1500cc Okrasa
Page: 1, 2, 3  Next
Vintage oval
Vintage oval is offline
PostPosted: Fri Nov 25, 2011 4:49 pm    Post subject: 1500cc Okrasa Reply with quote
I'm finishing up a 1500cc Okrasa 36hp motor with custom handmade linkage and would like some help jetting the Solex P40-11 carbs. The motor is 74mm x 80mm. Cam is 265 Dur, .322 Lift and the compression Ratio 8.5:1. The ventures are 32mm.
I'm in the Denver area and I'm thinking of using 122.5 mains, 180 air correction, 965 pilot. Has anyone used the P40-11 on Okrasa heads before that might be able to give me some suggestions on the jetting?
alanhall
alanhall is offline
PostPosted: Fri Nov 25, 2011 6:22 pm    Post subject: Reply with quote
Don't have experience with the Okrasa heads, but the jetting you are suggesting is standard for a split shaft 40PII-4 on a late 912 Porsche, 1600cc 9.3:1 CR. Might be a little rich for 1500 cc in Denver, perhaps a 115 or 120 main might work better. Are your carbs solid or split shaft? Engine looks great by the way!!
Vintage oval
PostPosted: Fri Nov 25, 2011 7:33 pm    Post subject: Reply with quote
Thanks for the info. The carbs are solid shaft. I have both split and solid shafts but decided to use the solid shaft as they look more period correct for the motor. I was trying to build something that looks it could of been built in the mid to late 50s
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Fri Nov 25, 2011 9:57 pm    Post subject: Re: 1500cc Okrasa Reply with quote
Beautiful
"no more hacking my sig line"
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Fri Nov 25, 2011 10:22 pm    Post subject: Reply with quote
Hello-
I'm so jealous!
I bought some Zenith carbs recently, but now I'm having second thoughts. Wink
Cheers,
Paul
grueni
grueni is offline
PostPosted: Fri Nov 25, 2011 10:27 pm    Post subject: Reply with quote
very beautiful. in first thoughts i would say the vents could be too big for this engine in low and mid range.
1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile )
Vintage oval
PostPosted: Fri Nov 25, 2011 10:53 pm    Post subject: Reply with quote
I also have a set of 28mm ventures that I can try out on the carbs if the 32mm take away too much from the low end and mid range.
Roadcow
Roadcow is offline
PostPosted: Sat Nov 26, 2011 12:23 am    Post subject: Reply with quote
Talk with Richard Troy, I used his Okrasa 1500cc with those same carbs at Bonneville 2 years ago. Ran 92 mph in my Ghia. Beautiful engine.
71 Westy Roadcow
67 Panel
63 Bug
66 Ghia Bonneville 2014
74 Ghia Vert
69 Bonneville Ghia 150 in Chico
69 Bonneville Ghia in Ireland
80 Cabby 2.1 16v
98 Passat
alanhall
alanhall is offline
PostPosted: Sat Nov 26, 2011 12:39 am    Post subject: Reply with quote
Just for comparisons the jetting used for solid shaft 40PII-4 on the 356 1600 Super 90 motor was: 115 main, 32 venturies, 57.5 idle, 1.8 idle air, 50 pump, and #25 emmulsion tube. The jetting used for the solid shaft, sand cast 40PII-4 on a 1500GS 4-cam motor was 102.5 main, 30 venturis, 50 idle, 1.5 idle air, 50 pump and #33 emmulsion tube. The sand cast 40PII-4 were similar but a somewhat different design compared to the later die cast 40PII-4 carbs.
oldbusboy
oldbusboy is offline
PostPosted: Sat Nov 26, 2011 2:41 pm    Post subject: Reply with quote
That motor looks awesome!
Sorry, nothing to add to the jetting question, but I'd love to see a video of that running.
Trevor
1968 porsche
Louis
Louis is offline
PostPosted: Sun Nov 27, 2011 2:08 am    Post subject: Reply with quote
where did you get the manifold?
cheers!
View user's profile Send private message Send e-mail AIM Address MSN Messenger Gallery Classifieds Feedback
Vintage oval
PostPosted: Sun Nov 27, 2011 6:14 am    Post subject: Reply with quote
I got the manifolds from Speedwell USA.
Jacks
Jacks is offline
PostPosted: Sun Nov 27, 2011 11:27 am    Post subject: Re: 1500cc Okrasa Reply with quote
What is a 965 pilot?
Louis
Louis is offline
PostPosted: Mon Nov 28, 2011 12:33 pm    Post subject: Reply with quote
any phone number for speedwell?
i emailed him from his website but no answer.
love those manifold... want them!
Louis
Louis is offline
PostPosted: Mon Nov 28, 2011 12:35 pm    Post subject: Reply with quote
are those carbs too big or they work great for this motor?
anyone want a set of pbic32?
cheers!
gimmesomeshelter
PostPosted: Tue Nov 29, 2011 1:53 pm    Post subject: Reply with quote
Hello-
Regarding your choice of ventruis, how do you want your car to drive?
Do you prefer to step on the gas at 2K and have something happen? If so, try the 28mm venturis first. If you prefer to let all the other cars pass you by until you finally reach 4K, then go with the 32mm. Given the modest duration of your cam, I suspect that the 32mm venturis may be a bit of a mismatch. Keep in mind that Pre-A Supers came with 26mm venturis for for normal driving, and used 29mm for racing.
Cheers,
Paul
rcraigbug
rcraigbug is offline
PostPosted: Tue Nov 29, 2011 5:44 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1226387
http://www.oldtimeroldspeedclub.blogspot.com/
Member United States Chapter
gimmesomeshelter
PostPosted: Mon Jan 23, 2012 10:37 pm    Post subject: Reply with quote
Hello-
Have you made any progress with your carbs?
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
earthquake
earthquake is offline
PostPosted: Tue Jan 24, 2012 12:32 am    Post subject: Reply with quote
That motor is beautiful but it should be hung on a nicer stand...
Just kidding Very Happy
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
Vintage oval
PostPosted: Wed Jan 25, 2012 10:27 pm    Post subject: Venturs Reply with quote
Here is an update on the ventures. I am looking a drivable engine, not a race engine so I am thinking of going with 26mm ventures. These will give me around 4500 rpm limit and will give torque in the lower range which I think will make it more drivable in the city. Anyone have any experience with selecting ventures for a 1500cc engine with two dual carbs?
Page: 1, 2, 3  Next
