KPK Samba Member
Posted: Wed May 12, 2010 4:26 pm Post subject: Question on the BN4 |
I just bought a 73 Thing and am starting to look at the heater. I noticed in the pictures that there is a small heat shield (or something) that is over the exhaust. Mine doesn't have one - is that a necessity and if so soes anyone know where to get one and how much they cost? |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2515 Location: . . . in denial.
Posted: Wed May 12, 2010 5:53 pm Post subject: Re: Question on the BN4 |
$45 at the Thing Shop.
crofty Judas of the North
Joined: August 09, 2000 Posts: 19319 Location: Land of Whine and Phonies
KPK Samba Member
Posted: Thu Jun 17, 2010 12:06 pm Post subject: Heater fuel pump |
Do you have to pull the gas tank to get to the heater fuel pump? |
Posted: Thu Jun 17, 2010 12:36 pm Post subject: Re: Heater fuel pump |
KPK wrote: |
No but it makes things much easier.
Be a good time to change the fuel lines too. _________________ When in doubt, logo it out!!
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
man130 Samba Member
Joined: August 25, 2008 Posts: 406 Location: long island , ny.
Posted: Thu Jun 17, 2010 12:46 pm Post subject: |
Its fairly easy to get to with the wheel turned, you can see it and reach in. if still have a problem just pull rim off. I see no need to pull tank |
KPK Samba Member
Posted: Fri Jun 25, 2010 7:35 am Post subject: |
Thanks Guys. Appreciate the info and advice. |
Worknclassbug Samba Member
Posted: Fri Nov 26, 2010 9:08 am Post subject: Remove the whole unit from the car to work on it? |
I have a simple question that I haven't been able to find an answer to. There is a ton of heater info on here and it's hard to filter through. Do you have to remove the heater unit from the car to work on it? I need to check the points/cam that controls the fuel pump because when I put a test light on the fuel pump leads I get a constant light on and no pulses like it should according to the manual. I think the nylon gear that has the cam on it may be shot. What is the easiest way to remove the fan assy? Thanks. _________________ 73 Thing
71 Karmann Ghia (2.2L Subaru Conversion)
72 Deluxe Transporter
Huntington WV
Member of The Wagenfolks |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5037 Location: Fair Oaks, CA
Posted: Sat Nov 27, 2010 12:42 pm Post subject: Re: Remove the whole unit from the car to work on it? |
Worknclassbug wrote: |
What is the easiest way to remove the fan assy? Thanks. |
I just posted some pics that might help you at the end of this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=352241 |
Fun 181 Zu Geil!
Joined: October 20, 2006 Posts: 1003 Location: Connecticut
Posted: Fri Jan 07, 2011 8:31 am Post subject: |
FYI-
Updated wiring diagrams for the BN-4 heater have been created by Captain Spalding, and can now be found in the Technical Section of the Samba forums.
Captain Spalding wrote: |
Update Notice:
Date: 1/6/11
New drawing added - Eberspächer BN-4 Ladder Diagram
Describes components of the BN-4 heater and their relationships to one another.
Technical>Wiring>Thing - bottom of the page in the "Other Wiring Diagrams" section.
Special thanks owed this time to "Speedy" Jim Mais, who created the source document, and to Emeritusx, who helped me wrap my head around it. |
Also, here is a related post titled "BN-4 Heater Timer" and addresses a few electrical issues regarding the heater which may be helpful...
http://www.thesamba.com/vw/forum/viewtopic.php?t=445667 _________________
Ian Epperson wrote: |
Holy poop, that's full of awesome! |
oasis Samba Member
Posted: Sat Jan 29, 2011 2:21 am Post subject: |
Can a gas heater be made to work with a fuel cell that replaced a gas tank? _________________ Now: 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 2003 New Beetle Turbo S / 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
Posted: Sat Jan 29, 2011 11:57 am Post subject: |
oasis wrote: |
Can a gas heater be made to work with a fuel cell that replaced a gas tank? |
I don't see why not as long as all the controls are there. The fuel cell must be positioned in such a way that fuel is fed the the heater fuel pump via gravity. If you are thinking of setting up a heater to run elsewhere than in the vehicle, you should take particular car regarding the combustion intake and exhaust, so that you are not burning the air you are breathing nor polluting it with the heater exhaust. |
Posted: Sat Jan 29, 2011 7:02 pm Post subject: |
We finally had a day above freezing here and I took advantage of it to work in the garage. I got a new (used) exhaust pipe and some other parts for my heater and installed them and fired up the heater for the first time. After I let it run for a few minutes with the fuel line off to get gas pumped up to the end of the line I connected the fuel line and the heater fired right up and ran great for about a minute and then I could hear the flame kind of intermittently going out for a second or two. Then after a couple of minutes the safety relay tripped and the heater stopped. I reset the relay and the heater restarted and was still having intermittent flame outs every few seconds and the safety relay tripped again. Is this possibly because of air in the line and is the safety relay tripping because the chamber isn't getting up to temperature? I'll try to let it run tomorrow with a clear fuel line on it so I can watch for bubbles. _________________ 73 Thing
Huntington WV
oasis Samba Member
Posted: Mon Jan 31, 2011 11:49 am Post subject: |
oasis wrote: |
I don't see why not as long as all the controls are there. The fuel cell must be positioned in such a way that fuel is fed the the heater fuel pump via gravity. |
Thanks. I imagine if/when I get to that stage, I will consult the fuel cell manufacturer.
