airkooledchris Samba Member
Posted: Sun Feb 19, 2012 11:09 am Post subject: help with Eberspacher BA6 heater wiring identification |
I can't read a wiring diagram to save my life unfortunately. Ive made a few random connections, but I simply can't find some of these on the diagrams so im hoping someone here can help.
The above picture is the end of the wiring loom that ends up in the passenger compartment. There are two connectors that mate this to the rest of the wiring loom going back to the actual heater and other components.
#1 - Ground (I know this one is right)
#2 - These two went to the fuse box on the Vanagon I pulled it from. Is this supposed to be switched 12V power?
#3 - Red wire ? Is this also switched 12V?
#4 - All Green wire with spade connector - was this a ground also?
#5 - Plug Adapter
#6 - All Green wire with spade connector - ground?
#7 - Gray wire with blue stripe coming from the Temperature Regulator Switch - My guess is that this goes to a dimmer switch signal for the light in the switch?
#8 - Brown Wire with White Stripe - coming from the Temperature Regulator Switch? - I have no idea what this is supposed to connect to?
#9 - brown wire coming from the Safety Switch. This im sure is ground, but correct me if wrong.
This is the wiring diagram I have been using from Scott at Germansupply:
http://germansupply.com/Scotts_Folder/F6_1_4_1.jpg |
Opossum Samba Member
Joined: February 26, 2005 Posts: 735 Location: Islets of Langerhans
Posted: Sun Feb 19, 2012 12:00 pm Post subject: |
Thanks, but those two are the same as the one big diagram above from Scott.
I can't find those two all green wires with the spades on them, and a few of them I just can't tell where they connect to. I would imagine that with the spades on those two all green wires that they were probably connected to either the fuse box or a ground. (but don't want to get that wrong obviously) |
Posted: Sun Feb 19, 2012 12:51 pm Post subject: |
The two all green wire diagram is on the page with the wire/part legend and color codes.
Far right near top of the diagram. Solid green color code is "gn". Looks like one connects to the fuel pump (G6) and the other to the overheating switch (F17). Then through a couple of connectors to the overheating fuse (S17) then to a relay (J8a).
Also, some of the photos in the repair manual might help: http://www.thesamba.com/vw/archives/manuals/1977eberspacher_ba6_repair_manual.php _________________ "You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner |
Posted: Sun Feb 19, 2012 9:57 pm Post subject: |
Thanks for the reply.
I don't know why I didn't do this before, but I traced the green wires to see what the other ends were connected to, in the hopes of figuring out what these ends connect to...
So, one of the all green wires goes to the Heater Relay, on a terminal marked with the letter F on the back of the relay.
The other green wire goes to the heater area under the bus, and ends up connecting to two wires on the other side of the loom. Those two wires are crimped onto a round connector which looks like its used to ground to the body where the coil mounts.
Is it possible that the ends im trying to find a location for are for opposite ends of the overheating fuse? |
Posted: Wed Feb 22, 2012 1:43 pm Post subject: |
Ive looked over some more user photo's of this setup and I think the two all green wires in the engine compartment are possibly for opposite ends of an inline fuse. there are a few of them in the wiring diagram but I don't have any in the current setup, so at least one or two of these unlabeled cabin side wires are likely going to fuses. |
rcrjacob Samba Member
Joined: June 23, 2008 Posts: 174 Location: Vacaville, CA
Posted: Sat Mar 10, 2012 9:15 pm Post subject: |
Sorry I didn't respond sooner... I'm the one with the youtube video. I bought a harness that was complete. Why is yours cut?? I might have another complete harness. _________________ 1974 7 Passenger - it's a mess
My M-Plate Decode:
http://www.vw-mplate.com/mcode.php?lang=EN&id=3447 |
Posted: Thu Apr 12, 2012 10:14 am Post subject: |
rcrjacob wrote: |
Sorry I didn't respond sooner... I'm the one with the youtube video. I bought a harness that was complete. Why is yours cut?? I might have another complete harness. |
Ill have to pull it all out again and shoot a short video of the setup. For some reason I thought id be able to match these up easier later on when I pulled this setup out of my old Vanagon.
I just found another youtube video showing a BA6 running on a bench. this one posted by skills@eurocarsplus:
I kept running into confusion over what should go where that ive temporarily set aside the project. I have however sourced the rest of the plumbing/etc to adapt it into a bay that didn't have one before, so hopefully I can get everything figured out by this summer for a full install. |
dvergillo Samba Member
Posted: Tue May 08, 2012 9:55 am Post subject: BA 6 heater |
In the video what is the knocking sound? Fuel pump? The '78 I just picked up has the ba 6. When the battery is hooked up it makes the same sound. The heater looks like it might not be factory or they cut a small section of a cross member for the heater exhaust.
Need to get it running first then worry about the gas heater.
Thanks |
Posted: Tue May 08, 2012 6:07 pm Post subject: |
Yeah it's the fuel pump. It pulses to regulate the flow. When the heater goes into high you can hear the pump speed up. _________________ 1974 7 Passenger - it's a mess
My M-Plate Decode:
Posted: Tue May 08, 2012 10:16 pm Post subject: |
Cool thanks for the info. Lots to learn with the gas heaters. My first thought was internal engine problem. I was glad to still hear the knock without the engine cranking. I know I 've got other dual relay po wiring issues.
Thanks again.
Dean |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51120 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 09, 2012 6:41 am Post subject: |
Sure it's the heater pump? if your bus has a progressive in place of the FI it may be an aftermarket fuel pump you're hearing. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed May 09, 2012 8:27 am Post subject: |
I 'm chasing a few too many items at once. Need to get it running before digging too deep into the heater.
I disconnected the engine fuel pump wiring and cranked the engine. Clunking noise is gone.
Thanks for the help.
Fyi :
1978 build 12 / 77
Stock hydro lifter 2.0 rebuilt at some point
stock FI system with PO wiring mods. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri Nov 27, 2015 7:37 am Post subject: Re: help with Eberspacher BA6 heater wiring identification |
For the record, the thick solid green wires are a fused safety function. Toss a inline fuse holder into that spot just like the ones in the engine compartment for backup lights and the heater fan
Since that ba6 is not in my bus, you shouldn't have to worry to much about it chris now I can see what all those damn numbers reference though...which is nice....the day AFTER I put it in and wire it up _________________ Stuart Zickefoose
206-841-7324
[email protected] |
