Gearbox with code H?
vw_speedsterke
vw_speedsterke is offline
PostPosted: Wed Jan 11, 2012 1:18 pm    Post subject: Gearbox with code H? Reply with quote
i have here a gearbox, its come from a splitscreen panelvan from '59. I think its not a splitscreen gearbox, the case is from VW. I can't find information for a gearbox with H code by vw, is it a early porsche gearbox?
type241
type241 is offline
PostPosted: Wed Jan 11, 2012 1:32 pm    Post subject: Reply with quote
I am fairly certain that isn't the OG tranny. 59 would still be splitcase tranny.
The axle tubes also are incorrect for 59. There wouldn't be mounts for the rubber snubbers. And depending on axle nut size, I am betting that has big nut gear reduction boxes. Looks like there is the plug on back of RGB(Big Nut).
What does the mount look like on your bus for the front of tranny? I have seen a splitcase with normal tunnel mount in 59ish?
vw_speedsterke
PostPosted: Wed Jan 11, 2012 3:20 pm    Post subject: Reply with quote
i have buy this tranny, its not from my bus.
Wexford
Wexford is offline
PostPosted: Wed Jan 11, 2012 4:51 pm    Post subject: Reply with quote
1967 bignut (42mm) RGB
Clara Premium Member
Clara is offline
PostPosted: Wed Jan 11, 2012 6:38 pm    Post subject: Reply with quote
While that tranny looks to be from a 65-67 bus, it may well be useful for your bus.
VW changed from split case to tunnel case tranny at VIN 469 xxx.
If your have an early 59, it came with a split case tranny, and that is not a straight bolt in.
There are adaptors that let you bolt a tunnel transmission in your split case bus.
If you have a late 59, it is a straight bolt in, and if you are running a larger than 36hp engine, you may prefer the later gearing in that gearbox.
This is where a split case tranny bolts into a bus. see the circle for the nose cone. Is yours like this?
PostPosted: Wed Jan 11, 2012 9:55 pm    Post subject: Reply with quote
Here's my '61, you can see the other style of mount here
Ignore that plate in the bottom center on the cross-bar, the previous owner added that.
vw_speedsterke
PostPosted: Wed Jan 11, 2012 11:24 pm    Post subject: Reply with quote
my bus is a '67
buth i can't find a list with H gearbox, there is no info
*VW Type 1
AA 1200 4.375 From Chassis No 0 981 810
AB 1300 4.375 Up to 8/70
AC 1500 4.125 also some 1300 from 8/70
AD 1200 4.375 Limited Slip Differential
AE 1300 4.375 Limited Slip Differential
AF 1500 4.125 Limited Slip Differential up to 8/70; also some
1300 from 8/70
AG 1200 4.375 Type 147 Fridolin
AH 1500 4.125 IRS from 8/68
1600 4.125 8/69 ? 8/72
AK 1500 3.875 Type 181 up to 8/70
1600 3.875 Type 181 from 8/70
AL 1500 3.875 Type 181 with LSD up to 8/70
1600 3.875 Type 181 with LSD from 8/70
AM 1300 4.375 Saloon and Cabrio from 8/70
AN 1600 3.875 Karmann Ghia with IRS from 8/70
AO 1600 4.125 Karmann Ghia from 8/70
AP 1300 4.375 LSD from 8/70
AQ 1600 4.125 LSD 8/70 ? 8/72
AR 1600 3.875 Karmann Ghia with LSD from 8/70
AS 1600cc3.875 From 3/72
AT 1600 3.875 1303s and Cabrio from 3/72
AU 1600 3.875 1303s and Cabrio from 3/72 with LSD
BA 1300 / 1500 4.375 Semi Automatic from 8/68 ? 8/70
BC 1300 / 1500 4.375 Semi Automatic from 8/68 ? 8/70 with LSD
BE 1600 4.125 Semi Automatic from 8/70 ? 8/71
BF 1600 4.125 Semi Automatic from 8/70 ? 8/71 with LSD
BG 1600 4.125 Karmann Ghia Semi Automatic from 8/70
BH 1300 4.125 Karmann Ghia Semi Automatic from 8/70 with LSD
BJ 1300 4.375 Semi Automatic from 8/70
BK 1300 4.375 Semi Automatic from 8/70 with LSD
BL 1600 4.125 Semi Auto
DA 1500 /1600 4.125 Type 3 Swing-axle up to 8/68
DB 1500 /1600 4.125 Type 3 Swing-axle up to 8/68 with LSD
DC 1500 /1600 4.125 Type 3 IRS from 8/68
DD 1500 /1600 4.125 Type 3 IRS from 8/68 with IRS
-VW 181 (Kubel)
AV (1:3.78 , 2:2.06 , 3:1.26 , 4:0.93 .IRS)
*VW Type 2
Clara is offline
PostPosted: Wed Jan 11, 2012 11:52 pm    Post subject: Reply with quote
Are you wanting to know the production date, or the gearing inside?
It may have been rebuildt with different gearing, you know.
AirBus
AirBus is offline
PostPosted: Thu Jan 12, 2012 5:09 am    Post subject: Reply with quote
I got a small nut (36mm) gearbox under my 64-er with code H.. is the OG one..
VW T1 1964 - Mouse Grey - Pearl White
Bagged, Porsche steeringrack/brakes..IRS, Type 4 EFI turbo in the builds....etc
type241
type241 is offline
PostPosted: Thu Jan 12, 2012 11:09 am    Post subject: H tranny Reply with quote
So what is an "H" tranny? I dont see it in the list. I have a tranny that has "H" also but came from a 1960 bus. Original? It sure looks original to me with non split axle boots, 6v, and small nut RGB's.
Wexford
Wexford is offline
PostPosted: Thu Jan 12, 2012 11:46 am    Post subject: Reply with quote
I've had 3 H boxes and all looked unmolested and never split...maybe a concidence but all were late ratios, bignut and from 67 buses...
Ben
BarryL Premium Member
BarryL is offline
PostPosted: Thu Jan 12, 2012 3:28 pm    Post subject: Reply with quote
Pat at ITS (I nternational T ransmission S upply) in San Diego said the "H" means they are bus. I always though it meant "bus" and "12 volt" hence the '67 affiliation.
