21-window Samba Member
Joined: March 23, 2004 Posts: 248 Location: out planting
Posted: Sun Jan 15, 2012 7:34 am Post subject: ANOTHER Syncro trans question |
I searched the interweb and here:
Do some syncros have aluminum trans cases and some have magnesium trans cases?
Which is better and why? |
gears Samba Member
Joined: October 28, 2002 Posts: 4411 Location: Tamarack, Bend, Kailua
Posted: Sun Jan 15, 2012 10:57 am Post subject: |
The low gear housing of all Syncros are aluminum. I believe the aluminum main cases and intermediate housing all originated in South Africa for added strength (to go with their larger engines).
While the mag alloy version is lighter and is said to have better "memory", the AL version resists ovaling in the two critical bearing bores subject to long term wear. |
Posted: Sun Jan 15, 2012 11:02 am Post subject: |
Any way to tell for sure?
The one in my 86 appears silver in color
I got a spare one that appears grayish (mag color)
They definitely look different.
I want to get one rebuilt, but want to use the "correct" one. |
gears Samba Member
Posted: Sun Jan 15, 2012 12:08 pm Post subject: |
| One way would be to use a file on both and burn/ignite the filings. Compare with known low gear housing (aluminum) and bell housing (mag) filings. You'll know pretty quick which are which. |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2987 Location: Issaquah, WA
Posted: Sun Jan 15, 2012 12:57 pm Post subject: |
I don't think any Syncro transmission cases were magnesium. They should all be aluminum. But keep in mind that a corroded aluminum case that has spent it's life in the salt belt will be grayish and look very different than a well preserved west coast example.
D |
gears Samba Member
Posted: Sun Jan 15, 2012 1:28 pm Post subject: |
| I believe that the only aluminum section in U.S. Syncros is the low gear housing. The main case and intermediate housings are mag alloy. I don't know about Canadian imports. |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Sun Jan 15, 2012 3:05 pm Post subject: |
Although they've been called Aluminium and Magnesium cases, they're more of an alloy of Magnesium and Aluminium and it's the varying amounts of this alloy which gives the different properties... not trying to teach you how to suck eggs or anything
I tend to refer to them as light and heavy cases... the heavy case being the stronger.
I have both heavy and light cases and they both work well. The light case tends to corrode more (more magnesium) and have to be replaced just because of this.
The weight difference can be a lot!
I have always tried to use heavy cases for my Syncros just to give them a fighting chance.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
Posted: Mon Jan 16, 2012 9:39 am Post subject: |
Thanks
I suppose I will have the "heavy" more silver looking trans currently in my syncro rebuilt.
insyncro Banned
Posted: Mon Jan 16, 2012 11:06 am Post subject: |
MG,
If you don't mind I am going to start using your description of cases.
Very easily unbderstood.
Well done.
dylan |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17658 Location: Left coast, Canada
Posted: Thu Jan 19, 2012 12:09 am Post subject: |
| 21-window wrote: |
| Any way to tell for sure? |
Acid test!
Literally, not figuratively.
Pour 1-2ml of vinegar on the suspected Mg part. Watch it for 3-5 min. If it starts to foam up, you have Mg. If it does nothing: Al. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
gears Samba Member
Posted: Tue Aug 27, 2013 8:02 am Post subject: |
No mistaking the aluminum main housing when compared directly with the mag alloy housing. One weighs 13 lbs, while the other weighs 18 lbs.
_________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
insyncro Banned
Posted: Tue Aug 27, 2013 8:07 am Post subject: |
| gears wrote: |
Which is stronger and will not stretch as much as the other from higher torque engines? |
derekdrew Samba Member
Joined: October 14, 2007 Posts: 248 Location: Far Northwest CT
Posted: Mon Nov 25, 2013 10:23 am Post subject: |
As some of you know, VW of South Africa, working with SDP, took over the development of improvements to the syncro gearbox starting in about 1991 after the gearbox began to experience failures when used with the more powerful Audi 5 cylindar engines that were supplied as original equipment on South African Vanagons.
The work that South Africa did to improve the transmission is of critical importance to us because many of us have moved to install more powerful engines, and the gearbox, without improvements, generally tolerates more powerful engines, especially powerful diesels, rather poorly.
You may know of syncro owners with more powerful engines who have transmission failures 10,000 to 30,000 miles after installing their new engines. Not everyone with these short mean-time-before-failures talks about it though.
In my view, all of these owners would be well to use the stronger All-Aluminum main cases and All-Aluminum intermediate housings (so called, 173 housings) that were created by SDP and VW of South Africa. These housings have less magnesium and are more of a pure aluminum mix.
(I also feel that all of these owners should install a temperature gauge inside or outside of their transmissions, but that is another story from what is addressed in this email.)
The purpose of this email is to alert readers to issues about the availability of the upgraded housings for the transmission.
