
Joined: April 22, 2007 Posts: 246 Location: Jackson Hole
Posted: Sun Oct 23, 2011 6:17 pm Post subject: |
Pascal wrote: |
Can you get some vice grips on that stud? If so heat around the stud with a propane torch then grab the stud with the vice grips and try to remove it. Are the any threads left in the other stud hole? it does not look like it from the picture. |
I'm hoping to leave the right stud there and only work on the left one.
I'm still bummed, just less bummed. I need to find a battery operated 90 degree drill, a decent bit and the correct easy out. _________________ Don't tell fish stories where the people know you; but particularly, don't tell them where they know the fish.
Mark Twain |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9776 Location: Mt Lemmon, AZ
Posted: Sun Oct 23, 2011 6:33 pm Post subject: |
I once called a shop when I had a broken (non-VW) stud. They quoted me 2 prices to get it out:
If I brought it in now: 20 bucks
If I broke an EZ-Out in it: it will cost whatever it costs (i.e. can't say and it won't be cheap). |
Pascal Samba Member
Joined: January 13, 2006 Posts: 825 Location: Fredericton, NB, Canada
Posted: Sun Oct 23, 2011 6:39 pm Post subject: |
[quote="wyomingresident"I'm hoping to leave the right stud there and only work on the left one.[/quote]
So the left stud is broken inside the hole? I've never seen that before. Can you clearly see it in there? _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16473 Location: Brookeville, MD
Posted: Sun Oct 23, 2011 6:42 pm Post subject: |
Once you use heat on the stud it will harden it and it is a PITA to drill (if you even can). I learned this the hard way on exhaust studs. I'd try drilling out the flush one with progressively larger drill bits until you can chase the threads and put in a new stud. I bought a right angle drill at Harbor Freight for this purpose. Try twisting out the proud stud with a vice grips or other method and if it beaks off then drill it out. Others swear by (at) welding a nut on the stud but the problem is that if it does not work the stud is hardened and it is much worse from there on. YMMV greatly. _________________ Dave O
The Western Syncro build
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7733 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Oct 23, 2011 7:01 pm Post subject: |
Picked up couple sets of these after my injector bracket stud went south.
Alaric likes 'em. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sun Oct 23, 2011 7:15 pm Post subject: |
wyomingresident wrote: |
Pascal wrote: |
I'm still bummed, just less bummed. I need to find a battery operated 90 degree drill, a decent bit and the correct easy out. |
Correction: I'm hoping to leave the intact- left one there and only work on the broken right one. Yes the stud is broken off 3 or so mms down in there.
Aaarrrggghhh! _________________ Don't tell fish stories where the people know you; but particularly, don't tell them where they know the fish.
Mark Twain |
insyncro Banned
Posted: Mon Oct 24, 2011 8:09 am Post subject: |
I have a Snap On extractor set.
It has removed 100% of all broken bolts I have had to extract.
Left handed drill bits are the key
Use a center punch to make sure you start in the center of the stud and not get off track.
Use cutting oil and keep cleaning the hole to remove all fragments.
Good luck |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3424 Location: Dartmouth, Mass.
Posted: Mon Oct 24, 2011 9:30 am Post subject: |
insyncro wrote: |
Great info Dylan!! Can you receommend a set and source?
I bought the screw extractor kit referenced above for future use, might as well get the left handed bits in advance of my exhaust work! _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Mon Oct 24, 2011 4:43 pm Post subject: |
insyncro wrote: |
Good luck |
I borrowed a nice right angle drill from a friend. I had a small cobalt bit and despite the center punch, couldn't keep the drill on track. I was afraid I was catching the block and stopped.
I replaced one of the studs and put it all together again.
How long will it last? I'd like to add the GoWesty Alternator bracket to help solid things up, but there are no holes where it should go.
I guess I'd have to bring it to a shop to get the spots drilled out.
Thoughts? _________________ Don't tell fish stories where the people know you; but particularly, don't tell them where they know the fish.
Mark Twain |
insyncro Banned
Posted: Mon Oct 24, 2011 5:27 pm Post subject: |
vanagonjr wrote: |
insyncro wrote: |
I bought the screw extractor kit referenced above for future use, might as well get the left handed bits in advance of my exhaust work! |
The complete Snap On kits come with the bits and extractors.
I have different sets of of drill bits for many different purposes.
All Snappy.
They are replaced regularly by my Rep without question
Tough little buggers, but they have a tough job and limited life.
The fresher the better in my experiences.
That goes for the bit and extractor. |
Pascal Samba Member
Posted: Mon Oct 31, 2011 3:49 pm Post subject: |
vanagonjr wrote: |
insyncro wrote: |
I bought my left handed cobalt drill bits from McMaster Carr. I could not find any locally. _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
