busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Thu Sep 16, 2010 7:59 am Post subject: CV Joint Orientation Information GKN Lobro |
Due to conflicting information all over the web and this site as to which way to orient the CV Joint for installation I contacted the GKN Driveline factory to get the final word, at least for GKN Lobro CV Joints. Per the email I received with the drawing, the single line side goes to the shaft and the three line side goes to the flange. the center hub on the single line side also has a chamfer and the three line side of the center hub is flat cut with no chamfer.
Below is the drawing and pictures of a GKN Lobro CV Joint from both sides.
Jalabert Samba Member
Joined: December 06, 2005 Posts: 632 Location: On the coast in NZ, somewhere...
Posted: Thu Sep 16, 2010 12:24 pm Post subject: |
That's awesome work. Maybe this could be merged with the thread with the link that aeromech put up showing how to reassemble a CV and made into a sticky...? _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
'73 westy, 1700 type 4 with 34icts |
babysnakes Samba Member
Posted: Fri Oct 15, 2010 7:08 am Post subject: |
Thanks for posting this. I packed my new lobros last night, planning on mounting them today. This was my question. |
Desertbusman Samba Member
Posted: Tue Mar 15, 2011 5:49 pm Post subject: |
I've never seen a joint with 3 grooves on one side. And that single groove is opposite the flange. Most joints only have one groove. And depending on the source, that single groove sometimes is inside and sometimes is outside. _________________ 71 Superbug
71 Westy |
Posted: Tue Mar 15, 2011 6:43 pm Post subject: |
These were Lobro's, as for other off brands I have no idea. |
SGKent Samba Member
Posted: Tue Mar 15, 2011 7:41 pm Post subject: |
The ones we had also show 3 and 1. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
curtis4085 Samba Member
Posted: Wed Nov 30, 2011 8:45 pm Post subject: |
So my Lobros came today in the mail so I figured this should be a fun messy project. Well have a few questions. I had to use a large round cylinder to help drive the CV joint onto the axle. One side went on pretty smooth and the other I had to give her a few hard taps to get her all the way seated back. Other thing to note is the one side that went on hard the circlip fit real nice and tight. The other easy side the circlip spins and seams lose I need to get some longer handled pliers to tighten it up. Where did I go wrong. ANy pointers? _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Wed Nov 30, 2011 9:01 pm Post subject: cv joints |
Way back when i was a tech i would put the new CV's up inside the shop heater in the winter time to warm them up before installing them.
Curtis,
As for the loose circlip if you have up and down play even with the new style joints that have the "built in thrust surface" you may still be able to install one of the old washers to remove the excess play.
Or, if you are saying the Snap ring is just to loose take it off and bend it a little. _________________ V.W.owner since 1967 |
Posted: Wed Nov 30, 2011 9:10 pm Post subject: Re: cv joints |
old DKP driver wrote: |
Curtis,
Or, if you are saying the Snap ring is just to loose take it off and bend it a little. |
not much or any play in joint to circlip. the circlip after install i could not squeeze tight. it spins in the grove. What do people use to pinch these thing together _________________ Special Thanks to:
Posted: Wed Nov 30, 2011 9:19 pm Post subject: |
Pince it before putting it on or much better yet is a new one. Was the groove in good shape? _________________ 71 Superbug
71 Westy |
Posted: Wed Nov 30, 2011 9:29 pm Post subject: |
Desertbusman wrote: |
Pince it before putting it on or much better yet is a new one. Was the groove in good shape? |
yep new..maybe I open it to far during installion. I will pull it off and try to tighten it up and reinstall. I had to call it a day. Way messy job. Thank god for rubbe gloves and shop towels. And I for got to change clothes into something I could toss. To excited to get the job going. _________________ Special Thanks to:
Posted: Wed Nov 30, 2011 9:32 pm Post subject: |
I bet you learned the importance of taking a leak and turning off the phone before you started. _________________ 71 Superbug
71 Westy |
Posted: Wed Nov 30, 2011 9:34 pm Post subject: |
I bet you learned the importance of taking a leak and turning off the phone before you started. |
so true. Learning all the way. And i have made similar boo boo when the with comes in the shop and breaks my stride. _________________ Special Thanks to:
SGKent Samba Member
Posted: Wed Nov 30, 2011 10:03 pm Post subject: |
one of the first reads for sure. and many threads and bently. and you tube. It seems i may have done ok. I am so hard on myself, want perfection all the time. For it being my first axle rebuild it will insure my next is near perfect. I hope. _________________ Special Thanks to:
Brionp Samba Member
Posted: Wed Nov 30, 2011 10:28 pm Post subject: |
And while we are on the subject I just wanted to share this:
For all the tool geeks out there. These are some old craftsmen snap ring pliers, or reverse pliers. They haven't been made for a while. But you can still find them on Ebay. And you would think they were custom made for the circlips. Some even have dimples on the tip that hold the clips that much better. |
porschpow Samba Member
Joined: May 21, 2005 Posts: 1256 Location: Hamilton, NJ / Flanders, NJ
Posted: Mon Mar 12, 2012 5:21 am Post subject: |
Good stuff. Thank you very much for this. I will be putting new boots on my bus and while I am there I will repack the bearings. I am assuming I need to clean off the old grease before I repack it, correct? _________________ -1973 Volkswagen Bus Westy (Weekender)
1.8 liter from 1.7(original)
-2011 Subaru Outback
-1986 Honda Magna |
SGKent Samba Member
Posted: Mon Mar 12, 2012 7:37 am Post subject: |
porschpow wrote: |
I am assuming I need to clean off the old grease before I repack it, correct? |
yes. Dry and inspect too. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Durk Samba Member
Joined: February 08, 2010 Posts: 14 Location: Kalispell, Montana
Posted: Wed Nov 06, 2013 7:55 pm Post subject: |
This post started years ago because of conflicting information I saw about proper CV joint assembly. There is still conflicting information out there, but in my assembly I'm going with the orientation provided by the original poster who contacted the GNC Lobro factory directly. I had been following the Van Cafe writeup on CV joint assembly until it seemed to conflict with other information on orientations of the 3 main parts. Also, the Van Cafe article shows a Lobro joint with only one groove on the outer ball hub, and the ones I just received from them have 4 grooves total.
There seems to be no dispute that the chamfered edge of the ball cage goes in, or toward the axle. What seems to differ is which side of the inner ball hub goes in. It seems to me that the Van Cafe article is showing what I believe to be the wrong direction to install the inner ball hub, with the more rounded edge toward the axle. When I called Van Cafe I was told that the more rounded edge faces out, or away from the axle which is what the Lobro factory said. Also, Van Cafe said that it doesn't matter at all which side of the outer ball hub goes in or out. Like I said, I was following the Van Cafe writeup, but am glad I found this post because I think this is the correct way. Any comments? |
Posted: Wed Nov 06, 2013 10:08 pm Post subject: |
Durk wrote: |
What seems to differ is which side of the inner ball hub goes in. |
I.D. chamfer towards the shaft and flat end with no chamfer against the clip. And the sharpest edge of the clip towards the shaft end and not against the hub.
But I don't think any of the CV's on either my bug or bus have Lobros. At least I don't think any have 4 outer grooves. _________________ 71 Superbug
71 Westy |
