EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Mon Feb 06, 2012 7:57 am Post subject: Pushrod tubes German vs. aftermarket ones |
Any big difference in quality in German pushrod tubes compared to the cheaper aftermarket ones? Is the metal thicker/stronger? Any other reasons to use German ones over the aftermarket ones? thanks _________________ 1963 Ragtop Bug |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Mon Feb 06, 2012 8:01 am Post subject: |
My favorite for mild/stock builds is just the stainless windage empi tubes. They look nice and work great. I polish them before the install...
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Mon Feb 06, 2012 8:45 am Post subject: |
I would always pick German first unless it didn't fit the situation. Meaning if you needed "Windage tubes", Wide mouth tubes for Hight Lift or drive in salt and buy stainless to avoid rusting.
Always use original seals. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Mon Feb 06, 2012 9:22 am Post subject: |
On the last 5 builds (haven't leaked a drop ) I have had good luck with Stainless tubes and empi silicone seals, as well as wolfsburg west silicone sump plate seals. _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE) |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
And don't polish them, flat black in a thin coating |
craigman Samba Member
Posted: Mon Feb 06, 2012 9:28 am Post subject: |
Hmm, I didn't know you could even get german tubes.. |
VIN Samba Member
Posted: Mon Feb 06, 2012 9:32 am Post subject: |
baked beetle wrote: |
On the last 5 builds (haven't leaked a drop ) I have had good luck with Stainless tubes and empi silicone seals, as well as wolfsburg west silicone sump plate seals. |
empi silicone seals rock! gonna have to try the silicone sump plate seal. _________________ Co-owner, 2 Brothers Guns
[email protected]
Click to view image |
Buellistic Samba Member
Joined: February 04, 2011 Posts: 357 Location: Albuquerque, New Mexico
Posted: Mon Feb 06, 2012 9:56 am Post subject: |
VIN wrote: |
empi silicone seals rock! gonna have to try the silicone sump plate seal. |
The white silicon seals hold up for replacing the heads too. I don't know how many rebuilds they can be used though.
As for tubes, they're all pretty much equal I would think. It's a really simple part, hard to get wrong. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Mon Feb 06, 2012 7:21 pm Post subject: seals |
Ditto. The transparent "whitish" EMPI silicone pushrod seals are the best I've ever come across. Maybe they're working on their quality control _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Tue Feb 07, 2012 10:34 am Post subject: |
Does any body make fined aluminum PR tubes?
That way they would act as mini oil coolers.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Feb 07, 2012 10:45 am Post subject: |
The ss empi tubes are my preference as well. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
slalombuggy Samba Member
Posted: Tue Feb 07, 2012 11:49 am Post subject: |
Yep, it's the only place I haven't had a leak from.....SS windage tubes and silicone seals
brad |
the2ndcashboy Samba Member
Posted: Tue Feb 07, 2012 12:08 pm Post subject: |
earthquake wrote: |
Casey |
Why not just run hard lines to a remote oil filter and then put fins on them ?
I think the whole "let's put fins on it to dissipate heat" thing gets taken a little too far sometimes.
Oh and I've also not had any leaks from my EMPI windage tubes and seals. _________________
SRP1 wrote: |
You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones. |
modok wrote: |
If anything comes out perfect it just means your measuring tools are substandard. |
Posted: Tue Feb 07, 2012 4:01 pm Post subject: |
the2ndcashboy wrote: |
earthquake wrote: |
Casey |
Oh and I've also not had any leaks from my EMPI windage tubes and seals. |
Hey, It worked on a Thompson Submachine Gun
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Tue Feb 07, 2012 6:02 pm Post subject: |
Hey Casey, I thought you'd be trying to minimise drag on the parts on your car????? Fins are just going to increase turbulence under the motor and slow you down
brad |
LyleGB Samba Member
Joined: August 20, 2011 Posts: 127 Location: Alvin, Tx.
Posted: Tue Feb 07, 2012 10:12 pm Post subject: |
I think they would act as maxi heat soakers since they're right in the path of the shroud's exhaust. |
