Oil temp sender
Steve Arndt
Steve Arndt is offline
PostPosted: Fri Feb 10, 2012 7:42 pm    Post subject: Reply with quote
from my STF build thread:
I wanted my oil temperature sensor to read accurately so I installed it into the full flow filter housing. This provides a direct reading of the oil as it returns to the case and into the bearings. The sensor would block part of the flow passage because the adapter didn't have enough material to tap. It would install too deep. To remedy this, I TIG welded a boss, faced off, drilled, and tapped the housing to provide a thicker area to thread the M10x1.0 sensor in. The inside is ported and polished for smooth flow. I also blue printed my Schadeck 26mm pump, as per the Bill Fisher manual.
[email protected]
john@aircooled.net is offline
PostPosted: Fri Feb 10, 2012 7:46 pm    Post subject: Reply with quote
http://vwparts.aircooled.net/Adapter-Bushing-1-2-NPT-to-1-8-NPT-p/adapter-bushing.htm
is another outstanding location, most do not know about.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Feb 11, 2012 12:36 am    Post subject: Reply with quote
I made this up, works like a champ.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Feb 11, 2012 1:07 am    Post subject: Reply with quote
Does this include the tap and/or sender as well??
'67 Sunroof
Eric
lots of money!
Hose & Fittings
aryue
aryue is offline
PostPosted: Sat Feb 11, 2012 6:03 am    Post subject: Reply with quote
At $9.95 - I'm sure you'll only receive the adapter fitting. The sending unit alone is $33.
OldandSlow - but still chuggin.
http://www.ph.utexas.edu/~yue/VW/VWBus.html
fory
fory is offline
PostPosted: Fri Jan 18, 2013 5:17 am    Post subject: Reply with quote
How accurate are the drain plug sensors? I'm getting some gauges and wondering if that's a good way to go... Obviously the drain plug is in constant contact with oil in the case.
Drive fast, take chances, pass on the right!!
Hotrodvw
Hotrodvw is offline
PostPosted: Fri Jan 18, 2013 7:34 am    Post subject: Reply with quote
Fortunately, you can buy that same bushing for about three dollars at any hard ware store.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Hotrodvw
Hotrodvw is offline
PostPosted: Fri Jan 18, 2013 7:37 am    Post subject: Reply with quote
So long as your engine is running, there is oil flowing past the sensor. I think it's a great location myself. I have a couple left.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
vwo60
vwo60 is offline
PostPosted: Fri Jan 18, 2013 4:18 pm    Post subject: Reply with quote
I have mine in the return line from the cooler in a seperate tee piece, i have been measuring the temp of the case and found that it is always hotter than the oil due to heat soak from the barrels and other parts of the engine so if the sender is installed in the case the temp reading in my opinion will not be acurate, you want to know if your oil cooler is actually doing anything, it would be ideal to have two senders so you can get the detla t across the cooler, you could use a rotory switch to change between the two senders, i also have a 10" fan on my cooler that was actuated by the switch supplied but was not very consistant, i installed on of these that allow's you to set the turn on and turn of point of the fan and have a alarm if it goes over your preset temp http://www.ebay.com.au/itm/BMW-ENGINE-ALARM-1-3-5-...2a26373a48 , also my cooler was supplied with the fan drawing air through the cooler, i turned the fan over and run it backwards thus pushing air through the cooler, this was also a improvement, next move is to fabricate a small scoop to to direct air onto the cooler directly from under the car, i bought a infrered heat gun and this is a good investmtent so you can check the acuracy of your system, my autometer oil temp gauge was out conciderably and the monitor is out by 4 degrees on the high side.
Hophead
Hophead is offline
PostPosted: Fri Jan 18, 2013 9:46 pm    Post subject: Reply with quote
That is where I put mine.... I bought the bushing from you.
70' Beetle Pan off Resto
2110cc
82 X 90.5
P&P 043 40x35.5
9.6-1 comp
FK-8
48 IDA
badufay
badufay is offline
PostPosted: Sat Jan 19, 2013 9:47 am    Post subject: Reply with quote
Jimmy111 wrote:
That is really a bad place for it. The only time it will work is when your relief valve leaks. Then what is the point. The motor just overheats anyways Very Happy
There is absoultly zero circulation of oil there.
Never thought of that...seems legit though, anyone else have any thoughts on this?