Firstly, Daryl at aatransaxle.com http://www.aatransaxle.com/price_list.htm has some of the upgraded 173 housings, also known as "intermediate housings" of the stronger all aluminum design. There are pictures of them here: https://picasaweb.google.com/111803335891651546087/173Housings I don't know whether he is selling these alone or only in connection with a gearbox rebuild but I mention it because previous to now, these housings were not well known, and the 173 housing is a problem area. GoWesty is on an interesting track to advocate the use of a steel insert into the 173 housing and a rebuild procedure that seems pretty neat: http://www.gowesty.com/ec_view_details.php?id=23511&category_id=93&category_parent_id= I think they have in mind to put the steel insert into an older magnesium housing that is being rebuilt, but I think its possible that the strongest housing of all would be to marry their steel insert with the stronger 173 all aluminum housing. I don't know anybody who has actually done this. Longer term, if it is far in the future when you read this post, you can check to see whether Weddle has their own proprietary housing that they might be manufacturing at some point. At the moment, what they seem to offer is the upgraded all aluminum housing similar, or the same as, what Daryl has, here: http://weddleindustries.com/products/new-products/weddle-syncro-and-vanagon-parts
The matter of the 173 housings is somewhat familiar to some syncroists by now.
But what is really new is the arrival on these shores of the stronger all-aluminum main case housings. I wouldn't be surprised if Weddle has 10 of these and GoWesty 25. You can see them referred to here: http://weddleindustries.com/sites/weddleindustries.com/files/Van_Parts_site.jpg / http://weddleindustries.com/products/new-products/weddle-syncro-and-vanagon-parts and here: http://www.gowesty.com/ec_view_details.php?id=23941&category_id=253&category_parent_id= (select the optional locker option).
The main cases used to weigh about 13lbs in their magnesium alloy formulation included with all syncro transmissions sold in North America as original equipment. The stronger all-aluminum design versions weigh more like 18lbs.
It is possible that once these cases sell out, there won't be any more, and it has been a long time since they have been available here in North America, and were never available here officially to my knowledge.
My advice is, if there is one thing you should do if you own a syncro, and you have or plan to have a larger engine, it is to order one of these advanced cases NOW before they sell out.
The price of them is something like $600 or $700 on the moment, but I expect that after they sell out, they will go for $1,200 on Samba or more.
It is something of a MIRACLE that they are available and I don't expect this condition to last more than a few months.
The purpose of this email is just to generally help people who have syncros by keeping them informed of developments.
(cross posted to syncro list) _________________ Derek Drew
derekdrew - a t - derekmail - dott - com |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Mon Nov 25, 2013 11:03 am Post subject: |
Good advice and timely for many. When I rebuilt my Syncro trans last year, I used the new aluminum main bearing section with the steel reinforcement. I liked the quality, the fit, and the design's intent. I can't be the only one??
Anyhow, agree - highly recomended. Planning to reduce the magnesium housing to shavings some day just to play with the pyrotechnics of mag shavings. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3674 Location: Dartmouth, Mass.
Posted: Mon Nov 25, 2013 1:05 pm Post subject: |
| insyncro wrote: |
MG,
Well done.
dylan |
No probs
I like Dereks info on this. As always, top notch.
If I can, I will always use a heavy case. I would say that on a standard vehicle with absolutely no modifications at all... I can't see there being much difference but as soon as you start pushing it it will make a difference.
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4624 Location: East Kootenay, British Columbia
Posted: Mon Nov 25, 2013 2:39 pm Post subject: |
So what are the chances that there might someday be completely new, custom designed, Syncro transmissions? The market seems to be there.
How much would it cost to build a totally new transmission? Maybe even a five speed plus granny?
There are custom transmissions out there for race cars, etc. Why not for Syncros? _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
hans j Samba Member
Joined: May 06, 2006 Posts: 2746 Location: Salt Lake City UT
Posted: Mon Nov 25, 2013 2:48 pm Post subject: |
I bought a completely new syncro transmission (brand new, all updated AL case and added internal goodies)
It's probably going to cost quite a bit more for a brand new housing and gear stacks to be manufactured. Like stated before, the transmissions can last if not abused. I'm even surprised at how long some of the 5cyl diesel conversion transmissions have lasted! Gives me hope that I could have a 300,000+ mile powertrain installed in my van now  _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
pedrokrusher Samba Member
Joined: July 11, 2011 Posts: 654 Location: Montreal, Quebec, Canada
insyncro Banned
Posted: Mon Nov 25, 2013 4:33 pm Post subject: |
I would love to get a hold of the tooling for each case of the Syncro locker.
I know of a shop in CT that could easily reproduce these cases and make improvements.
I suppose if one was to purchase each aluminum case section and hand it over to them, they could go forward.
One pricey venture, for sure. |
