oil in cylinders on top of pistons
hobbybob517
hobbybob517 is offline
PostPosted: Wed Feb 15, 2012 3:45 pm    Post subject: oil in cylinders on top of pistons Reply with quote
Hi guys,
pulled my cylinder heads off today, and i found some oil on top of my pistons,
is this normal? what is causing this?
also what is this hole under my oil cooler?
THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote:
3 million rpm? Well there's your problem! No wonder it blew up!
jamesdagg
jamesdagg is offline
PostPosted: Wed Feb 15, 2012 5:04 pm    Post subject: Reply with quote
Should not be oil there. Only source would be valve stem seals.
jim
'72 FI Westy
'71 Super rear inside defrost vents no longer available
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Feb 15, 2012 9:46 pm    Post subject: Reply with quote
No such thing as valve stem seals in stock ACVW engine. Even if there were, any leakage would be contained inside the engine.
Might be oil cooler leak.
Hole under cooler is casting norm.
In Stereo, Where Available!
VeedubPastor
VeedubPastor is offline
PostPosted: Wed Feb 15, 2012 9:47 pm    Post subject: Re: oil in cylinders on top of pistons Reply with quote
hobbybob517 wrote:
Hi guys,
You mean oil on top of your cylinders? It looks like your oil cooler is leaking. Not sure what that hole is. I don't have one there...
1971 Super Beetle - Daily Driver
Solex H30/31 & 034 distributor (yeah, I know)
Stock thermostat & flaps
Stock air cleaner and emissions equipment
hobbybob517
PostPosted: Wed Feb 15, 2012 11:26 pm    Post subject: Reply with quote
i did fix an oil cooler leak a while back, only ran the engine for a few minutes after that, what i don't understand is how a oil cooler leak could leak the oil into the cylinders?
can anyone explain so that i can check if it is fixed.
VeedubPastor
PostPosted: Wed Feb 15, 2012 11:40 pm    Post subject: Reply with quote
The previous answer is correct. The only way oil gets up there is through the valve guides after the engine is shut off. Do you get a puff of blue smoke when you first start it in the morning? I suppose it could get in there too if the crankcase was WAY over-filled...
hobbybob517
PostPosted: Wed Feb 15, 2012 11:44 pm    Post subject: Reply with quote
the engine has not been in the car for a while, but i did start it a few weeks ago, and it did give a big cloud of white/blue smoke.
how can i fix this problem? maybee my case is over filled, i have the bugpack dipstick, to which mark does the oil go? check when hot or cold?
VeedubPastor
PostPosted: Wed Feb 15, 2012 11:57 pm    Post subject: Reply with quote
Check when the car has been off for a few minutes but it doesn't have to be a cold engine. Car should be close to level. It should be between the two marks. The puff of smoke when you first start it is the oil burning off that las leaked into the cylinders through the worn valve guides while it was sitting.
hobbybob517
PostPosted: Thu Feb 16, 2012 12:00 am    Post subject: Reply with quote
how do i measure/check if my valve guides are worn?
at firts i thought the pistong rings where worn,
are valveguides easy to replace?
VeedubPastor
PostPosted: Thu Feb 16, 2012 12:06 am    Post subject: Reply with quote
You have to pull the heads. The valves should not wiggle from side to side in the guides. Do a search and you can see what is involved. If you suspect bad rings, have you done a compression test? Readings? If the rings are bad and the valve guides are worn, you may as well take care of those things while the engine is out. if you don't have the money right now and you just want to run it, keep a close eye on the oil level because the engine is going to consume oil. Good luck. 2:00 AM here so I'd better get to bed.
Eric&Barb
PostPosted: Thu Feb 16, 2012 9:34 am    Post subject: Reply with quote
If the cooler is leaking or perhaps there is a crack in the case there, the shroud is designed to BLOW air over the engine and thru the early cooler. So any oil leakage there can and will get blown right over the cylinders and downward.
A valve guide leak is only going to allow oil to leak into the cylinder. So unless there is a hole in the upper side of the cylinder....
Might try cleaning up the engine real well and starting it up for a minute without shroud and see if you can locate the leak.
There are oil leak detection kits out there that might help.
VeedubPastor
PostPosted: Thu Feb 16, 2012 9:43 am    Post subject: Reply with quote
Read the first post. Slowly. Read all the other posts. Then comment.
Eric&Barb
PostPosted: Thu Feb 16, 2012 9:48 am    Post subject: Reply with quote
Ah our mistake. Thanks did not catch that.
Was going by the image is looks like there is oil on the cylinders.
Could be your rings have gone bad.
schadenfreude
Banned
schadenfreude is offline
PostPosted: Thu Feb 16, 2012 11:06 am    Post subject: Reply with quote
the cylinders have oil in them, with the heads off
(inside !)
that is not normal for new engine.
and is par for course with antique motor. high mileage.
the reason is simple, lack of oil control.
or over filled like last poster stated.
or was motor parked upside down? on a pallet, surely id dont know.
1: rings are bad, (oil control rings (bottom)
2: valve guides are bad, tell me , are not they all? Just replaced mine.
mine were so loose , the valve stems felt like a gear shifter lever. Rolling Eyes
dah. end of life on the guides.
all this is academic , what you do is strip the motor
and mike (yes micrometer) it all and replace all worn parts.
the Bentleys has all the spec's there to do that.
most just pitch the jugs (with pistons ) to the trash.
then send out the heads for overhaul.
only 15% of heads that arrive at majors are rebuildable.
guess what ,mine were not.
guess why, some machinist made custom over sized (OD) guides
that spells the end of that.
$200 later, like new (labor only) parts more, i put in bugpacks best.
then rebuild the short block , like new. or fail.
here is my rebuild journal. (still not up to date ,but will be by days end)
http://ac-vw-remove.com/my-motor-build/clearance.html
hobbybob517
PostPosted: Thu Feb 16, 2012 11:13 am    Post subject: Reply with quote
i keep the motor on a table off the ground, it stands level, i'm going over later to check the oil level and valve guides.
schadenfreude
Banned
PostPosted: Thu Feb 16, 2012 12:00 pm    Post subject: Reply with quote
even with VC removed, springs on valves.
you reach in,
and push the stem up then down. repeat, ahhhhhhh
this is the rocker wear direction.
it will be , yes, horrible.
get elephant feet and prevent this in future. Porsche like.
hobbybob517
PostPosted: Thu Feb 16, 2012 3:19 pm    Post subject: Reply with quote
you reach in,
i don't understand, elephant feet?
VeedubPastor
PostPosted: Thu Feb 16, 2012 3:23 pm    Post subject: Reply with quote
Ball-tipped adjusters. Swivel adjusters...
schadenfreude
Banned
PostPosted: Thu Feb 16, 2012 5:40 pm    Post subject: Reply with quote
first hit , in gallery search.