Ben
Current: 1976 VW Bus, 3 spd auto 2.0L FI; 2017 GTI S, 6 spd man; 2017 Jetta SE TSI, 5 spd man; 2006 Golf GL 2.0L, auto
Previous: 2015 Golf S TDI, 6 spd man; 2015 Jetta SE TDI, 6 spd man; 12 Jetta 2.5L, 04 Jetta 2.0L, 02 Golf 2.0L, 98 Jetta 2.0L, 98 Golf 2.0L, 98 Cabrio 2.0L, 95 Golf 2.0L, 87 golf GTI 16 valve 1.8L, 86 Cabriolet 1.6L, 80 Audi 4000 1.6L, 76 Audi Fox 1.6L, 76 VW Beetle 1.6L, 74 Audi Fox 1.5L, 69 VW Beetle 1.5L
Alpha_Maverick
Alpha_Maverick is offline
PostPosted: Sat Jan 19, 2013 11:25 am    Post subject: Reply with quote
There's no o-ring sealing the piston to the case. There will -always- be a small amount of leakage there. Whether or not it's enough to give the sensor an accurate reading is up for discussion. I believe it would be plenty.
Alstrup wrote:
hmm well, wiggly Laughing I like 5,5inchers in the rear at least.
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Jan 19, 2013 11:33 am    Post subject: Reply with quote
Correct, we're reading temperature, not pressure. A leak would effect pressure though.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Quokka42
Quokka42 is offline
PostPosted: Sat Jan 19, 2013 2:35 pm    Post subject: Reply with quote
You guys are talking about the relief plug sensor? There is no flow whatsoever past that - if it ever does read the same as the oil temperature, it is going to lag far behind it when it changes. It's probably going to get a liittle cooling air and read low anyway.
To the guys that have used the pickup adapter John mentioned (seems Aircooled read ob Hoover, too) how far does the sensor extend into the oil?
There has only ever been one man who was perfect, and they nailed Him to a cross.
flyboat
flyboat is offline
PostPosted: Sat Jan 19, 2013 5:43 pm    Post subject: Reply with quote
How about down the dipstick tube
http://vwparts.aircooled.net/Dipstick-Oil-Temperature-Gauge-p/thermo-dipstick.htm
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Jan 19, 2013 6:34 pm    Post subject: Reply with quote
Hard to read from the dash...
'67 Sunroof
Eric
lots of money!
Hose & Fittings
flyboat
flyboat is offline
PostPosted: Sat Jan 19, 2013 6:42 pm    Post subject: Reply with quote
I agree but it is a nice piece. and it is more accurate than any of the temp gauges on the market. it reads temp in the sump and that's as accurate as it gets.
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Jan 19, 2013 6:44 pm    Post subject: Reply with quote
True, but there are better ways to do it. Useless to me if I can't see what's going on under load.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
owdlvr
owdlvr is offline
PostPosted: Sat Jan 19, 2013 10:34 pm    Post subject: Reply with quote
I can confirm that the relief plug sensor reads lower due to air moving over it.
My setup includes three sensors, and a rotary switch to select which one shows up on the oil temp gauge.
Sender in the Feed line to engine "F":
Sender in the dry sump Tank "T":
And a third sender in the Oil pressure relief plug position (flywheel end) "E". (not pictured). You can see a significant difference between the three sensors as the engine heats up. Obviously the oil tank is the slowest to come up to temperature with 10L of oil in the whole system. Once the system is up to normal operating temperature (200deg), the temp stays relatively stable across all three sensors. The setup allows me to watch the tank to determine when the system is fully up to temp and ready for racing, I use the engine sensor to monitor temps normally, and switch to the feed if I'm seeing increased oil temps and/or want to diagnose the cooler/fan setup.
But my post started with being able to confirm the relief case sensor reads cool due to airflow over it. How?
I run a skid plate underneath my engine. With the plate installed, my oil temps are essentially exactly the same across all three. Remove the skid plate, and the sensor in the relief plug will drop 15-20deg. The amount of temperature drop is directly related to the traveling speed of the vehicle. Stop-and-Go around town and the temp senders match, hit the highway for a length of time and 20deg cooler. The airstream _does_ effect that sensor location.
-Dave
Instagram: @DaveHord
1971 1302s - Salzburg Tribute the #RallyBug
1958 Beetle
1975 Beetle
1973 Super Beetle
1993 C3500 with Cummins swap
1967 MGB
1963 MG Midget
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Jan 19, 2013 10:36 pm    Post subject: Reply with quote
Good to know.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Page 3 of 5
