earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Fri Feb 10, 2012 4:22 pm Post subject: |
Modoc
now that you used the rear hub from your bicycle how are you going to get to work
I'm surprised no one make a cheap copy of the Berg linkage, it would so easy to make, I would but I'm not a big fan of shroud mounted linkages because the shroud can move around a bit throwing the synchronization off.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Fri Feb 10, 2012 5:08 pm Post subject: |
Makes the Scat linkage a very reasonable price.
The amount of time and material to build that has to be at least 3 times in cost and in weight of the Scat linkage. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Fri Feb 10, 2012 5:48 pm Post subject: |
It could just be my imagination, but think about this....
a four cylinder engine always has some torque shake, you know it tends to kind of "rotate" on the axis of the crank. Such is nature
The engine mounts being on the bottom, there is a degree of side-to-side vibration at the level of the carbs
The regular kadron linkage would be a lot more likely to vibrate due to this, compared to my linkage(both sides pull) or a hexbar type
Vibration could really wear out the throttle shaft bushings.......
Sometimes it is better to adjust the linkage with the engine running, the vibration kind of takes the play out of the joints, you know
should I balance both links to within one gram? |
Chuey Samba Member
Joined: October 18, 2010 Posts: 855 Location: Oceanside, California
Posted: Fri Feb 10, 2012 10:14 pm Post subject: |
Max, Yup. Thanks for the reply. It completely cleared up my question.
Chuey |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Thu Feb 23, 2012 7:52 am Post subject: |
Put the carbs on..linkage not really lining up though nwith the hole in the shroud Does something look wrong?
_________________ 1963 Ragtop Bug |
Chuey Samba Member
Posted: Thu Feb 23, 2012 10:48 pm Post subject: |
"Does something look wrong?"
Yes. You need a Miller Light can on the left side of the fan shroud for balance.
Chuey |
Posted: Thu Feb 23, 2012 11:54 pm Post subject: |
Yes,
Not only does it not line up but now you have to find a new place to put your coil since it goes right through your mounting area.
You would be better off getting the scat linkage.......it works. Period..... _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Fri Feb 24, 2012 6:32 am Post subject: |
clonebug wrote: |
Yes,
You would be better off getting the scat linkage.......it works. Period..... |
Do you really think I'm worried about relocating the coil? That's the easy part..Obviously I can go out and buy a new linkage, but that's not the point here. Someone did a lot of work to make this linkage, and I'm wondering if they just designed it around an aftermarket shroud. I may just cut the throttle pull piece off and weld it back on over to the left a bit. _________________ 1963 Ragtop Bug |
Posted: Sat Feb 25, 2012 3:18 pm Post subject: |
I figured it out, the spacers on either side were reversed, so its lined up now _________________ 1963 Ragtop Bug |
