Leds in vanagon. how to wire??
littlejay
littlejay is offline
PostPosted: Mon Jan 30, 2012 9:49 am    Post subject: Leds in vanagon. how to wire?? Reply with quote
I want to put Leds in all lighting in the Vanagon. I see pics of people adding in dome lights in their front and back of Westy's . How is this wired??. Also the overhead in the Kitchen area,I have seen others add a second light and run them in parallel. I just saw some lights like this in Lowes. Is this what people are doing?
Timwhy
Timwhy is offline
PostPosted: Mon Jan 30, 2012 11:34 am    Post subject: Reply with quote
Read these threads, it may give you some ideas on a how to?
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...ght=alpena
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...light=leds
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
randywebb
randywebb is offline
PostPosted: Mon Jan 30, 2012 3:13 pm    Post subject: Reply with quote
the light behind the stove on the shelf was 3 bulbs, then changed to a fluorescent bulb by 1986
no easily avail. LED conversion for the latter, only the early 3 bulb type
1986 2.1L Westy 2wd Auto Trans.
climberjohn
climberjohn is offline
PostPosted: Mon Jan 30, 2012 7:18 pm    Post subject: Reply with quote
Hi Littlejay,
As mentioned, this thread should get you started:
"Alpena Flex LED lights for interior van lighting"
I have gone to all LEDs for house lighting, and could not be happier. Use small gauge wire, like 16, and a small fuse, like 5 amps. The Alpena Flex lights are great, if you can manage the "cool" LED look. For reading and cooking I prefer the "warm" white LEDs from Oznium.com. Get the Alpena LEDs at Autozone.
I am running this:
- 1 set of the Alpenas (2 strips of 1 foot each) under the dash, ground wire connected to each front door switch, lights are always wired hot. Thus, the lights go on when door is opened. Center one LED strip over the glove box.
- 1 Oznium.com "Surface Mount LED Light Bar - Warm White", over the stove/sink.
- 1 Oznium.com "Surface Mount LED Light Bar - Warm White" over bench seat as a reading light
http://www.oznium.com/smd-bar
(Anyone wanna buy a pair of $50+ Go We$ty fluorescent lights?)
-CJ
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
littlejay
PostPosted: Tue Jan 31, 2012 8:57 am    Post subject: Reply with quote
thanks man, perfect. I like the idea of the ones wired to the door switch.
littlejay
PostPosted: Tue Jan 31, 2012 9:23 am    Post subject: Reply with quote
how do you get a power source and switch in the sink and bench seat location?
littlejay
these Led's are great!!!!
climberjohn
PostPosted: Tue Jan 31, 2012 11:09 am    Post subject: Reply with quote
I am working on a redo of the over sink light in the next day or so, and will post photos in the Alpena light thread.
-CJ
