Hotrodvw Samba Member
Posted: Sat Oct 29, 2011 8:09 pm Post subject: |
I had my stock, unwelded fan to 7K+ on accident.......it held up. Would I do it again? Heck no. I'm building a new IDA motor, going to weld the fan. I should say, that you can gain a bit of 'buffer' if you will, by running a smaller power pulley at the track to keep that fan from spinning so fast. This of course all depends on what RPM you're shifting at if it's isn't too obnoxious. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sat Oct 29, 2011 8:15 pm Post subject: |
15 years ago I missed a shift and had the stock fan explode. Had to replace the shroud, oil cooler, alternator and fan shroud. Also had 2 fins broken on the right side head. _________________ Glenn
Member #1009
#BlueSquare |
mxracer Samba Member
Posted: Sat Oct 29, 2011 8:42 pm Post subject: |
I tig'ed my T3 fan without issue. There is enough tab bent over at each fin to weld it without filler rod so throwing it out of balance isn't an issue. I had everything from pulley to flywheel balanced and the fan was still dead on after welding it. It's an easy job with a good tig welder and a little skill. If anyone is interested PM me and I'll weld it up for a fraction of the cost of a Berg one. Then you can get it balanced (or at least checked) when you get the rest of the parts done. I also plan to make a jig for my balance machine so I can take care of that part as well. |
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6264 Location: Chickengeorge's Neighbor
Posted: Sun Oct 30, 2011 12:06 am Post subject: |
Didn't research it well enough prior to purchasing one from Kustom1. What a wobbling piece of crap. Will be calling Berg on Monday. Live and learn... |
Posted: Sun Oct 30, 2011 11:24 am Post subject: |
You can prevent some of the fan issues by running a GOOD BELT, "race loose". The fan will hit a speed and won't go faster, even with increasing engine speed. That's one problem with Serpentine Belts, they grip "too well". _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
rkeller Samba Member
Joined: February 15, 2007 Posts: 169 Location: Wake Forest, NC
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 419 Location: Nowhere, USA
Posted: Wed Jan 18, 2012 10:43 pm Post subject: |
I would be interested. There's one.... _________________ Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie." |
torsionbar Samba Member
Posted: Fri Jan 20, 2012 1:21 pm Post subject: |
Hotrodvw wrote: |
So, welding them is the easy part. How does one balance one themselves? I know how it's done, but have any of you done it yourself at home? |
sure, anybody can do it themselves at home. you just need to own a balancing machine. do you have a balancing machine at home? _________________
Max Welton wrote: |
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed. |
Posted: Fri Jan 20, 2012 1:32 pm Post subject: |
I do not. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
catbox Samba Member
Joined: May 16, 2007 Posts: 866 Location: Portland, Oregon
Posted: Fri Jan 20, 2012 1:46 pm Post subject: |
Lawn mower blade balancer....
_________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
Posted: Fri Jan 20, 2012 1:49 pm Post subject: |
Harbor Freight sells balancers..... _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
oldmanmark Samba Member
Joined: July 08, 2006 Posts: 842 Location: n.w. indiana,chicagoland
Posted: Mon Jan 30, 2012 12:21 am Post subject: |
X2 on racin jason. |
adalcanto Samba Member
Joined: July 09, 2005 Posts: 48 Location: San Jose, California
Posted: Tue Jan 31, 2012 1:38 pm Post subject: |
The bottom line is you never want one to explode as it tears things up beyond belief. I had one explode at Sacramento (BOM) and it took out the fan shroud, alternator and broke a few fins off of one cylinder. The noise.... holy crap! My linkage got tweaked and what not. Let’s just say that night I was in the pits doing a teardown and repair with a mediocre fan I bought from a vendor. On race day I pulled the belt so there was no chance of another grenade going off. I now run a Berg fan with a serpentine belt and have taken it up but still uncomfortable with it so I pull the belt when I race. Even if you use a v-belt and run it loose it is risky in my opinion and most time the belt just rolls off and you lose it at halftrack.
1LOW67 |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Wed Feb 01, 2012 11:14 pm Post subject: |
Fully tig welded German fan is the way to go and remember to torque fan nut to 40-45 lbs. |
Joost Samba Member
Joined: December 16, 2011 Posts: 30 Location: Holland
hpw Samba Member
Posted: Mon Feb 27, 2012 3:30 pm Post subject: |
Sounds appropriate due to the weak USD. There are other ways than spending $462.00. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
thebucket Samba Stockbroker
Joined: April 06, 2004 Posts: 3734 Location: Houston Texas
youngstah Samba Member
Joined: December 28, 2008 Posts: 89 Location: california
Posted: Sun Jan 11, 2015 6:20 pm Post subject: fwiw berg doghouse fan 2105 |
After reading this older yet informative thread and speaking w a berg late last year i figured a purchase was in order. It seemed at the time there were only a few German OEM fans hanging around still.
I waited until now to place the order. I thought od share woth you what i received and let you comment: Prumsa (sounds brazilian?)
Im NOT completely on the up and up re good vs bad practices with welded fan production but upon inspection i did notice the following so perhaps you could comment:
- good weld penetration
- it seems filler rod was used
- the veins dont appear to be perpendicular to the axis
- the edges are ground for circumference rounding - is this how its balanced?
- clean bare metal, coated w a wd40 like substance (do folks have theirs painted / powder coated and will this affect the balance?
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Sun Jan 11, 2015 7:40 pm Post subject: |
It certainly does look like filler rod was used. Using a TIG to simply melt the existing tabs over works extremely well though.... _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
