joescoolcustoms Samba Member
Posted: Mon Jan 23, 2012 11:31 am Post subject: Where to find a new buggy dash |
I do not like the design of my buggy's dash and want to change it. The way it comes back towards the passengers does not allow for a close fitting roll cage front hoop. Plus it has been hacked by several PO's.
I do not want the ABS plastic Manx dash. I want a fiberglass dash so I can cut my already painted hood and bond a new dash onto it. I can do this at the windscreen area so the seam will be covered. I am looking for a dash that slopes back towards the front of the buggy so I can tuck a roll cage hoop right up againt the windscreen.
Is there a source for new fiberglass dash's out there?
Here is what I currently have:
_________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Meco Samba Member
Joined: January 09, 2009 Posts: 148 Location: Chula Vista, CA
Posted: Mon Jan 23, 2012 3:32 pm Post subject: |
FYI -The new Manx dash is fiberglass. |
surfnc Samba Member
Joined: September 29, 2006 Posts: 948 Location: OBX, NC
Posted: Mon Jan 23, 2012 3:51 pm Post subject: |
Joe,
You can use a Manx dash but you will have to cut away some of your current dash, then glass the new dash on.
Not the best picture but you can see how the Manx hood/dash angles forward where yours angles backward. It should not be too big a deal and the joint will be covered by the windshield. _________________ LOOKING FOR VINTAGE MEYERS MANX STUFF!!!
http://www.thesamba.com/vw/classifieds/detail.php?id=1105228 |
Posted: Mon Jan 23, 2012 4:17 pm Post subject: |
surfnc wrote: |
Joe,
Not the best picture but you can see how the Manx hood/dash angles forward where yours angles backward. It should not be too big a deal and the joint will be covered by the windshield. |
That is my exact intention. I do not like the current slope of my dash, I want it to slope away from me. I believe I can do the work and never harm the current paint.
I have contemplated the Manx dash, but the design does not impress me. I have emailed Berrien about the Citation and Lancer Dash's but have yet to hear back. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
surfnc Samba Member
Posted: Mon Jan 23, 2012 4:26 pm Post subject: |
They should work the same. You should be able to do it without damaging the paint. You could tape it off and use a cut-off wheel to cut hood to fit new dash. Then tape the hood to protect paint and glass dash to hood. (from underneath) You may find, as I did, that you have to clamp the hood to the dash to pull in the lower "fingers" of the hood. Mine were sprung out and needed to be pulled in to match the dash's contour. _________________ LOOKING FOR VINTAGE MEYERS MANX STUFF!!!
Posted: Mon Jan 23, 2012 4:42 pm Post subject: |
Actually, I will make the dash fit the hood. The hood fits the contour of the body so well, I will modify the dash to meet it so it will still fill all the gaps as it currently does.
I have also been contemplating adapting/contouring/altering the dash to fit the roll cage into it, but not have the roll cage go through it. Basically have a cupped, contoured section at each end of the dash for the tubing to fit into but still be exposed and able to remove the dash/hood as one piece away from the roll cage.
A buddy flagged me on these racing 944 fiberglass dashes. I can alter this one nicely to fit the roll cage and my existing hood.
Just looking at all options.
MANXXMAN Samba Member
Posted: Mon Jan 23, 2012 6:24 pm Post subject: |
I make a version of dash for our mid travel cars you might be able to use.
We get $225 for the 3 piece set. It may be a little wide for a standard manx though.
Posted: Mon Jan 23, 2012 6:27 pm Post subject: |
Quote: |
We get $225 for the 3 piece set. |
Looks interesting. Please explain the three pieces and the outside width. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
GTBRADLEY Samba Member
Posted: Mon Jan 23, 2012 7:20 pm Post subject: |
Looks like it fastens around the roll cage. The center pc then two outer pcs _________________ Thunderbug by Bugformance 1969 |
