Vanagon H4 headlights into Bay?
germanysfinest
germanysfinest is offline
PostPosted: Fri Nov 04, 2011 8:11 am    Post subject: Vanagon H4 headlights into Bay? Reply with quote
Hi everyone!
I have a set of Euro spec Vanagon H4 headlights. Can these be made to fit a US spec bay? Any hints would be appreciated!
Thanks!
Alex
ned
ned is offline
PostPosted: Fri Nov 04, 2011 8:29 am    Post subject: Reply with quote
If you already have the H4s why not just try and put them in. If they don`t fit, which I think they will, you can always just put your original back in . You don`t even have to do both. You may need the hardware from inside the Vanagon head lite bucket though.
tristessa
tristessa is offline
PostPosted: Fri Nov 04, 2011 8:45 am    Post subject: Reply with quote
.. round lights or rectangular?
copellos
copellos is offline
PostPosted: Fri Nov 04, 2011 8:46 am    Post subject: Reply with quote
go for the rectang....ill get my sawsall...
germanysfinest
PostPosted: Fri Nov 04, 2011 8:50 am    Post subject: Reply with quote
They dont pop right in because of the mounting tabs on them. They are the round units and I took them out of a Vanagon to convert my US Bay to European spec because I just moved back to Europe and took my bus with me Smile.
Just wanted to see if anyone ran into the same problems before.
josh
josh is offline
PostPosted: Fri Nov 04, 2011 8:44 pm    Post subject: Reply with quote
The 7" round headlights sold in the US are for the most part universal fit, even if you buy euro spec lensed ones. I actually pulled a set of euro spec H4s from a Vanagon and installed them in a bus. They fit just like stock.
I wonder if some Vanagons in europe got a different headlight setup. I know some GTIs came with some round headlights that are quite a bit bigger than standard 7".
modok wrote:
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold
