EverettB  Administrator
Joined: April 11, 2000 Posts: 71882 Location: Phoenix 602
Posted: Mon Jan 09, 2012 6:01 pm Post subject: '63 Squareback rear brake layout |
I pulled apart the rear brakes on my '63 and I'm pretty sure the e-brake arms are on the wrong side of the shoe?
My car:
Shop manual:
The shop manual shows the e-brake arm on the OUTSIDE of the brake shoe, not the inside. Parts book is hard to tell but it looks that way too.
The clip for the top spring is backward too.
Just wanted some confirmation before I reverse everything. _________________ How to Post Photos
supaninja Samba Member
ibjack Samba Member
Joined: February 06, 2002 Posts: 2117 Location: Imperial Beach CA
Posted: Mon Jan 09, 2012 7:27 pm Post subject: |
I think you have the wrong brake shoes. I'm almost positive that those are correct for the early cars on the front only. They ebrake set up should have the lever on the front of the shoe. _________________ '65 T346 RHD sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
1500 Club OG
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Mon Jan 09, 2012 7:39 pm Post subject: |
Should be like the shop manual, but likely not causing any harm. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
Brent Samba Member
Joined: April 28, 2010 Posts: 1622 Location: San Tan Valley, AZ
Posted: Mon Jan 09, 2012 7:47 pm Post subject: |
Is there any difference running two little springs on the bottom instead of one large one? I remember when I set mine up the spring kit had two small ones that hooked to the backing plate.
The manual also shows the top spring clip facing the other way; not sure if it makes any difference. _________________ 69 Fastback Build
Berg5 Build |
IAMIROY Samba Member
Joined: September 27, 2011 Posts: 294 Location: Palmdale, CA
Posted: Mon Jan 09, 2012 8:52 pm Post subject: |
| Mark's '64 has 2 small springs hooked to the backplate. Also, e-brake arm on the front of the shoe like the manual. |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Posted: Mon Jan 09, 2012 10:44 pm Post subject: |
Thanks for all the input.
I had not noticed the shoes don't match the shop book either but they are 45mm wide (correct) and they were working fine so I think I am ok.
But... the shoes are damaged so if anyone has any "correct" ones, even cores, I would get the right ones redone/installed.
Or if anyone knows the universal number for the rear brake shoes, please post it.
For instance, the front shoes are number 10139
As someone said above, it looks like they swapped left & right as they would be correct otherwise. To swap side to side was my plan.
They also installed the wrong wheel cylinders, they are 65-era 23.8mm ones instead of the correct 63 25.4mm ones - probably all they could find. It seemed to drive fine though, not that I have driven it much, haha, but if I can find some 25.4mm ones I will swap them out. (Hint, hint, part # 361611069B) _________________ How to Post Photos
Slow 1200 Samba Member
Posted: Thu Jan 12, 2012 10:21 pm Post subject: |
| ibjack wrote: |
| I think you have the wrong brake shoes. I'm almost positive that those are correct for the early cars on the front only. They ebrake set up should have the lever on the front of the shoe. |
Hey Jack,
If you were referring to the shape of the shoes?
They match what is in my parts book for 63-down and a couple other brake shoes sources I found later.
64-65 have the shape as seen in my shop book image above. _________________ How to Post Photos
ibjack Samba Member
Posted: Fri Jan 13, 2012 1:13 am Post subject: |
| EverettB wrote: |
| ibjack wrote: |
Hey Jack,
64-65 have the shape as seen in my shop book image above. |
My experience has been that the batwing sytle were for the fronts on the earlies and since squarebacks had larger shoes thay were more of the "regular "style. I have never owned an early square but have been able to work on a few early cars. Here's what I'm used to seeing
1500 Club OG
notchboy Samba Member
Joined: April 27, 2002 Posts: 22686 Location: Escondido CA
Posted: Fri Jan 13, 2012 9:36 am Post subject: |
Those are the correct shoes Jack-Ev. The early ones have that universal shoe. In the pic above those back ones are just later types-that Im pretty sure you can use up front as well. Its the width as Ev said. 45mm is for the early rear.
Dont toss those early shoes Ev. ISP as well as other shops re-shoe them. Super Beetles use those later rear T3 shoes for the fronts.
Oh and the E brake arm should be on the outside.
See the pic below-the shoe has the groove in it for the E brake arm. Making it univeral-F to R.
My 63 Ev
| t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Randall Samba Member
Joined: October 03, 2004 Posts: 1404 Location: Orange County, Alta California, El Norte
Posted: Fri Jan 13, 2012 1:41 pm Post subject: |
| EverettB wrote: |
They also installed the wrong wheel cylinders, they are 65-era 23.8mm ones instead of the correct 63 25.4mm ones - probably all they could find. It seemed to drive fine though, not that I have driven it much, haha, but if I can find some 25.4mm ones I will swap them out. (Hint, hint, part # 361611069B) |
Here's a post you made back in 2007, Everett, showing the complete range of front and rear Type 3 wheel cylinders.
http://www.thesamba.com/vw/forum/viewtopic.php?t=266697
The only VW I have owned or worked on is a '63 Notchback with an 83000 chassis number. I wrote down in a repair manual some 30 years ago that I replaced my rears with 113 611 057B. Now I find out from your 2007 post that I should be using 311 611 067. Since both part numbers have a 22.2 mm bore I'm not going to sweat it.
However, I did switch to 50 mm shoes way back when and have not had any problems with the brakes (except for when I took steep Hwy 18 north from Big Bear Lake in the San Bernardino Mts. to the desert below. But that's another story). I suppose I should switch to the later cylinders since the tab of the shoe that fits into cylinder slot is 2.5 mm farther away from the backing plate on 50 mm shoes compared with 45 mm shoes. This raises the question: when, if ever, did the Type 3 switch to 50 mm shoes? |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23567 Location: Kimball, Mi
Posted: Fri Jan 13, 2012 3:52 pm Post subject: |
| Randall wrote: |
| EverettB wrote: |
They changed in 64, and stayed that size until the end of production. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Posted: Fri Jan 13, 2012 5:57 pm Post subject: |
| Randall wrote: |
| The only VW I have owned or worked on is a '63 Notchback with an 83000 chassis number. I wrote down in a repair manual some 30 years ago that I replaced my rears with 113 611 057B. Now I find out from your 2007 post that I should be using 311 611 067. Since both part numbers have a 22.2 mm bore I'm not going to sweat it. |
Yes, I'm not sure if it matters. I found some photos online and it also looks like the Bug bleeder valve is on the opposite side of the metal line connection on the cylinder. I'm not sure if there is a difference otherwise. _________________ How to Post Photos