I'm not sure if I understand you here. Do you mean running the heat from from the Thing to an external place such as a tent? If so, I have no such intentions. If you meant taking a gas heater and adding it to a '74, I may want to do that if I get a '74. Under such a circumstance, I would also add the ductwork the '73 had and have dual heat (so to speak) with a gas heater as one option and heater boxes as the other option. I have been taking note of another thread that has that possibility in the works.
Thanks again. _________________ Now: 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Posted: Wed Feb 02, 2011 7:08 am Post subject: |
We finally had a day above freezing here and I took advantage of it to work in the garage. I got a new (used) exhaust pipe and some other parts for my heater and installed them and fired up the heater for the first time. After I let it run for a few minutes with the fuel line off to get gas pumped up to the end of the line I connected the fuel line and the heater fired right up and ran great for about a minute and then I could hear the flame kind of intermittently going out for a second or two. Then after a couple of minutes the safety relay tripped and the heater stopped. I reset the relay and the heater restarted and was still having intermittent flame outs every few seconds and the safety relay tripped again. Is this possibly because of air in the line and is the safety relay tripping because the chamber isn't getting up to temperature? I'll try to let it run tomorrow with a clear fuel line on it so I can watch for bubbles. |
In case anyone is interested, I was getting a lot of air bubbles. I only put about a gallon of gas in the tank to begin with and I think that was the culprit. I filled the gas tank about half full and let it sit for a while to work out the air that was trapped in the new fuel filter. I tried the heater again and it worked great. Thanks for all of the advice. _________________ 73 Thing
Huntington WV
nateairman Samba Member
Joined: January 26, 2008 Posts: 30 Location: Wet Coast BC
Posted: Thu Mar 17, 2011 6:40 pm Post subject: BN 4 Fuel |
I am in the process of repairing a BN 4 and have a few questions:
1. What do I replace the braided lines with?
2. There seems to be a bit of the fan missing and it vibrates slightly. Is it balance able? I had to put new bushings in the motor....
Great thread Thanks to everyones input! _________________ Nathan
69 Westy "Pearl" Stock |
fyter889 Samba Member
Posted: Mon May 16, 2011 1:10 pm Post subject: bn4 early model with reciprocating fuel pump and |
a separate pressure regulator. Ok heres my problem, fuel pump inop, got 12v there, has been dissassembled cleaned etc. My question is, does anyone know what the fuel pressure is supposed to be going into the combustion chamber? I am looking at several types of pumps to try to update this unit a little. I see on some of the posted photos in this thread that there are no pressure regulators on those heaters, mine sits just aft of the intake fan forward of the coil and plugs on the outside of the main body. Any help would be appreciated. BTW this unit does run if I manually run the points on the back of the pump. |
analogmax Samba Member
Joined: September 27, 2006 Posts: 161 Location: Chandler, Arizona
Posted: Sat Nov 05, 2011 11:09 am Post subject: |
my fuel pump was not working at all, I had voltage but no click. I pulled it and cleaned it but still no good. I ended up spraying some carburetor cleaner in it and the next day it was working great. |
jwillhoit Samba Member
Joined: August 04, 2009 Posts: 10 Location: Long Beach, CA
Posted: Tue Nov 22, 2011 4:16 pm Post subject: |
I'm looking for a someone to rebuild my BN4 gas heater. If anyone knows anyone that offers this service, please let me know. Thanks |
Posted: Tue Nov 22, 2011 6:20 pm Post subject: |
jwillhoit wrote: |
Give Greg and Arda at German Motor Works a call. I bet they can do it for you. They're in Garden Grove. (714) 534-1841 |
