AlteWagen Troll
Posted: Thu Dec 15, 2011 3:55 pm Post subject: Official Upright fan shroud thread |
WORK IN PROGRESS!!! PICS ADDED AS FOUND. If you have better pics please post.
25hp shroud
seamed at top of shroud
KDF shroud
1946/1947
Manual lever for "summer/winter"
Listed from PR
1947 Cooling air throttle ring
previously slide
March 1949 Now without throttle ring
May 1950 Automatic cooling air regulation
previously throttle ring with swing handle
December 1951 Throttle ring spot welded
previously screw mounted
September 1952 Throttle ring support guide projected for operating shaft
previously recessed
Oct 1953 Fan blade increased to 1.5mm thick
previously 1.25
36 hp shroud
Throttle control ring and thermostat
Aug 1959 Fan bore diameter increased to 28mm
previously 20mm
Nov 1960 Fan now has 28 blades with 20mm bore diameter
previously 16 blades 28mm bore diameter
40hp stale air shroud
Transitional?
Note holes for plug wires and choke
May 1961 Throttle ring rubber stop now increased to 8-9mm
preciously flat
1961-1962
Note cutout for air cleaner no choke hole
July 1962- December 1962
Non fresh air with larger housing
PR lists
Fan housing/fan
Now: Modified shape increased
cooling air throughput
63-70 fresh air shroud
Uses upright oil cooler
April 1964 Cooling flaps replace throttle ring
August 1964 Cooling flaps replace throttle ring (Type II)
71-74 dog house shroud
Type I used a large negative oil cooler slot
Type II used a large positive oil cooler slot similar to a thing shroud (1971 only)
2 piece oil cooler exhaust ducting
All important hoover bit bolted to oil cooler to seal shroud and direct air through cooler
Thermostat flap rod changed due to dog house addition
Doghouse shroud with modified fresh air outlet for use with A/C
Different left side A/C fresh air outlet
73 thing shroud
One year only for export
Non fresh air heat
Uses large positive oil cooler slot
Early FI shroud
Large neagative slot
Velosity ring on back
Late FI shroud
Small peanut oil cooler slot
Puma shroud
Low profile
Non fresh air heat
Large negative oil slot
Both upright and doghouse versions available
Doghouse type has enclosed oil cooler with round exhaust outlet with matching front tin
Brazilia shroud
Low profile
Fresh air heat
torsionbar Samba Member
Posted: Thu Dec 15, 2011 4:18 pm Post subject: |
excellent, nice work! _________________
Max Welton wrote: |
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed. |
KopfenJager Samba Member
Posted: Thu Dec 15, 2011 4:50 pm Post subject: |
And I wast just going to take a pic and post, asking what shroud do I have, but I see it is a 1963 Type II 1500
Non fresh air with larger housing . Sweet. Soon off to Don's powder coating. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Thu Dec 15, 2011 5:09 pm Post subject: Re: Official Upright fan shroud thread |
derluftwagen wrote: |
that is a late model FI fan shroud.
note the venturi ring, coil & throttle cable location _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Thu Dec 15, 2011 5:11 pm Post subject: |
Very cool thread..... _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
danielsan Samba Member
Joined: September 18, 2008 Posts: 802 Location: Carson City, NV
Posted: Thu Dec 15, 2011 5:15 pm Post subject: |
Nice thread.
Puma shroud cooling flap linkage and puma shroud return spring. (German spring shown so you can compare)
Posted: Thu Dec 15, 2011 6:03 pm Post subject: Flaps? |
Does anybod know if a 1963 Type II 1500 Non fresh air with larger housing originaly come with flaps and a thermostat? The one I scrounged out of a scrap pile doesn't have them on it. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Thu Dec 15, 2011 6:17 pm Post subject: |
Thermostat yes, flaps no, they use the control ring _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
jl_1303 Samba Member
Posted: Thu Dec 15, 2011 6:29 pm Post subject: |
Out of interest, does anyone know if these seals are still available anywhere?
Posted: Thu Dec 15, 2011 7:02 pm Post subject: |
Ok, where do I get the ring and thermo? |
Posted: Thu Dec 15, 2011 7:47 pm Post subject: |
Brasilia shroud:
Tube for charcoal chamber. Uses the German style exhaust. No Kadron linkage slot. Fresh air tubes do not have an indentation that allows the Kadrons the clear the tubes.
Photo of the stock puma with the provisions for the fuel lines and the Kadron linkage attached:
SRP1 Samba Member
Posted: Thu Dec 15, 2011 7:58 pm Post subject: |
jl_1303 wrote: |
The two metal pieces CB Performance has, and they come with the rubber
seals. I would bet they have the rubber pieces available seperatly too.
http://www.cbperformance.com/catalog.asp?ProductID=274
The soft seals are nothing more than foam weather stripping availble at
you local hardware store, home depot, etc... |
Almost Alive Samba Member
Posted: Fri Dec 16, 2011 12:23 am Post subject: |
WOW! Long overdue my friend. I LOVE this post. |
74 Thing Samba Member
Posted: Fri Dec 16, 2011 12:34 am Post subject: |
Can you clarify with maybe an explanation or close up photo between the difference of a positve vs negative oil cooler slot?
Thanks |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6032 Location: CONGERS, N.Y.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Fri Dec 16, 2011 8:06 am Post subject: |
nextgen wrote: |
What fantastic amount of information.
I vote his post be a permanent information listing.
Excellent.
I like the Venturi Ring, ha!!!! |
Added to the FAQS/Sticky.
Now if only people would look at it before posting _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Dec 16, 2011 9:37 am Post subject: |
Glenn wrote: |
nextgen wrote: |
Excellent.
Now if only people would look at it before posting |
Well deserved. |
AlteWagen Troll
Posted: Fri Dec 16, 2011 12:39 pm Post subject: Re: Official Upright fan shroud thread |
borninabus wrote: |
note the venturi ring, coil & throttle cable location |
Fixed! |
AlteWagen Troll
Posted: Fri Dec 16, 2011 12:43 pm Post subject: |
74 Thing wrote: |
Thanks |
Negative oil slot (inverted scoop)
Positive oil slot (scoop)
Joost Samba Member
Joined: December 16, 2011 Posts: 30 Location: Holland
Posted: Fri Dec 16, 2011 1:47 pm Post subject: |
Wich is better the late or early FI shroud?
The early shroud looks to be better due to the large slot,
But there must be a reason why they changed right?
I have got two late FI shrouds and one normal doghouse shroud with large negative slot, can i remove the venturi and weld it too the normal shroud as too have better cooling? |
