Another 1.8T hits the road !!
VWhead
VWhead is offline
PostPosted: Tue Jan 17, 2012 2:58 pm    Post subject: Another 1.8T hits the road !! Reply with quote
Just completed a 1.8T engine conversion into a 85' Vanagon and it's all California legal ! Very Happy VW Logo Very Happy
The motor was removed from a 02' VW GTI.
Here's some pics...
81' Single Cab Syncro 1.8T GMW
88' 2wd Westy 1.8T GMW
www.gmwerks.com
purplepeopleeater
purplepeopleeater is offline
PostPosted: Tue Jan 17, 2012 3:03 pm    Post subject: Reply with quote
wow, nice.
doesnt even look like you modified the oil pan and clearance looks awesome.
D Clymer
D Clymer is offline
PostPosted: Tue Jan 17, 2012 3:06 pm    Post subject: Reply with quote
Nice! Under the engine cover too! How much did you have to lower the transmission from stock?
I like the exhaust layout. Everything is in stock position - except much larger.
D
insyncro
Banned
insyncro is offline
PostPosted: Tue Jan 17, 2012 3:26 pm    Post subject: Reply with quote
Very clean install Exclamation
Applause Applause Applause
andy syncro-nutz
andy syncro-nutz is offline
PostPosted: Tue Jan 17, 2012 4:49 pm    Post subject: Reply with quote
X2 Real nice,
What is the ground clearance for the sump?
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Jan 17, 2012 5:11 pm    Post subject: Reply with quote
Sweetness! That's one of the cleanest and stealthiest raised engine lids I've seen. That engine totally belongs in there.
Casey--
'01 Weekender --> full camper
y u rune klassik?
hans j
hans j is offline
PostPosted: Tue Jan 17, 2012 5:36 pm    Post subject: Reply with quote
Looks great! Did you make those engine brackets/cradle bars?
1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
VWhead
VWhead is offline
PostPosted: Tue Jan 17, 2012 6:35 pm    Post subject: Reply with quote
Thanks everyone for your positive comments!
It's just too much fun building 1.8T breadbox's! Laughing
The oil pan is stock from the GTI donor vehicle and doesn't need any modification.
I wanted the engine lid spacer to be very simple,yet functional. The engine lid spacer is 1-1/4" tall and the trans is spaced down 1-1/2".
The exhaust system is all Tig welded with 304 stainless mandrel bent tubing and uses the donor cat. It sounds great!
Ground clearance on this 2wd is approximately 8" and that's with stock suspension and 27" tires. More clearance could be had with taller springs if needed.
I'm using our newly redesigned engine carrier system,it's similar to what VW did with the Diesel Vanagon engines,but it mounts upright at 15 degrees.
www.gmwerks.com
andy syncro-nutz
PostPosted: Tue Jan 17, 2012 6:43 pm    Post subject: Reply with quote
And great 200th post on here too! Well done Smile
insyncro
Banned
insyncro is offline
PostPosted: Tue Jan 17, 2012 7:41 pm    Post subject: Reply with quote
Are pricing and options listed anywhere?
This conversion is really growing on me and I am nowhere near Cali. Very Happy
hans j
hans j is offline
PostPosted: Tue Jan 17, 2012 7:55 pm    Post subject: Reply with quote
There is a 06A factory steel pan available too! I don't remember the part number but I think it is usually on 2.0. That's what I am going to do on my TDI conversion so it can take abuse if I am unlucky enough!
dredward
dredward is offline
PostPosted: Tue Jan 17, 2012 8:19 pm    Post subject: Re: Another 1.8T hits the road !! Reply with quote
Here's some pics...
YAY!!!!! Is this yer van Paul?
Cars owned: 1979/89 scirraco, 1983 gti, 1984 gti, 1986 gti, 1990 gli, 1989 cabriolet(2.0,16v conversion), 1992 gti, 1982 Westy, 1987 syncro Westy(w/ 1.8t conversion stg1 chip), and finally 2004 r32....
Crankey
Crankey is offline
PostPosted: Tue Jan 17, 2012 8:26 pm    Post subject: Reply with quote
that looks very nice in there. great work.
I too am leaning more this way.
is there any reason it couldn't be mounted 'upright' without any tilt from it's original orientation in a doka, ?
I have 9 5/8" from the top of my WBX alternator to the bottom of the engine hatch.
I'm nearly 100% street driven so I don't need higher than stock ground clearance. someday I may get shorter springs, but I'm on carat springs now.
thanks for sharing your pics ! drool worthy !
purplepeopleeater
PostPosted: Tue Jan 17, 2012 9:12 pm    Post subject: Reply with quote
Yeah, my Doka would like that in the back of it.
as insyncro said, price?
andy syncro-nutz
PostPosted: Tue Jan 17, 2012 9:20 pm    Post subject: Reply with quote
You kinda gotta look out for the PWR Steering pump when you put these engines uprite Russel @ syncro-nutz did a TDI uprite and i remember the pump was the lowest thing and needed to modifi the diesel syncro bash plate,
Ryan Alfonso
Ryan Alfonso is offline
PostPosted: Tue Jan 17, 2012 9:36 pm    Post subject: Reply with quote
Want. Want. Want
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Crankey
Crankey is offline
PostPosted: Tue Jan 17, 2012 10:13 pm    Post subject: Reply with quote
power steering ?!? I don got no stinkin power steering ! Laughing
purplepeopleeater
PostPosted: Tue Jan 17, 2012 10:17 pm    Post subject: Reply with quote
me either, not power steering rack anyways.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Tue Jan 17, 2012 10:30 pm    Post subject: Reply with quote
Great stuff!
Looks like the cat is supported off d-side of block. I have been using something similar.
Is the muffler supported from body? I imagine the turbo must quell some exhaust noise.
Interesting to have a look at another 15º install. I'm currently in the middle of carrier and exhaust redesign and am still making decisions. Very helpful to see your pics.
Thanks!
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
Tristar Eric
Tristar Eric is offline
PostPosted: Tue Jan 17, 2012 10:55 pm    Post subject: Reply with quote
Excellence! I really like your lid spacer. I might have to borrow your idea there. Super clean, congrats on the BAR sticker.
Page 1 of 9
