pinballwiz Samba Member
Joined: September 26, 2009 Posts: 159 Location: Knoxville, TN
Posted: Wed Oct 19, 2011 10:15 am Post subject: Correct lug bolts for AER fake Fuchs |
I need to know exactly what bolts to get to install my American Eagle Fake Fuchs on my 64 type 2. Any ideas and good prices too.
Thanks in advance!!!! _________________ 61 Panel |
Posted: Wed Oct 19, 2011 11:14 am Post subject: |
Oh yeah these are the wide 5's attaching to the factory drums. I am running adapter 4to5 plates on the back but they are the same thread size as the original. _________________ 61 Panel |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Oct 19, 2011 11:57 am Post subject: |
Get out your tape measure and finger it out for yourself! After you've determined the 2 lengths you need for your particular 'setup' proceed to Google 'lug bolts'. BTDT
ezaccessory.com have a good selection @ good prices.
http://www.ezaccessory.com/default.asp _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Thu Oct 20, 2011 4:50 am Post subject: |
Thanks for the tip but I need to know what type of bolt. I know it is 14mm. _________________ 61 Panel |
Posted: Thu Oct 20, 2011 5:25 am Post subject: |
I would imagine it's either a 'ball seat' or a 'cone seat' lug bolt or a 'mag style nut with washer' used with studs. My real 2.0 liter 914 Porsche wheels take a 14mm 'ball seat' lug bolt. _________________ https://imgur.com/user/FisherSquareback/posts
econo_bug Samba Member
Joined: March 03, 2009 Posts: 24 Location: Manila, Philippines
Posted: Tue Oct 25, 2011 3:35 am Post subject: |
It'd be better if you post some pictures of your wheels, so that we can identify if it's ball seat, cone seat or lug bolt with insert washers.
You may want to check this site as well:
http://www.radusadirect.com/product/20-4269-B/RAD-...ex-19.html
I ordered from them a few years back and I'm very happy with their products. |
john7 Samba Member
Joined: August 06, 2003 Posts: 1542 Location: Garden grove ca
Posted: Tue Oct 25, 2011 1:22 pm Post subject: |
pinballwiz wrote: |
Thanks for the tip but I need to know what type of bolt. I know it is 14mm. |
edited to clarify wheels
american eagle wide 5 fuchs use
the wheels use a mag wheel nut with washer. The only problem that you are gonna run into is that the 14mm mag wheel nuts do not fit through the hole in the wheel. you will have to change to 12mm studs or have the wheels redrilled to fit the larger lug (about .050" larger)
if they are the 5x130 pattern fuchs they use a ball seat lug nut just like the original porsche wheels
they have both kind and are very knowledgeable in wheel patterns and lugs
http://www.dubberstoybox.com/dubbersonline/catalog...3_157.html _________________ Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders. |
Tony_Revo Samba Member
Posted: Thu Dec 29, 2011 8:34 am Post subject: Correct lug bolts for AER fake Fuchs‎ |
I have just got set of these wheels and it has taken a bit of time to get them on my 66' bug, for the same reasons as you.
The following details may help you:
http://www.machine7.com/product.php?xProd=10595&xSec=580
Wheel Nut, Mag, M12x1.5, 11/16' OD, 15mm, Flat Washer
Wheel Stud, Screw-in, M12x1.5, 40mm
http://www.machine7.com/product.php?xProd=1161&xSec=582
Please Note:
The Mag Nuts are not 15mm as descirbed at Machine7, they are 16mm (that's what they sent me). Therefore I needed to machine 3mm off them or they hit the drum before the wheel does! I also had to tap clear down to the bottom of the Mag Nuts, so the studs don't seize in them.
Do be careful with flat Mag Nuts (no taper). You really have to torque them up pretty high and without snapping the studs (70-80Ft/Lbs http://www.tirerack.com/wheels/tech/techpage.jsp?techid=107).
Last thing is centre caps. I found some Wolfsburg ones in Calafornia:
http://www.vwparts.net/JM100-1.html
Good Luck and hold on to them. |
rustin peace Samba Member
