DannoT Samba Member
Joined: September 15, 2007 Posts: 249 Location: Up where the air is thin
Posted: Wed Nov 16, 2011 12:42 pm Post subject: Starting Issue - turns over but wont catch |
Ok Ive been working out kinks in my 67 for about two months now, It started when I pulled my engine to replace the clutch and throw-out bearing, after that I had two stripped holes on a rear drum and after a sh#%y brazilian drum blew out the rear seal, I got a good old german drum. After that the bus runs and drives fine but at odd times it wont start. Its a dual carb 1914, hooked to a freeway flyer with rgb's and when I try to start it the engine turns over but wont catch. so I went through the engine and checked everything, Points are good, timings good, carbs are good and tuned, alternators and battery are good, valves adjusted, solenoid is good, and starter is good. The car will sometimes start just fine and other times when it wont a jump will get it to catch and start. The fuel pump is good as it runs fine once going and the carbs aren't starving for fuel. The starter has a normal amp load when starting so i don't think the brushes are worn. I am thoroughly stumped, any one have any good ideas on what could be the problem? |
quartermilecamel Samba Member
Posted: Wed Nov 16, 2011 1:23 pm Post subject: |
Yeah. What are you not getting during this no start condition? Spark, or fuel? _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
DannoT Samba Member
Posted: Wed Nov 16, 2011 1:34 pm Post subject: |
Its getting fuel because I can flood it while pumping the gas when its turning over trying to start, the spark plugs are only a year old, I haven't checked their spark while starting but I assume they are sparking because the bus runs fine once going its just getting it going that is the current issue. Ill check the spark when I get home but I'm fairly confident they are sparking when it tries to start. |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Wed Nov 16, 2011 6:58 pm Post subject: |
Check the choke and remove the spark plugs to see how rich the engine is. _________________ Don't worry; be happy. (Baba) |
Tim MacDonald Samba Member
Joined: October 11, 2004 Posts: 1346 Location: Edmonton alberta
Posted: Wed Nov 16, 2011 7:05 pm Post subject: |
Could it be the cap or rotor button? _________________ 61 so34 flip seat
78 automatic champagne Westfalia
84 mint original paint westfalia
57 oval project barn find
88 cabriolet |
ricekooker Samba Member
Joined: April 09, 2006 Posts: 1788 Location: Winter Park, FL
Posted: Wed Nov 16, 2011 7:28 pm Post subject: |
Try another coil. |
mpribanic Samba Member
Joined: October 25, 2004 Posts: 3177 Location: Neptune Beach, Florida
Posted: Thu Nov 17, 2011 10:26 am Post subject: |
I've been having the same issue. It was a bad ground on the battery. _________________ Call your Cunado's:
https://vimeo.com/67661950 |
Robertjm Samba Member
Joined: May 22, 2011 Posts: 261 Location: San Francisco Bay Area
Posted: Thu Nov 17, 2011 11:03 am Post subject: |
Fuel getting funky? How old is it? _________________ 1967 VW Double Cab Pickup
2003 Mercedes ML-500
1995 Saab 900SE Turbo Convertible (Crossed over into Valhalla April 2014)
1972 VW Squareback (Autobahn in the Sky - July 1987) |
61TXghia Samba Member
Joined: July 17, 2009 Posts: 950 Location: El Paso, TX
Posted: Thu Nov 17, 2011 10:22 pm Post subject: |
mpribanic wrote: |
I've been having the same issue. It was a bad ground on the battery. |
How did you catch this? _________________ 62 Standard Type 2 (Nothing Fancy)
my bus: http://www.thesamba.com/vw/forum/viewtopic.php?t=464719
bill may wrote: |
Camping is cheaper than therapy. |
Posted: Fri Nov 18, 2011 3:56 am Post subject: |
61TXghia wrote: |
mpribanic wrote: |
How did you catch this? |
By taking the ground strap off & cutting 1" off of the end and re crimping it. I then relocated the ground wire to a bolt. Just below the engine lid prop. The original set up was crusty/ rusty and behind the battery were I couldnt see it until I pulled the battery. _________________ Call your Cunado's:
