Bumper End Caps-installation repair
T25 Pilot
T25 Pilot is offline
PostPosted: Thu Nov 24, 2011 7:58 am    Post subject: Bumper End Caps-installation repair Reply with quote
Bumper end caps very often have their inner mounting tabs broken off leaving you with a very loose piece ready to fall off. This repair involves drilling holes into the cap's "hole markings",
which line up perfectly with the bumper holes, then installing them with the hardware shown. No redrilling of the bumper holes was required.
Using the side OEM screw further helps to stabilize the end cap.
Hope this helps, and Happy Thanksgiving!
-T25 Pilot
1999 MKIII Jetta
1984 1.9L Vanagon
1972 Super Beetle
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Thu Nov 24, 2011 8:17 am    Post subject: Reply with quote
Nice job, well done. Funny how some bumpers have a carriage bolt in that square hole, and some don't.
alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
seanjenn
seanjenn is offline
PostPosted: Thu Nov 24, 2011 10:35 am    Post subject: Reply with quote
Looks good.
My black bumpers have a hole in them that lines up with the carriage bolt hole on my end caps, so that's how I attached mine.
...and if you do use carriage bolt, don't over tighten Cool
1987 GL Sunroof
2.1 4 spd
joseph928
joseph928 is offline
PostPosted: Thu Nov 24, 2011 10:45 am    Post subject: bumper caps Reply with quote
Looks great good cost and less calories its a winner. Now only if I still had stock bumpers. Blue Bay Bus
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
rubbachicken
rubbachicken is offline
PostPosted: Thu Nov 24, 2011 11:04 am    Post subject: Reply with quote
from experience i'n not bother with the screw into the body, i've had to replace many, when i lived in london
without the screw into the bodywork, if it gets bumped something breaks, it it's only fixed to the bumper it's got more flex
more flex = less breakage = less $$
lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182
IdahoDoug
IdahoDoug is offline
PostPosted: Thu Nov 24, 2011 1:36 pm    Post subject: Reply with quote
I installed mine to the body as well and have a tip for that to add.
Due to me straightening the bumpers before putting them back on, the holes were sometimes a quarter inch out of line and I frustrated myself trying to pull on the bumper and screw it in. Hit on the idea of using a motorcycle strap (ratcheting type) or a hand winch. That way you can pull it into position, then in a leisurely fashion put the screw back in the body. Much less drama. Less filling.
That's a good point on the allowance for flex. However, I'll be driving my Syncro offroad and was worried the unsecured bumper tips would easily hook on brush and get pulled away from the body - cracking my new tips. So I put a little time into securing them agains that.
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader
ragnarhairybreeks
PostPosted: Thu Nov 24, 2011 1:40 pm    Post subject: Reply with quote
DougM
yes, that happens, grr.
alistair
IdahoDoug
PostPosted: Thu Nov 24, 2011 1:43 pm    Post subject: Reply with quote
Heh- thought so. I was going to leave them unsecured and then a revelation in the form of an extension cord hooking a rear one as I walked around the van made me go "Hmmm, that would suck if it happened in the brush..."
Doug
vanagonjr
vanagonjr is offline
PostPosted: Thu Nov 24, 2011 5:38 pm    Post subject: Reply with quote
Good point - rust place as well. Some modern cars have a plastic tab that snaps into a square hole in the sheet metal. Then a thread forming screw for plastic threads into the a round hole in the center of this plastic tab. I was thinking that would have been a better way to attach to the body.
[img]
[/img]
WVVWFERG
WVVWFERG is offline
PostPosted: Fri Nov 25, 2011 7:49 am    Post subject: bumper Reply with quote
T25 pilot: what is the source of the plastic "harware" used? Nice tip; thanks.
vanagonjr
PostPosted: Fri Nov 25, 2011 12:50 pm    Post subject: Reply with quote
Might be easiest to ask your Ford dealer, else try here http://www.pointe-products.com/itemclass/Ford-Fasteners-and-Clips
Edit - sorry, I thought you were asking about my post with the square clip for the fender, even though you said T25pilot and meant the clips into the steel bumper Embarassed
randywebb
randywebb is offline
PostPosted: Fri Nov 25, 2011 1:12 pm    Post subject: Reply with quote
IdahoDoug wrote:
... I'll be driving my Syncro offroad and was worried the unsecured bumper tips would easily hook on brush and get pulled away from the body - cracking my new tips.
You need to fab up some separate Bull Bars -- just for the bumper end caps.
(who designed these things anyway?)
1986 2.1L Westy 2wd Auto Trans.
T25 Pilot
PostPosted: Fri Nov 25, 2011 5:45 pm    Post subject: Bumper End Caps-Installation Repair Hardware Reply with quote
WVVWFERG,
I'm pretty sure I got these from Autozone. Don't have the packaging for them but I think the brand was Dorman. Dimensions are approximately
1/4" diameter by 7/8" in length(bottom of "cap" to tip).
Hope this helps.
WVVWFERG
WVVWFERG is offline
PostPosted: Fri Nov 25, 2011 6:56 pm    Post subject: bumper Reply with quote
Many thanks Pilot; that will be an easy item to find (Auto Zone & Advance Auto both nearby)> Kim
jungle dog
jungle dog is online now
PostPosted: Wed Nov 08, 2023 11:46 am    Post subject: Re: Bumper End Caps-installation repair Reply with quote
Good Day.
Did you do anything to fill in the rhombus hole, without drilling a new hole in the bumper?
Thanks,
J
