Posted: Thu Jun 05, 2003 5:08 pm Post subject: Factory Jack |
In planning for my cross country trip in my bus I have been testing my equipment. This is my question: When I put the factory jack in the jackpoint it does not stand completely parallel to the side of the bus, instead it is angled so that the bottom of the jack is somewhat closer to the bus, Is This Normal? Do I have the wrong jack (from a beetle or something)? It doesn't look right/safe. If the following brackets represent my bus the comma is the jack angled inward--> [], that's what it looks like.
Thanks, John |
bugster1226 Samba Member
Posted: Thu Jun 05, 2003 5:26 pm Post subject: Factory Jack |
I have a 70 bus and the jack looks just like yours. It works very good. I think the reason it leans inward is when you jack the bus up, the jacking receptical tilts to the horizontal position??? |
westy78 Samba Member
Joined: August 20, 2002 Posts: 2005 Location: Portland OR
Posted: Thu Jun 05, 2003 5:48 pm Post subject: Factory Jack |
Yep mine did the same thing. I say did, because I once used it without blocking the wheels and the Bus began to roll forward as I lowered it. Luckily I had already put the tire back on. It twisted the jack but thankfully didn't tweak the jack port on the Bus. USE WHEEL BLOCKS! This was also on a level concrete driveway. If you go here about one quarter down the page http://busdepot.com/asp/ResultsSpecials.asp?VehCod=C&B1=Search they sell a genuine VW scissor jack that is more stable. That is if your bus is a '72-'79 I just got mine and looks like it will work much better than the stock jack.
Jasan C.
'78 Westy
Portland OR. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Fri Jun 06, 2003 9:36 am Post subject: Factory Jack |
The stock jack, the early ratchet style or the later wind-up style, although both made by Bilstein are not safe to use.
I bought the same BD scissor jack about a year ago: very sturdy, very handy. It's a great deal. I usually put a large block of wood under it to get it started because it takes a while to wind it up to height and has a limited reach like any other jack. |
Posted: Fri Jun 06, 2003 12:04 pm Post subject: Factory Jack |
I had the same problem with our original jack too. Did not stand straight up. It kinda freaked me out. Well needless to say while jacking her up one day, the weld that held that bar that goes into the jack point failed and popped. The circular piece (once welded) began to split the higher I jacked her up. Luckily I had not taken the wheel off and I brought her down safely and pitched that thing. Bought one of the scissor kind and like it alot better! Much safer.
Paul
'78 Westy |
Posted: Fri Jun 06, 2003 4:15 pm Post subject: Factory Jack |
Ok thanks for the info. I was getting a little worried that I had the wrong jack in my bus, but instead it appears that I have a poorly made/designed original jack. Thanks again, John |