Posted: Fri Nov 18, 2011 8:15 am Post subject: |
mpribanic wrote: |
61TXghia wrote: |
mpribanic wrote: |
By taking the ground strap off & cutting 1" off of the end and re crimping it. I then relocated the ground wire to a bolt. Just below the engine lid prop. The original set up was crusty/ rusty and behind the battery were I couldnt see it until I pulled the battery. |
If I set my Volt Meter to test continuity, touch the end of the ground cable that goes to battery and the lug on my motor, it beeps showing continuity, should this tell me I have a good ground? My battery is gounded right under the engine lid prop also. _________________ 62 Standard Type 2 (Nothing Fancy)
bill may wrote: |
DannoT Samba Member
Posted: Fri Nov 18, 2011 1:21 pm Post subject: |
Ok so after some more work I achieved nothing Its getting gas and spark fuel is good and battery ground is fine. After driving the bus for two days Its starting about 80% of the time, sometimes it will start after sitting all night sometimes it doesn't. Ill drive it for a while stop at the groceries store start it go to a gas station then it wont start after filling up, though that's not the problem because it has started at most gas stations. I'm going to test the compression next but for now I'm just making a habit of parking on hills |
Dontburnit Samba Member
Posted: Fri Nov 18, 2011 1:35 pm Post subject: starting trouble |
If it push starts, I doubt that its a compression issue.
http://www.cip1.ca/PhotoGallery.asp?ProductCode=ACC%2DC10%2D5767
After years of the same trouble with my bug, and trying everything from soup to nuts, the high torque starter found above is the cats a** solution. It spins over faster and has more torque - the motor started every time (until I accidentally burnt it )
Some guys will tell you to install a bendex in your starter wiring to give your factory starter the extra juice it really needs to do the job - just more parts to wear out.
I replaced the battery, relocated the fuel filter, installed and electronic fuel pump, replaced the carb, points, condenser, coil, plug wires, installted platnum spark plugs, tore my hair out trying to figure this out. Just needed a better starter. _________________ What can we build for you?
Contact Kevin today. 205 750 2705 |
DannoT Samba Member
Posted: Fri Nov 18, 2011 1:42 pm Post subject: |
It could be the starter though I don't think that's the problem because when it does start it usually catches on the first crank, and when it doesn't start it will turn over and over and may give a slight sputter when I stop turning the engine over. |
Posted: Fri Nov 18, 2011 3:25 pm Post subject: |
DannoT wrote: |
I didn't think so either, for a long, long time. I was wrong. _________________ What can we build for you?
Posted: Sat Nov 19, 2011 9:21 pm Post subject: |
I am thinking I have the same issue, my awesome O'reillys starter can barely turn my motor. My ghia was doing the same thing, but it turned out my ignition switch was giving out. When I would switch on my ignition, I had 12 volts at the coil, when cranking it would drop to 9 volts. I replaced my ignition switch and it fixed it. I am having the exact problem right now with my bus. _________________ 62 Standard Type 2 (Nothing Fancy)
bill may wrote: |
DannoT Samba Member
Posted: Mon Dec 05, 2011 8:47 pm Post subject: |
Well I finally fixed it, i didn't want to jinx it by posting on the samba to soon but after going through everything 10 times I found i had bad continuity in the center button in the distributer cap. So i went to checkers and bought a new one for a whopping 6 bucks and I'm back in business. |
Posted: Mon Dec 05, 2011 9:10 pm Post subject: |
Tim MacDonald wrote: |
Could it be the cap or rotor button? |
Man, Tim had it. Good job on fixing it. I bet you learned alot about your bus, LOL _________________ 62 Standard Type 2 (Nothing Fancy)
bill may wrote: |
